[pdal-commits] [PDAL/PDAL] 118a05: add std::cout to --detail output of 'pdal delta
GitHub
noreply at github.com
Tue Oct 7 06:40:02 PDT 2014
Branch: refs/heads/bpfv1
Home: https://github.com/PDAL/PDAL
Commit: 118a05e1381b4e80d2ea1371388c49e33ae0e741
https://github.com/PDAL/PDAL/commit/118a05e1381b4e80d2ea1371388c49e33ae0e741
Author: Howard Butler <howard at hobu.co>
Date: 2014-09-12 (Fri, 12 Sep 2014)
Changed paths:
M src/kernel/Delta.cpp
Log Message:
Commit: 0bbd50d49928f4ba6265a634bed9c74108129f44
https://github.com/PDAL/PDAL/commit/0bbd50d49928f4ba6265a634bed9c74108129f44
Changed paths:
M include/pdal/PointBuffer.hpp
M src/filters/Chipper.cpp
Log Message:
sround instead of lround
Commit: 6b1757d3205cbe908e9e5cb76e44569a2d32e448
https://github.com/PDAL/PDAL/commit/6b1757d3205cbe908e9e5cb76e44569a2d32e448
Date: 2014-09-15 (Mon, 15 Sep 2014)
Changed paths:
M src/drivers/oci/OciReader.cpp
Log Message:
fix scale normalization bug
Commit: 5f330ebb66b05ff39c1f937f166672539552a11b
https://github.com/PDAL/PDAL/commit/5f330ebb66b05ff39c1f937f166672539552a11b
Date: 2014-09-16 (Tue, 16 Sep 2014)
Changed paths:
M src/drivers/bpf/BpfReader.cpp
Log Message:
support setting SRS in BPF reader
Commit: 0887bf51db5185434c3365fcda15419672baff2c
https://github.com/PDAL/PDAL/commit/0887bf51db5185434c3365fcda15419672baff2c
Date: 2014-09-23 (Tue, 23 Sep 2014)
Changed paths:
M src/drivers/nitf/Reader.cpp
Log Message:
always set LAS_OFFSET and LAS_LENGTH in nitf reader
Commit: 6429a8ec43fc1ab03760e58684fd7169e4f7804b
https://github.com/PDAL/PDAL/commit/6429a8ec43fc1ab03760e58684fd7169e4f7804b
Date: 2014-09-26 (Fri, 26 Sep 2014)
Changed paths:
M src/Dimension.cpp
Log Message:
sanitize space names and other bad characters out of Dimension
Commit: 2a563ba6a824a57851b4620098ae1ab01d9e92c8
https://github.com/PDAL/PDAL/commit/2a563ba6a824a57851b4620098ae1ab01d9e92c8
Changed paths:
Log Message:
fix up BPF SRS support
Commit: b90133c4dd81eb1731e39949212b470490508a35
https://github.com/PDAL/PDAL/commit/b90133c4dd81eb1731e39949212b470490508a35
Changed paths:
Log Message:
put PDAL_HAVE_GDAL guard around setSpatialReference call in BPF reader
Commit: 333f05715777b2d9ee68b702066d000b734d15cc
https://github.com/PDAL/PDAL/commit/333f05715777b2d9ee68b702066d000b734d15cc
Date: 2014-10-02 (Thu, 02 Oct 2014)
Changed paths:
M src/drivers/oci/OciSeqIterator.cpp
Log Message:
put back old scale normalization for drivers.oci.reader
Commit: fb799b13745e49f6e85d17561a84c11544d67a6b
https://github.com/PDAL/PDAL/commit/fb799b13745e49f6e85d17561a84c11544d67a6b
Date: 2014-10-03 (Fri, 03 Oct 2014)
Changed paths:
Log Message:
fix setField for int8_t/uint8_t -- boost::numeric_cast doesn't work on them
Commit: b843f9b70f4c540ff992ba45a87a273a690148b3
https://github.com/PDAL/PDAL/commit/b843f9b70f4c540ff992ba45a87a273a690148b3
Changed paths:
M include/pdal/drivers/oci/OciReader.hpp
M include/pdal/drivers/oci/OciSeqIterator.hpp
Log Message:
put back populate_pointsourceid capability in oracle reader
Commit: c71126ff10209ddd9b6944f4784f79d48710ce70
https://github.com/PDAL/PDAL/commit/c71126ff10209ddd9b6944f4784f79d48710ce70
Changed paths:
M include/pdal/drivers/oci/common.hpp
M src/drivers/oci/common.cpp
Log Message:
put back old drivers.oci.reader behavior (need to read from block's schema, not our own)
Commit: 6d459a29e53023b554221fa763ad28ffdec53e67
https://github.com/PDAL/PDAL/commit/6d459a29e53023b554221fa763ad28ffdec53e67
Changed paths:
Log Message:
remove debugging cruft
Commit: 0c2d2be7862b09edf3970b1fdd2dcccbf4e6f164
https://github.com/PDAL/PDAL/commit/0c2d2be7862b09edf3970b1fdd2dcccbf4e6f164
Changed paths:
Log Message:
don't write the same point over and over in point-major scenario
Commit: 7d55b78b4aba24fbcc15c46b6df72767cc327a63
https://github.com/PDAL/PDAL/commit/7d55b78b4aba24fbcc15c46b6df72767cc327a63
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2014-10-07 (Tue, 07 Oct 2014)
Changed paths:
M src/Dimension.cpp
Log Message:
Merge branch 'grid-1.3.3' of https://github.com/PDAL/PDAL into bpfv1
Commit: 7d18d4197e22cba5dfdb79c45d1b03dab299f057
https://github.com/PDAL/PDAL/commit/7d18d4197e22cba5dfdb79c45d1b03dab299f057
Changed paths:
Log Message:
Update EPSG reference for north UTM zones.
Compare: https://github.com/PDAL/PDAL/compare/07223464f521...7d18d4197e22
More information about the pdal-commits
