[pdal-commits] [PDAL/PDAL] 46954c: Merge branch 'pdal-info-summary' into pcl-tests
GitHub
noreply at github.com
Tue Oct 7 11:59:40 PDT 2014
Branch: refs/heads/pcl-tests
Home: https://github.com/PDAL/PDAL
Commit: 46954c99656a16145a7131d582315387186dc7ac
https://github.com/PDAL/PDAL/commit/46954c99656a16145a7131d582315387186dc7ac
Author: Michael P. Gerlek <mpg at flaxen.com>
Date: 2014-10-06 (Mon, 06 Oct 2014)
Changed paths:
M include/pdal/PDALUtils.hpp
M include/pdal/kernel/Info.hpp
M src/CMakeLists.txt
A src/PDALUtils.cpp
M src/kernel/Info.cpp
Log Message:
Commit: 0b3f006b6a0ce182bab9df8197ddde62f23ec3d1
https://github.com/PDAL/PDAL/commit/0b3f006b6a0ce182bab9df8197ddde62f23ec3d1
Changed paths:
M src/SpatialReference.cpp
M src/drivers/las/Reader.cpp
M src/drivers/nitf/MetadataReader.hpp
M src/drivers/nitf/NitfFile.cpp
M src/drivers/nitf/NitfFile.hpp
M src/drivers/nitf/Writer.cpp
M src/drivers/nitf/tre_plugins.cpp
M src/filters/Decimation.cpp
M src/pdal_config.cpp
M test/unit/main.cpp
Log Message:
Merge branch 'clang-warnings' into pcl-tests
Commit: dd8bdaeb47763d00147844e1ce302de24844a00f
https://github.com/PDAL/PDAL/commit/dd8bdaeb47763d00147844e1ce302de24844a00f
Changed paths:
A src/pclsupport/PCLPipeline.cpp
A src/pclsupport/PCLPipeline.h
A src/pclsupport/PCLPipeline.hpp
Log Message:
import PCL pipeline files from the PCL repo
Commit: fcdab382d8572bf1c89fb3f1185bf60e6b871ea6
https://github.com/PDAL/PDAL/commit/fcdab382d8572bf1c89fb3f1185bf60e6b871ea6
Changed paths:
M include/pdal/PCLConversions.hpp
M src/drivers/pcd/Reader.cpp
M src/drivers/pcd/Writer.cpp
M src/filters/PCLBlock.cpp
Log Message:
tighten up the namespaces
Commit: 6566496705fa24d61a9ad0f27bdb713e09c7a2f1
https://github.com/PDAL/PDAL/commit/6566496705fa24d61a9ad0f27bdb713e09c7a2f1
Changed paths:
M src/pclsupport/PCLPipeline.h
Log Message:
remove debugging
Commit: ac2820aa4a085df306144231a9d4d52d9494b232
https://github.com/PDAL/PDAL/commit/ac2820aa4a085df306144231a9d4d52d9494b232
Date: 2014-10-07 (Tue, 07 Oct 2014)
Changed paths:
M doc/tutorial/pcl_block_tutorial.rst
A test/data/filters/pcl/conditional_removal.xml
A test/data/filters/pcl/grid_minimum.xml
A test/data/filters/pcl/normal_estimation.xml
A test/data/filters/pcl/outlier_removal.xml
M test/data/filters/pcl/passthrough.json
A test/data/filters/pcl/passthrough.xml
M test/data/filters/pcl/passthrough_outlier_removal.json
A test/data/filters/pcl/passthrough_outlier_removal.xml
M test/data/filters/pcl/progressive_morphological_filter.json
A test/data/filters/pcl/progressive_morphological_filter.xml
A test/data/filters/pcl/progressive_morphological_filter2.json
A test/data/filters/pcl/voxel_grid.xml
R test/data/filters/pcl_conditional_removal.xml
R test/data/filters/pcl_grid_minimum.xml
R test/data/filters/pcl_normal_estimation.xml
R test/data/filters/pcl_outlier_removal.xml
R test/data/filters/pcl_passthrough.xml
R test/data/filters/pcl_passthrough_outlier_removal.xml
R test/data/filters/pcl_progressive_morphological_filter.xml
R test/data/filters/pcl_voxel_grid.xml
M test/unit/filters/PCLBlockFilterTest.cpp
Log Message:
cleanups on PCL tutorial
moved files into pal dir; cleanups on tutorial text; made examples
work; added examples as unit tests
Commit: f221181ed270134e0b1f57255beac63766e71108
https://github.com/PDAL/PDAL/commit/f221181ed270134e0b1f57255beac63766e71108
Changed paths:
M doc/stages/filters.pclblock.rst
A doc/tutorial/pcl_spec.rst
Log Message:
cleaned up PCL docs
cleaned up filter docs, brought over json spec file from PCL repo
Commit: 223dfcfe19b8e3dbaa01253b2cd1144caf3a81d6
https://github.com/PDAL/PDAL/commit/223dfcfe19b8e3dbaa01253b2cd1144caf3a81d6
Changed paths:
R test/data/filters/pcl/conditional_removal.json
R test/data/filters/pcl/conditional_removal.xml
A test/data/filters/pcl/example_PMF.json
A test/data/filters/pcl/example_PMF_2.json
A test/data/filters/pcl/example_PassThrough.json
A test/data/filters/pcl/example_PassThrough_2.json
A test/data/filters/pcl/filter_APMF.json
A test/data/filters/pcl/filter_ConditionalRemoval.json
A test/data/filters/pcl/filter_GridMinimum.json
A test/data/filters/pcl/filter_NormalEstimation.json
A test/data/filters/pcl/filter_PMF.json
A test/data/filters/pcl/filter_PassThrough.json
A test/data/filters/pcl/filter_RadiusOutlierRemoval.json
A test/data/filters/pcl/filter_StatisticalOutlierRemoval0.json
A test/data/filters/pcl/filter_VoxelGrid.json
R test/data/filters/pcl/grid_minimum.json
R test/data/filters/pcl/grid_minimum.xml
R test/data/filters/pcl/normal_estimation.json
R test/data/filters/pcl/normal_estimation.xml
R test/data/filters/pcl/outlier_removal.json
R test/data/filters/pcl/outlier_removal.xml
R test/data/filters/pcl/passthrough.json
M test/data/filters/pcl/passthrough.xml
R test/data/filters/pcl/passthrough_outlier_removal.json
R test/data/filters/pcl/passthrough_outlier_removal.xml
R test/data/filters/pcl/progressive_morphological_filter.json
R test/data/filters/pcl/progressive_morphological_filter.xml
R test/data/filters/pcl/progressive_morphological_filter2.json
R test/data/filters/pcl/voxel_grid.json
R test/data/filters/pcl/voxel_grid.xml
Log Message:
PCL test cleanup
renamed files for clarity; added unit tests for each filter
note: filter unit tests commented out, not yet passing
Commit: 6e56ed899e7a67a7cb6558ff581364e059806dfe
https://github.com/PDAL/PDAL/commit/6e56ed899e7a67a7cb6558ff581364e059806dfe
Changed paths:
M doc/tutorial/pcl_spec.rst
Log Message:
lint
Commit: 02cfd787f3105918090a4a1f9f56a40ed3a0abce
https://github.com/PDAL/PDAL/commit/02cfd787f3105918090a4a1f9f56a40ed3a0abce
Changed paths:
M src/pclsupport/PCLPipeline.hpp
Log Message:
added debugging support
Commit: 1486ab78911e099931ad0f03f6b08bd810fb80a1
https://github.com/PDAL/PDAL/commit/1486ab78911e099931ad0f03f6b08bd810fb80a1
Changed paths:
R test/data/filters/pcl/example_PMF.json
A test/data/filters/pcl/example_PMF_1.json
R test/data/filters/pcl/example_PassThrough.json
A test/data/filters/pcl/example_PassThrough_1.json
R test/data/filters/pcl/filter_APMF.json
A test/data/filters/pcl/filter_APMF_1.json
R test/data/filters/pcl/filter_ConditionalRemoval.json
A test/data/filters/pcl/filter_ConditionalRemoval_1.json
A test/data/filters/pcl/filter_ConditionalRemoval_2.json
M test/data/filters/pcl/filter_GridMinimum.json
R test/data/filters/pcl/filter_NormalEstimation.json
A test/data/filters/pcl/filter_NormalEstimation_1.json
A test/data/filters/pcl/filter_NormalEstimation_2.json
R test/data/filters/pcl/filter_PMF.json
A test/data/filters/pcl/filter_PMF_1.json
A test/data/filters/pcl/filter_PMF_2.json
A test/data/filters/pcl/filter_PMF_3.json
A test/data/filters/pcl/filter_PMF_4.json
A test/data/filters/pcl/filter_PMF_5.json
A test/data/filters/pcl/filter_PMF_6.json
A test/data/filters/pcl/filter_PMF_7.json
A test/data/filters/pcl/filter_PMF_8.json
A test/data/filters/pcl/filter_PMF_9.json
R test/data/filters/pcl/filter_PassThrough.json
A test/data/filters/pcl/filter_PassThrough_1.json
A test/data/filters/pcl/filter_PassThrough_2.json
R test/data/filters/pcl/filter_RadiusOutlierRemoval.json
A test/data/filters/pcl/filter_RadiusOutlierRemoval_1.json
A test/data/filters/pcl/filter_RadiusOutlierRemoval_2.json
R test/data/filters/pcl/filter_StatisticalOutlierRemoval0.json
A test/data/filters/pcl/filter_StatisticalOutlierRemoval_1.json
A test/data/filters/pcl/filter_StatisticalOutlierRemoval_2.json
M test/data/filters/pcl/filter_VoxelGrid.json
Log Message:
all the PCL filter unit tests now working
except the APMF one (still to be debugged)
use #define USE_SLOW_TESTS for maximal testing goodness
Compare: https://github.com/PDAL/PDAL/compare/46954c99656a^...1486ab78911e
More information about the pdal-commits
