[pdal-commits] [PDAL/PDAL] 9cc8dd: Add PCL kernel to compute Height Above Ground
GitHub
noreply at github.com
Thu Jan 29 13:10:53 PST 2015
Branch: refs/heads/initial-hag-kernel
Home: https://github.com/PDAL/PDAL
Commit: 9cc8ddbe3239adfc083ad22c627b711e23c42179
https://github.com/PDAL/PDAL/commit/9cc8ddbe3239adfc083ad22c627b711e23c42179
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2015-01-29 (Thu, 29 Jan 2015)
Changed paths:
M include/pdal/Dimension.hpp
M plugins/pcl/CMakeLists.txt
A plugins/pcl/kernel/HeightAboveGroundKernel.cpp
A plugins/pcl/kernel/HeightAboveGroundKernel.hpp
Log Message:
Requires either 1) classification dimension with ground returns in the input or
2) a secondary input that is only ground returns.
Computes Height Above Ground as difference in Z between the input point and the
nearest corresponding ground return (in the XYZ plane).
Reader drivers are inferred from the filenames, but the Writer must be BPF to
accomodate the non-standard dimension.
More information about the pdal-commits
