[pdal-commits] [PDAL/PDAL] 67d851: On OSX, don't build with install rpath
GitHub
noreply at github.com
Mon Apr 4 08:00:46 PDT 2016
Branch: refs/heads/offset-icebridge-longitude
Home: https://github.com/PDAL/PDAL
Commit: 67d8518c3cf6bddb1138d6cc7e0dcbb8049cf9de
https://github.com/PDAL/PDAL/commit/67d8518c3cf6bddb1138d6cc7e0dcbb8049cf9de
Author: Pete Gadomski <pete.gadomski at gmail.com>
Date: 2016-04-01 (Fri, 01 Apr 2016)
Changed paths:
M CMakeLists.txt
Log Message:
This is an identical change to #733. If cmake builds with install rpath
on OSX, `make test` is broken when `BUILD_SHARED_LIBS=ON` on OSX.
Commit: 91d0d9aeab9f5b753c2fcbc7945c3ee954d3d0ec
https://github.com/PDAL/PDAL/commit/91d0d9aeab9f5b753c2fcbc7945c3ee954d3d0ec
Changed paths:
M CMakeLists.txt
Log Message:
Silence BUILD_SHARED_LIBS=ON gtest warnings
When `BUILD_SHARED_LIBS=ON`, gtest emits a couple of cmake warnings, one
about MACOSX_RPATH and one about a missing link_directory. We can quiet
both warnings by setting these properties.
We could also just change gtest's CMakeLists.txt in our vendor
directory, but I'm submitting this change on the principle that the
vendor subdirectories should stay pristine. If vendored software can be
tweaked in our tree, then we should discard this patch and instead fix
things in `vendor/gtest-1.7.0/CMakeLists.txt`.
Commit: 8b5e2e69e467a90927f17280724fb6ff44e10922
https://github.com/PDAL/PDAL/commit/8b5e2e69e467a90927f17280724fb6ff44e10922
Author: Howard Butler <howard at hobu.co>
Date: 2016-04-04 (Mon, 04 Apr 2016)
Changed paths:
M CMakeLists.txt
Log Message:
Merge pull request #1210 from gadomski/gtest-shared-libs
Two changes when building on OSX w/ shared libs
Commit: ab66a6803dee1934006ce75f4f2031981de599f1
https://github.com/PDAL/PDAL/commit/ab66a6803dee1934006ce75f4f2031981de599f1
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Changed paths:
M include/pdal/util/Utils.hpp
M io/ilvis2/Ilvis2Reader.cpp
M io/ilvis2/Ilvis2Reader.hpp
M plugins/icebridge/io/IcebridgeReader.cpp
M plugins/icebridge/io/IcebridgeReader.hpp
M src/SpatialReference.cpp
M src/util/Utils.cpp
Log Message:
Move normalizeLongitude to Utils.
Commit: 90433dd7912d61cdd4eacd3ecfa7ac1b68eeebea
https://github.com/PDAL/PDAL/commit/90433dd7912d61cdd4eacd3ecfa7ac1b68eeebea
Changed paths:
M CMakeLists.txt
Log Message:
Merge branch 'master' into offset-icebridge-longitude
Compare: https://github.com/PDAL/PDAL/compare/a9124dc7ae24...90433dd7912d
More information about the pdal-commits
