[pdal-commits] [PDAL/PDAL] 51e0f7: Fix GDAL reader so that tests pass :)
GitHub
noreply at github.com
Wed Feb 17 12:17:25 PST 2016
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 51e0f721c8cf672b9f3a2cf9553909269a8c84f5
https://github.com/PDAL/PDAL/commit/51e0f721c8cf672b9f3a2cf9553909269a8c84f5
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2016-02-17 (Wed, 17 Feb 2016)
Changed paths:
M io/gdal/GDALReader.cpp
M src/GDALUtils.cpp
A test/data/gdal/byte.tif
A test/data/gdal/data.xyz
A test/data/gdal/float32.tif
A test/data/gdal/float64.tif
A test/data/gdal/int16.tif
A test/data/gdal/int32.tif
M test/unit/io/gdal/GDALReaderTest.cpp
Log Message:
Test tif files from from GDAL autotest. data.xyz file was generated from
float32.tif with gdal_translate.
Commit: e933b45d4510d1779219d0bc3441113a51d7b27c
https://github.com/PDAL/PDAL/commit/e933b45d4510d1779219d0bc3441113a51d7b27c
Author: Howard Butler <howard at hobu.co>
Changed paths:
M src/GDALUtils.cpp
Log Message:
Merge pull request #1135 from PDAL/fixgdal
Compare: https://github.com/PDAL/PDAL/compare/e76b229515a4...e933b45d4510
More information about the pdal-commits
