[pdal-commits] [PDAL/PDAL] 51e0f7: Fix GDAL reader so that tests pass :)
GitHub
noreply at github.com
Wed Feb 17 12:17:43 PST 2016
Branch: refs/heads/windows-warnings-cleanup-hobu
Home: https://github.com/PDAL/PDAL
Commit: 51e0f721c8cf672b9f3a2cf9553909269a8c84f5
https://github.com/PDAL/PDAL/commit/51e0f721c8cf672b9f3a2cf9553909269a8c84f5
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2016-02-17 (Wed, 17 Feb 2016)
Changed paths:
M io/gdal/GDALReader.cpp
M src/GDALUtils.cpp
A test/data/gdal/byte.tif
A test/data/gdal/data.xyz
A test/data/gdal/float32.tif
A test/data/gdal/float64.tif
A test/data/gdal/int16.tif
A test/data/gdal/int32.tif
M test/unit/io/gdal/GDALReaderTest.cpp
Log Message:
Test tif files from from GDAL autotest. data.xyz file was generated from
float32.tif with gdal_translate.
Commit: e41d193900cb1099d43b2f30d435e303f122cfd6
https://github.com/PDAL/PDAL/commit/e41d193900cb1099d43b2f30d435e303f122cfd6
Author: Mateusz Łoskot <mateusz at loskot.net>
Changed paths:
M include/pdal/util/Utils.hpp
Log Message:
Fix UB caused by incrementing pass-the-end iterator
Iterator returned from std::find_if may point pass-the-end,
but incrementing pass-the-end iterator is an undefined behaviour.
The bug was revealed by stringsplit case of the OptionsTest,
as well as UtilsTest, where final std::find_if returns end
iterator which must not be incremented.
Commit: 931c8ae7eac69220248c6df4fd0d13618b55af47
https://github.com/PDAL/PDAL/commit/931c8ae7eac69220248c6df4fd0d13618b55af47
Changed paths:
M src/util/Utils.cpp
Log Message:
Fix out of range access bug in trimTrailing
If input string is empty, size()-1 overflows
causing character access beyond valid range.
Commit: 37b3f35e75ef8fd52c66f789d6c1b35460a81bdf
https://github.com/PDAL/PDAL/commit/37b3f35e75ef8fd52c66f789d6c1b35460a81bdf
Changed paths:
Log Message:
Merge pull request #1129 from mloskot/ml/fix-utils-split2-ub
Commit: 2b1eb3f514fea3f0e20921fc57c4714cb0d1f48d
https://github.com/PDAL/PDAL/commit/2b1eb3f514fea3f0e20921fc57c4714cb0d1f48d
Changed paths:
Log Message:
Merge pull request #1130 from mloskot/ml/fix-trim
Commit: bbb283471071564d1e71e25ef3dc1e94162c1bca
https://github.com/PDAL/PDAL/commit/bbb283471071564d1e71e25ef3dc1e94162c1bca
Changed paths:
M test/unit/PDALUtilsTest.cpp
Log Message:
Open output file in binary mode to avoid EOL translation.
Otherwise, on Windows, EOL is translated to CRLF and test
files do not compare as equal.
Commit: d15222c41f95229cd40c3f9ca1486493cbf60d3c
https://github.com/PDAL/PDAL/commit/d15222c41f95229cd40c3f9ca1486493cbf60d3c
Changed paths:
Log Message:
Merge pull request #1132 from mloskot/ml/fix-cmp-files-eol
Commit: 3c54b01b51763292418246bfda53827e4507b003
https://github.com/PDAL/PDAL/commit/3c54b01b51763292418246bfda53827e4507b003
Changed paths:
M include/pdal/util/Uuid.hpp
Log Message:
Fix too small sprintf buffer in Uuid::unparse
sprintf always appends terminating null character, so the character
buffer used with sprintf needs to accommodate it.
Commit: 00a1ddf550b49429f7fc8c75837111dcd2ac753d
https://github.com/PDAL/PDAL/commit/00a1ddf550b49429f7fc8c75837111dcd2ac753d
Changed paths:
Log Message:
Merge pull request #1133 from mloskot/ml/fix-uuid-buffer-overrun
Commit: 98505f1184200a236cc273db467d4b23db704330
https://github.com/PDAL/PDAL/commit/98505f1184200a236cc273db467d4b23db704330
Changed paths:
M filters/crop/CropFilter.cpp
M include/pdal/Polygon.hpp
M src/Polygon.cpp
Log Message:
Use standard error handling for stream failure of Polygon.
Remove unnecessary indirection for GEOS context.
Commit: e76b229515a41b5cf7a2d891d0d5106042602659
https://github.com/PDAL/PDAL/commit/e76b229515a41b5cf7a2d891d0d5106042602659
Author: Howard Butler <howard at hobu.co>
Changed paths:
M src/Polygon.cpp
Log Message:
Merge pull request #1134 from PDAL/polycontext
Commit: e933b45d4510d1779219d0bc3441113a51d7b27c
https://github.com/PDAL/PDAL/commit/e933b45d4510d1779219d0bc3441113a51d7b27c
Changed paths:
M src/GDALUtils.cpp
Log Message:
Merge pull request #1135 from PDAL/fixgdal
Commit: 04072b6ec918a192b0729d20ebeb58207729aef2
https://github.com/PDAL/PDAL/commit/04072b6ec918a192b0729d20ebeb58207729aef2
Changed paths:
M src/GDALUtils.cpp
M src/Polygon.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into windows-warnings-cleanup-hobu
Compare: https://github.com/PDAL/PDAL/compare/f06f3b22315b...04072b6ec918
More information about the pdal-commits
