[pdal-commits] [PDAL/PDAL] b7f1c4: Documentation updates
GitHub noreply at github.com
Wed Nov 23 09:09:02 PST 2016
  Branch: refs/heads/kernel-links-add-hausdorff
  Home:   https://github.com/PDAL/PDAL
  Commit: b7f1c42f9f7e148481faa1578faee5779b518b5d
      https://github.com/PDAL/PDAL/commit/b7f1c42f9f7e148481faa1578faee5779b518b5d
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2016-11-23 (Wed, 23 Nov 2016)
  Changed paths:
    M doc/apps/density.rst
    A doc/apps/hausdorff.rst
    A doc/apps/sort.rst
    M kernels/delta/DeltaKernel.cpp
    M kernels/diff/DiffKernel.cpp
    M kernels/hausdorff/HausdorffKernel.cpp
    M kernels/info/InfoKernel.cpp
    M kernels/merge/MergeKernel.cpp
    M kernels/pipeline/PipelineKernel.cpp
    M kernels/random/RandomKernel.cpp
    M kernels/sort/SortKernel.cpp
    M kernels/split/SplitKernel.cpp
    M kernels/tindex/TIndexKernel.cpp
    M kernels/translate/TranslateKernel.cpp
    M plugins/hexbin/kernel/DensityKernel.cpp
    M plugins/pcl/kernel/GroundKernel.cpp
    M plugins/pcl/kernel/PCLKernel.cpp
    M plugins/pcl/kernel/ViewKernel.cpp
  Log Message:
* Add Hausdorff and Sort kernel documentation
* Update all kernel links to point to the real URLs
* Add note that density kernel only comes with Hexer
More information about the pdal-commits mailing list
