[pdal-commits] [PDAL/PDAL] b7f1c4: Documentation updates
GitHub
noreply at github.com
Wed Nov 23 10:08:43 PST 2016
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: b7f1c42f9f7e148481faa1578faee5779b518b5d
https://github.com/PDAL/PDAL/commit/b7f1c42f9f7e148481faa1578faee5779b518b5d
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2016-11-23 (Wed, 23 Nov 2016)
Changed paths:
M doc/apps/density.rst
A doc/apps/hausdorff.rst
A doc/apps/sort.rst
M kernels/delta/DeltaKernel.cpp
M kernels/diff/DiffKernel.cpp
M kernels/hausdorff/HausdorffKernel.cpp
M kernels/info/InfoKernel.cpp
M kernels/merge/MergeKernel.cpp
M kernels/pipeline/PipelineKernel.cpp
M kernels/random/RandomKernel.cpp
M kernels/sort/SortKernel.cpp
M kernels/split/SplitKernel.cpp
M kernels/tindex/TIndexKernel.cpp
M kernels/translate/TranslateKernel.cpp
M plugins/hexbin/kernel/DensityKernel.cpp
M plugins/pcl/kernel/GroundKernel.cpp
M plugins/pcl/kernel/PCLKernel.cpp
M plugins/pcl/kernel/ViewKernel.cpp
Log Message:
* Add Hausdorff and Sort kernel documentation
* Update all kernel links to point to the real URLs
* Add note that density kernel only comes with Hexer
Commit: 44075bce4a7d6c36ac0e38636568d66d114cb785
https://github.com/PDAL/PDAL/commit/44075bce4a7d6c36ac0e38636568d66d114cb785
Author: chambbj <brad.chambers at gmail.com>
Changed paths:
A doc/apps/sort.rst
Log Message:
Merge pull request #1403 from PDAL/kernel-links-add-hausdorff
Compare: https://github.com/PDAL/PDAL/compare/99a24312d603...44075bce4a7d
More information about the pdal-commits
