[pdal-commits] [PDAL/PDAL] 9d0c9a: Improve quality of derivative writer outputs
GitHub noreply at github.com
Fri Feb 3 08:01:02 PST 2017
  Branch: refs/heads/slope-update
  Home:   https://github.com/PDAL/PDAL
  Commit: 9d0c9ad90019dee615ff2d70b3029c27fb60bb3a
      https://github.com/PDAL/PDAL/commit/9d0c9ad90019dee615ff2d70b3029c27fb60bb3a
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2017-02-03 (Fri, 03 Feb 2017)
  Changed paths:
    M io/DerivativeWriter.cpp
    M io/DerivativeWriter.hpp
    M pdal/EigenUtils.cpp
    M pdal/EigenUtils.hpp
    M test/unit/EigenTest.cpp
  Log Message:
First, we had a bug in how we computed slope for the D8 method. We were
dividing the slope in the cardinal directions by sqrt(2) instead of the
diagonals.
Second, we offer a switch to output slopes in degrees, not just percent. Note,
this is really just a convenience as analysts should have been able to convert
in the GIS tool of their choice.
Finally, our DSM generation approach had a tendency to leave voids in the max
elevation matrix. We switched to something very similar to what the GDAL writer
does, that is, specifying a radius and considering all points within the
cylinder centered at the current grid cell. At the same time, we remove the DSM
cleaning step.
Future work should consider unifying the behavior of GDALGrid/GDALWriter with
DerivativeWriter such that we can leverage the existing implementation and hole
filling capabilities. We may also be able to convert this to support streaming.
More information about the pdal-commits mailing list
