[pdal-commits] [PDAL/PDAL] 11d55b: Enable streaming for filters.colorinterp where pos...
    GitHub
    noreply at github.com
    Tue Oct 10 12:31:40 PDT 2017
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 11d55bec978089a79b41435312ffcad1cf37ecb0
      https://github.com/PDAL/PDAL/commit/11d55bec978089a79b41435312ffcad1cf37ecb0
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2017-09-15 (Fri, 15 Sep 2017)
  Changed paths:
    M filters/ColorinterpFilter.cpp
    M filters/ColorinterpFilter.hpp
    M pdal/Stage.hpp
    M test/unit/CMakeLists.txt
    A test/unit/filters/ColorinterpFilterTest.cpp
  Log Message:
  Enable streaming for filters.colorinterp where possible.
Add tests for filters.colorinterp
Close #1609
  Commit: 73676be924a1a63ef57537d47c8860092a0d21ef
      https://github.com/PDAL/PDAL/commit/73676be924a1a63ef57537d47c8860092a0d21ef
  Author: Howard Butler <howard at hobu.co>
  Date:   2017-09-19 (Tue, 19 Sep 2017)
  Changed paths:
    M pdal/Stage.hpp
  Log Message:
  Merge branch 'post1.6' of github.com:PDAL/PDAL
  Commit: b6e613820477a6077d8713e30bcfb3747ccf328b
      https://github.com/PDAL/PDAL/commit/b6e613820477a6077d8713e30bcfb3747ccf328b
  Date:   2017-09-20 (Wed, 20 Sep 2017)
  Log Message:
  Merge branch 'master' of github.com:PDAL/PDAL
  Commit: 43d3c540d5ca2a1169e31a2da00535f7cda17fef
      https://github.com/PDAL/PDAL/commit/43d3c540d5ca2a1169e31a2da00535f7cda17fef
  Date:   2017-09-21 (Thu, 21 Sep 2017)
  Changed paths:
    M apps/pdal.cpp
    M doc/apps/delta.rst
    M kernels/DeltaKernel.cpp
    M kernels/DeltaKernel.hpp
    M kernels/GroundKernel.cpp
    M kernels/GroundKernel.hpp
    M kernels/TIndexKernel.cpp
    M kernels/TIndexKernel.hpp
    M kernels/TranslateKernel.cpp
    R pdal/KernelFactory.cpp
    R pdal/KernelFactory.hpp
    M pdal/StageFactory.cpp
    M plugins/pcl/kernel/PCLKernel.cpp
    M plugins/pcl/kernel/SmoothKernel.cpp
  Log Message:
  Commit: c5058f90610d7102484dcf2bc82a409cf5461fef
      https://github.com/PDAL/PDAL/commit/c5058f90610d7102484dcf2bc82a409cf5461fef
  Date:   2017-09-29 (Fri, 29 Sep 2017)
  Changed paths:
    M .gitignore
    M .travis.yml
    M CMakeLists.txt
    M doc/stages/filters.cpd.rst
    M doc/stages/readers.text.rst
    M filters/AssignFilter.cpp
    M filters/ColorizationFilter.cpp
    M filters/private/DimRange.cpp
    M io/LasReader.cpp
    M io/LasWriter.cpp
    M io/PlyReader.cpp
    M kernels/SortKernel.cpp
    M pdal/Kernel.cpp
    M pdal/Metadata.hpp
    M pdal/PDALUtils.hpp
    M pdal/util/ProgramArgs.hpp
    M pdal/util/Utils.cpp
    M pdal/util/Utils.hpp
    M plugins/cpd/filters/CpdFilter.cpp
    M plugins/pcl/filters/IcpFilter.cpp
    M scripts/ci/script.sh
    A scripts/docker/1.4-maintenance/alpine/10-backtrace-guards.patch
    A scripts/docker/1.4-maintenance/alpine/Dockerfile
    A scripts/docker/1.4-maintenance/ubuntu/Dockerfile
    A scripts/docker/1.5-maintenance/alpine/10-backtrace-guards.patch
    A scripts/docker/1.5-maintenance/alpine/Dockerfile
    A scripts/docker/1.5-maintenance/ubuntu/Dockerfile
    A scripts/docker/master/alpine/Dockerfile
    A scripts/docker/master/ubuntu/Dockerfile
    M test/unit/MetadataTest.cpp
    M test/unit/UtilsTest.cpp
    M tools/lasdump/Dumper.cpp
    M tools/lasdump/Dumper.hpp
    M vendor/eigen/Eigen/CMakeLists.txt
    M vendor/eigen/Eigen/Cholesky
    M vendor/eigen/Eigen/CholmodSupport
    M vendor/eigen/Eigen/Core
    M vendor/eigen/Eigen/Eigen
    M vendor/eigen/Eigen/Eigenvalues
    M vendor/eigen/Eigen/Geometry
    M vendor/eigen/Eigen/Householder
    M vendor/eigen/Eigen/IterativeLinearSolvers
    M vendor/eigen/Eigen/Jacobi
    M vendor/eigen/Eigen/LU
    M vendor/eigen/Eigen/MetisSupport
    M vendor/eigen/Eigen/OrderingMethods
    M vendor/eigen/Eigen/PaStiXSupport
    M vendor/eigen/Eigen/PardisoSupport
    M vendor/eigen/Eigen/QR
    M vendor/eigen/Eigen/QtAlignedMalloc
    M vendor/eigen/Eigen/SPQRSupport
    M vendor/eigen/Eigen/SVD
    M vendor/eigen/Eigen/Sparse
    M vendor/eigen/Eigen/SparseCholesky
    M vendor/eigen/Eigen/SparseCore
    M vendor/eigen/Eigen/SparseLU
    M vendor/eigen/Eigen/SparseQR
    M vendor/eigen/Eigen/StdDeque
    M vendor/eigen/Eigen/StdList
    M vendor/eigen/Eigen/StdVector
    M vendor/eigen/Eigen/SuperLUSupport
    M vendor/eigen/Eigen/UmfPackSupport
    M vendor/eigen/Eigen/src/Cholesky/LDLT.h
    M vendor/eigen/Eigen/src/Cholesky/LLT.h
    A vendor/eigen/Eigen/src/Cholesky/LLT_LAPACKE.h
    M vendor/eigen/Eigen/src/CholmodSupport/CholmodSupport.h
    M vendor/eigen/Eigen/src/Core/Array.h
    M vendor/eigen/Eigen/src/Core/ArrayBase.h
    M vendor/eigen/Eigen/src/Core/ArrayWrapper.h
    M vendor/eigen/Eigen/src/Core/Assign.h
    A vendor/eigen/Eigen/src/Core/AssignEvaluator.h
    M vendor/eigen/Eigen/src/Core/Assign_MKL.h
    M vendor/eigen/Eigen/src/Core/BandMatrix.h
    M vendor/eigen/Eigen/src/Core/Block.h
    M vendor/eigen/Eigen/src/Core/BooleanRedux.h
    M vendor/eigen/Eigen/src/Core/CommaInitializer.h
    A vendor/eigen/Eigen/src/Core/ConditionEstimator.h
    A vendor/eigen/Eigen/src/Core/CoreEvaluators.h
    M vendor/eigen/Eigen/src/Core/CoreIterators.h
    M vendor/eigen/Eigen/src/Core/CwiseBinaryOp.h
    M vendor/eigen/Eigen/src/Core/CwiseNullaryOp.h
    A vendor/eigen/Eigen/src/Core/CwiseTernaryOp.h
    M vendor/eigen/Eigen/src/Core/CwiseUnaryOp.h
    M vendor/eigen/Eigen/src/Core/CwiseUnaryView.h
    M vendor/eigen/Eigen/src/Core/DenseBase.h
    M vendor/eigen/Eigen/src/Core/DenseCoeffsBase.h
    M vendor/eigen/Eigen/src/Core/DenseStorage.h
    M vendor/eigen/Eigen/src/Core/Diagonal.h
    M vendor/eigen/Eigen/src/Core/DiagonalMatrix.h
    M vendor/eigen/Eigen/src/Core/DiagonalProduct.h
    M vendor/eigen/Eigen/src/Core/Dot.h
    M vendor/eigen/Eigen/src/Core/EigenBase.h
    M vendor/eigen/Eigen/src/Core/ForceAlignedAccess.h
    M vendor/eigen/Eigen/src/Core/Fuzzy.h
    M vendor/eigen/Eigen/src/Core/GeneralProduct.h
    M vendor/eigen/Eigen/src/Core/GenericPacketMath.h
    M vendor/eigen/Eigen/src/Core/GlobalFunctions.h
    M vendor/eigen/Eigen/src/Core/IO.h
    A vendor/eigen/Eigen/src/Core/Inverse.h
    M vendor/eigen/Eigen/src/Core/Map.h
    M vendor/eigen/Eigen/src/Core/MapBase.h
    M vendor/eigen/Eigen/src/Core/MathFunctions.h
    A vendor/eigen/Eigen/src/Core/MathFunctionsImpl.h
    M vendor/eigen/Eigen/src/Core/Matrix.h
    M vendor/eigen/Eigen/src/Core/MatrixBase.h
    M vendor/eigen/Eigen/src/Core/NestByValue.h
    M vendor/eigen/Eigen/src/Core/NoAlias.h
    M vendor/eigen/Eigen/src/Core/NumTraits.h
    M vendor/eigen/Eigen/src/Core/PermutationMatrix.h
    M vendor/eigen/Eigen/src/Core/PlainObjectBase.h
    A vendor/eigen/Eigen/src/Core/Product.h
    A vendor/eigen/Eigen/src/Core/ProductEvaluators.h
    M vendor/eigen/Eigen/src/Core/Random.h
    M vendor/eigen/Eigen/src/Core/Redux.h
    M vendor/eigen/Eigen/src/Core/Ref.h
    M vendor/eigen/Eigen/src/Core/Replicate.h
    M vendor/eigen/Eigen/src/Core/ReturnByValue.h
    M vendor/eigen/Eigen/src/Core/Reverse.h
    M vendor/eigen/Eigen/src/Core/Select.h
    M vendor/eigen/Eigen/src/Core/SelfAdjointView.h
    M vendor/eigen/Eigen/src/Core/SelfCwiseBinaryOp.h
    A vendor/eigen/Eigen/src/Core/Solve.h
    M vendor/eigen/Eigen/src/Core/SolveTriangular.h
    A vendor/eigen/Eigen/src/Core/SolverBase.h
    M vendor/eigen/Eigen/src/Core/StableNorm.h
    M vendor/eigen/Eigen/src/Core/Stride.h
    M vendor/eigen/Eigen/src/Core/Swap.h
    M vendor/eigen/Eigen/src/Core/Transpose.h
    M vendor/eigen/Eigen/src/Core/Transpositions.h
    M vendor/eigen/Eigen/src/Core/TriangularMatrix.h
    M vendor/eigen/Eigen/src/Core/VectorBlock.h
    M vendor/eigen/Eigen/src/Core/VectorwiseOp.h
    M vendor/eigen/Eigen/src/Core/Visitor.h
    A vendor/eigen/Eigen/src/Core/arch/AVX/Complex.h
    A vendor/eigen/Eigen/src/Core/arch/AVX/MathFunctions.h
    A vendor/eigen/Eigen/src/Core/arch/AVX/PacketMath.h
    A vendor/eigen/Eigen/src/Core/arch/AVX/TypeCasting.h
    A vendor/eigen/Eigen/src/Core/arch/AVX512/MathFunctions.h
    A vendor/eigen/Eigen/src/Core/arch/AVX512/PacketMath.h
    M vendor/eigen/Eigen/src/Core/arch/AltiVec/Complex.h
    A vendor/eigen/Eigen/src/Core/arch/AltiVec/MathFunctions.h
    M vendor/eigen/Eigen/src/Core/arch/AltiVec/PacketMath.h
    A vendor/eigen/Eigen/src/Core/arch/CUDA/Complex.h
    A vendor/eigen/Eigen/src/Core/arch/CUDA/Half.h
    A vendor/eigen/Eigen/src/Core/arch/CUDA/MathFunctions.h
    A vendor/eigen/Eigen/src/Core/arch/CUDA/PacketMath.h
    A vendor/eigen/Eigen/src/Core/arch/CUDA/PacketMathHalf.h
    A vendor/eigen/Eigen/src/Core/arch/CUDA/TypeCasting.h
    M vendor/eigen/Eigen/src/Core/arch/NEON/Complex.h
    A vendor/eigen/Eigen/src/Core/arch/NEON/MathFunctions.h
    M vendor/eigen/Eigen/src/Core/arch/NEON/PacketMath.h
    M vendor/eigen/Eigen/src/Core/arch/SSE/Complex.h
    M vendor/eigen/Eigen/src/Core/arch/SSE/MathFunctions.h
    M vendor/eigen/Eigen/src/Core/arch/SSE/PacketMath.h
    A vendor/eigen/Eigen/src/Core/arch/SSE/TypeCasting.h
    A vendor/eigen/Eigen/src/Core/arch/ZVector/Complex.h
    A vendor/eigen/Eigen/src/Core/arch/ZVector/MathFunctions.h
    A vendor/eigen/Eigen/src/Core/arch/ZVector/PacketMath.h
    A vendor/eigen/Eigen/src/Core/functors/AssignmentFunctors.h
    A vendor/eigen/Eigen/src/Core/functors/BinaryFunctors.h
    A vendor/eigen/Eigen/src/Core/functors/NullaryFunctors.h
    A vendor/eigen/Eigen/src/Core/functors/StlFunctors.h
    A vendor/eigen/Eigen/src/Core/functors/TernaryFunctors.h
    A vendor/eigen/Eigen/src/Core/functors/UnaryFunctors.h
    M vendor/eigen/Eigen/src/Core/products/GeneralBlockPanelKernel.h
    M vendor/eigen/Eigen/src/Core/products/GeneralMatrixMatrix.h
    M vendor/eigen/Eigen/src/Core/products/GeneralMatrixMatrixTriangular.h
    A vendor/eigen/Eigen/src/Core/products/GeneralMatrixMatrixTriangular_BLAS.h
    A vendor/eigen/Eigen/src/Core/products/GeneralMatrixMatrix_BLAS.h
    M vendor/eigen/Eigen/src/Core/products/GeneralMatrixVector.h
    A vendor/eigen/Eigen/src/Core/products/GeneralMatrixVector_BLAS.h
    M vendor/eigen/Eigen/src/Core/products/Parallelizer.h
    M vendor/eigen/Eigen/src/Core/products/SelfadjointMatrixMatrix.h
    A vendor/eigen/Eigen/src/Core/products/SelfadjointMatrixMatrix_BLAS.h
    M vendor/eigen/Eigen/src/Core/products/SelfadjointMatrixVector.h
    A vendor/eigen/Eigen/src/Core/products/SelfadjointMatrixVector_BLAS.h
    M vendor/eigen/Eigen/src/Core/products/SelfadjointProduct.h
    M vendor/eigen/Eigen/src/Core/products/SelfadjointRank2Update.h
    M vendor/eigen/Eigen/src/Core/products/TriangularMatrixMatrix.h
    A vendor/eigen/Eigen/src/Core/products/TriangularMatrixMatrix_BLAS.h
    M vendor/eigen/Eigen/src/Core/products/TriangularMatrixVector.h
    A vendor/eigen/Eigen/src/Core/products/TriangularMatrixVector_BLAS.h
    M vendor/eigen/Eigen/src/Core/products/TriangularSolverMatrix.h
    A vendor/eigen/Eigen/src/Core/products/TriangularSolverMatrix_BLAS.h
    M vendor/eigen/Eigen/src/Core/products/TriangularSolverVector.h
    M vendor/eigen/Eigen/src/Core/util/BlasUtil.h
    M vendor/eigen/Eigen/src/Core/util/Constants.h
    M vendor/eigen/Eigen/src/Core/util/DisableStupidWarnings.h
    M vendor/eigen/Eigen/src/Core/util/ForwardDeclarations.h
    M vendor/eigen/Eigen/src/Core/util/MKL_support.h
    M vendor/eigen/Eigen/src/Core/util/Macros.h
    M vendor/eigen/Eigen/src/Core/util/Memory.h
    M vendor/eigen/Eigen/src/Core/util/Meta.h
    M vendor/eigen/Eigen/src/Core/util/ReenableStupidWarnings.h
    M vendor/eigen/Eigen/src/Core/util/StaticAssert.h
    M vendor/eigen/Eigen/src/Core/util/XprHelper.h
    M vendor/eigen/Eigen/src/Eigenvalues/ComplexEigenSolver.h
    M vendor/eigen/Eigen/src/Eigenvalues/ComplexSchur.h
    A vendor/eigen/Eigen/src/Eigenvalues/ComplexSchur_LAPACKE.h
    M vendor/eigen/Eigen/src/Eigenvalues/EigenSolver.h
    M vendor/eigen/Eigen/src/Eigenvalues/GeneralizedEigenSolver.h
    M vendor/eigen/Eigen/src/Eigenvalues/GeneralizedSelfAdjointEigenSolver.h
    M vendor/eigen/Eigen/src/Eigenvalues/HessenbergDecomposition.h
    M vendor/eigen/Eigen/src/Eigenvalues/RealQZ.h
    M vendor/eigen/Eigen/src/Eigenvalues/RealSchur.h
    A vendor/eigen/Eigen/src/Eigenvalues/RealSchur_LAPACKE.h
    M vendor/eigen/Eigen/src/Eigenvalues/SelfAdjointEigenSolver.h
    A vendor/eigen/Eigen/src/Eigenvalues/SelfAdjointEigenSolver_LAPACKE.h
    M vendor/eigen/Eigen/src/Eigenvalues/Tridiagonalization.h
    M vendor/eigen/Eigen/src/Geometry/AlignedBox.h
    M vendor/eigen/Eigen/src/Geometry/AngleAxis.h
    M vendor/eigen/Eigen/src/Geometry/EulerAngles.h
    M vendor/eigen/Eigen/src/Geometry/Homogeneous.h
    M vendor/eigen/Eigen/src/Geometry/Hyperplane.h
    M vendor/eigen/Eigen/src/Geometry/OrthoMethods.h
    M vendor/eigen/Eigen/src/Geometry/ParametrizedLine.h
    M vendor/eigen/Eigen/src/Geometry/Quaternion.h
    M vendor/eigen/Eigen/src/Geometry/Rotation2D.h
    M vendor/eigen/Eigen/src/Geometry/RotationBase.h
    M vendor/eigen/Eigen/src/Geometry/Scaling.h
    M vendor/eigen/Eigen/src/Geometry/Transform.h
    M vendor/eigen/Eigen/src/Geometry/Translation.h
    M vendor/eigen/Eigen/src/Geometry/Umeyama.h
    M vendor/eigen/Eigen/src/Geometry/arch/Geometry_SSE.h
    M vendor/eigen/Eigen/src/Householder/BlockHouseholder.h
    M vendor/eigen/Eigen/src/Householder/Householder.h
    M vendor/eigen/Eigen/src/Householder/HouseholderSequence.h
    M vendor/eigen/Eigen/src/IterativeLinearSolvers/BasicPreconditioners.h
    M vendor/eigen/Eigen/src/IterativeLinearSolvers/BiCGSTAB.h
    M vendor/eigen/Eigen/src/IterativeLinearSolvers/ConjugateGradient.h
    A vendor/eigen/Eigen/src/IterativeLinearSolvers/IncompleteCholesky.h
    M vendor/eigen/Eigen/src/IterativeLinearSolvers/IncompleteLUT.h
    M vendor/eigen/Eigen/src/IterativeLinearSolvers/IterativeSolverBase.h
    A vendor/eigen/Eigen/src/IterativeLinearSolvers/LeastSquareConjugateGradient.h
    A vendor/eigen/Eigen/src/IterativeLinearSolvers/SolveWithGuess.h
    M vendor/eigen/Eigen/src/Jacobi/Jacobi.h
    M vendor/eigen/Eigen/src/LU/Determinant.h
    M vendor/eigen/Eigen/src/LU/FullPivLU.h
    A vendor/eigen/Eigen/src/LU/InverseImpl.h
    M vendor/eigen/Eigen/src/LU/PartialPivLU.h
    A vendor/eigen/Eigen/src/LU/PartialPivLU_LAPACKE.h
    M vendor/eigen/Eigen/src/LU/arch/Inverse_SSE.h
    M vendor/eigen/Eigen/src/MetisSupport/MetisSupport.h
    M vendor/eigen/Eigen/src/OrderingMethods/Amd.h
    M vendor/eigen/Eigen/src/OrderingMethods/Eigen_Colamd.h
    M vendor/eigen/Eigen/src/OrderingMethods/Ordering.h
    M vendor/eigen/Eigen/src/PaStiXSupport/PaStiXSupport.h
    M vendor/eigen/Eigen/src/PardisoSupport/PardisoSupport.h
    M vendor/eigen/Eigen/src/QR/ColPivHouseholderQR.h
    A vendor/eigen/Eigen/src/QR/ColPivHouseholderQR_LAPACKE.h
    A vendor/eigen/Eigen/src/QR/CompleteOrthogonalDecomposition.h
    M vendor/eigen/Eigen/src/QR/FullPivHouseholderQR.h
    M vendor/eigen/Eigen/src/QR/HouseholderQR.h
    A vendor/eigen/Eigen/src/QR/HouseholderQR_LAPACKE.h
    M vendor/eigen/Eigen/src/SPQRSupport/SuiteSparseQRSupport.h
    A vendor/eigen/Eigen/src/SVD/BDCSVD.h
    M vendor/eigen/Eigen/src/SVD/JacobiSVD.h
    A vendor/eigen/Eigen/src/SVD/JacobiSVD_LAPACKE.h
    A vendor/eigen/Eigen/src/SVD/SVDBase.h
    M vendor/eigen/Eigen/src/SVD/UpperBidiagonalization.h
    M vendor/eigen/Eigen/src/SparseCholesky/SimplicialCholesky.h
    M vendor/eigen/Eigen/src/SparseCholesky/SimplicialCholesky_impl.h
    M vendor/eigen/Eigen/src/SparseCore/AmbiVector.h
    M vendor/eigen/Eigen/src/SparseCore/CompressedStorage.h
    M vendor/eigen/Eigen/src/SparseCore/ConservativeSparseSparseProduct.h
    M vendor/eigen/Eigen/src/SparseCore/MappedSparseMatrix.h
    A vendor/eigen/Eigen/src/SparseCore/SparseAssign.h
    M vendor/eigen/Eigen/src/SparseCore/SparseBlock.h
    M vendor/eigen/Eigen/src/SparseCore/SparseColEtree.h
    A vendor/eigen/Eigen/src/SparseCore/SparseCompressedBase.h
    M vendor/eigen/Eigen/src/SparseCore/SparseCwiseBinaryOp.h
    M vendor/eigen/Eigen/src/SparseCore/SparseCwiseUnaryOp.h
    M vendor/eigen/Eigen/src/SparseCore/SparseDenseProduct.h
    M vendor/eigen/Eigen/src/SparseCore/SparseDiagonalProduct.h
    M vendor/eigen/Eigen/src/SparseCore/SparseDot.h
    M vendor/eigen/Eigen/src/SparseCore/SparseFuzzy.h
    A vendor/eigen/Eigen/src/SparseCore/SparseMap.h
    M vendor/eigen/Eigen/src/SparseCore/SparseMatrix.h
    M vendor/eigen/Eigen/src/SparseCore/SparseMatrixBase.h
    M vendor/eigen/Eigen/src/SparseCore/SparsePermutation.h
    M vendor/eigen/Eigen/src/SparseCore/SparseProduct.h
    M vendor/eigen/Eigen/src/SparseCore/SparseRedux.h
    A vendor/eigen/Eigen/src/SparseCore/SparseRef.h
    M vendor/eigen/Eigen/src/SparseCore/SparseSelfAdjointView.h
    A vendor/eigen/Eigen/src/SparseCore/SparseSolverBase.h
    M vendor/eigen/Eigen/src/SparseCore/SparseSparseProductWithPruning.h
    M vendor/eigen/Eigen/src/SparseCore/SparseTranspose.h
    M vendor/eigen/Eigen/src/SparseCore/SparseTriangularView.h
    M vendor/eigen/Eigen/src/SparseCore/SparseUtil.h
    M vendor/eigen/Eigen/src/SparseCore/SparseVector.h
    M vendor/eigen/Eigen/src/SparseCore/SparseView.h
    M vendor/eigen/Eigen/src/SparseCore/TriangularSolver.h
    M vendor/eigen/Eigen/src/SparseLU/SparseLU.h
    M vendor/eigen/Eigen/src/SparseLU/SparseLUImpl.h
    M vendor/eigen/Eigen/src/SparseLU/SparseLU_Memory.h
    M vendor/eigen/Eigen/src/SparseLU/SparseLU_Structs.h
    M vendor/eigen/Eigen/src/SparseLU/SparseLU_SupernodalMatrix.h
    M vendor/eigen/Eigen/src/SparseLU/SparseLU_Utils.h
    M vendor/eigen/Eigen/src/SparseLU/SparseLU_column_bmod.h
    M vendor/eigen/Eigen/src/SparseLU/SparseLU_column_dfs.h
    M vendor/eigen/Eigen/src/SparseLU/SparseLU_copy_to_ucol.h
    M vendor/eigen/Eigen/src/SparseLU/SparseLU_gemm_kernel.h
    M vendor/eigen/Eigen/src/SparseLU/SparseLU_heap_relax_snode.h
    M vendor/eigen/Eigen/src/SparseLU/SparseLU_kernel_bmod.h
    M vendor/eigen/Eigen/src/SparseLU/SparseLU_panel_bmod.h
    M vendor/eigen/Eigen/src/SparseLU/SparseLU_panel_dfs.h
    M vendor/eigen/Eigen/src/SparseLU/SparseLU_pivotL.h
    M vendor/eigen/Eigen/src/SparseLU/SparseLU_pruneL.h
    M vendor/eigen/Eigen/src/SparseLU/SparseLU_relax_snode.h
    M vendor/eigen/Eigen/src/SparseQR/SparseQR.h
    M vendor/eigen/Eigen/src/StlSupport/StdDeque.h
    M vendor/eigen/Eigen/src/StlSupport/StdList.h
    M vendor/eigen/Eigen/src/StlSupport/StdVector.h
    M vendor/eigen/Eigen/src/StlSupport/details.h
    M vendor/eigen/Eigen/src/SuperLUSupport/SuperLUSupport.h
    M vendor/eigen/Eigen/src/UmfPackSupport/UmfPackSupport.h
    M vendor/eigen/Eigen/src/misc/Image.h
    M vendor/eigen/Eigen/src/misc/Kernel.h
    A vendor/eigen/Eigen/src/misc/RealSvd2x2.h
    M vendor/eigen/Eigen/src/misc/blas.h
    A vendor/eigen/Eigen/src/misc/lapack.h
    A vendor/eigen/Eigen/src/misc/lapacke.h
    A vendor/eigen/Eigen/src/misc/lapacke_mangling.h
    M vendor/eigen/Eigen/src/plugins/ArrayCwiseBinaryOps.h
    M vendor/eigen/Eigen/src/plugins/ArrayCwiseUnaryOps.h
    M vendor/eigen/Eigen/src/plugins/BlockMethods.h
    M vendor/eigen/Eigen/src/plugins/CommonCwiseBinaryOps.h
    M vendor/eigen/Eigen/src/plugins/CommonCwiseUnaryOps.h
    M vendor/eigen/Eigen/src/plugins/MatrixCwiseBinaryOps.h
    M vendor/eigen/Eigen/src/plugins/MatrixCwiseUnaryOps.h
  Log Message:
  Commit: c3f2a5c10d06d0c8d7b987c1cf93e03c90addd9d
      https://github.com/PDAL/PDAL/commit/c3f2a5c10d06d0c8d7b987c1cf93e03c90addd9d
  Changed paths:
    M doc/stages/filters.assign.rst
    M pdal/GDALUtils.hpp
    M test/unit/filters/ColorinterpFilterTest.cpp
  Log Message:
  Commit: 336f2dda45746674cd18573c6f77c0e9f43e397d
      https://github.com/PDAL/PDAL/commit/336f2dda45746674cd18573c6f77c0e9f43e397d
  Date:   2017-10-02 (Mon, 02 Oct 2017)
  Changed paths:
    M java/core-scala/src/main/scala/io/pdal/pipeline/PipelineExpressions.scala
    M java/core-scala/src/main/scala/io/pdal/pipeline/json/Implicits.scala
  Log Message:
  Commit: 591f10500b8601f4f8589cb173a337cd0516ad3e
      https://github.com/PDAL/PDAL/commit/591f10500b8601f4f8589cb173a337cd0516ad3e
  Date:   2017-10-10 (Tue, 10 Oct 2017)
  Changed paths:
    M CMakeLists.txt
    M doc/stages/filters.ferry.rst
    M doc/stages/filters.smrf.rst
    M filters/FerryFilter.cpp
    M filters/FerryFilter.hpp
    M filters/SampleFilter.cpp
    M io/LasReader.cpp
    M io/LasReader.hpp
    M io/LasWriter.cpp
    M io/LasWriter.hpp
    M pdal/Dimension.json
    M pdal/Stage.cpp
    M pdal/Stage.hpp
    M plugins/nitf/io/NitfWriter.cpp
    M scripts/docker/master/alpine/Dockerfile
    M scripts/docker/master/ubuntu/Dockerfile
    M test/unit/filters/FerryFilterTest.cpp
    M test/unit/io/LasWriterTest.cpp
  Log Message:
  Commit: 976821dd5180d7ab471e3d4a8663147e42e5b9ff
      https://github.com/PDAL/PDAL/commit/976821dd5180d7ab471e3d4a8663147e42e5b9ff
  Changed paths:
    M cmake/examples/hobu-config.sh
    M cmake/modules/FindMatlab.cmake
    M plugins/matlab/filters/MatlabFilter.cpp
    M plugins/matlab/filters/MatlabFilter.hpp
    M plugins/matlab/filters/Script.cpp
    M plugins/matlab/filters/Script.hpp
    M plugins/matlab/io/MatlabWriter.cpp
    M plugins/matlab/test/MatlabFilterTest.cpp
  Log Message:
  Commit: 2c8c67d05bb3074fbc417961459870e67b595c85
      https://github.com/PDAL/PDAL/commit/2c8c67d05bb3074fbc417961459870e67b595c85
  Changed paths:
    M scripts/docker/dependencies/Dockerfile
  Log Message:
  use LASzip 3.1.1 for pdal/dependencies docker image
Compare: https://github.com/PDAL/PDAL/compare/e26906850795...2c8c67d05bb3
More information about the pdal-commits
