[pdal-commits] [PDAL/PDAL] 11d55b: Enable streaming for filters.colorinterp where pos...
GitHub
noreply at github.com
Fri Oct 13 09:48:07 PDT 2017
Branch: refs/tags/docker-master
Home: https://github.com/PDAL/PDAL
Commit: 11d55bec978089a79b41435312ffcad1cf37ecb0
https://github.com/PDAL/PDAL/commit/11d55bec978089a79b41435312ffcad1cf37ecb0
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2017-09-15 (Fri, 15 Sep 2017)
Changed paths:
M filters/ColorinterpFilter.cpp
M filters/ColorinterpFilter.hpp
M pdal/Stage.hpp
M test/unit/CMakeLists.txt
A test/unit/filters/ColorinterpFilterTest.cpp
Log Message:
Enable streaming for filters.colorinterp where possible.
Add tests for filters.colorinterp
Close #1609
Commit: 73676be924a1a63ef57537d47c8860092a0d21ef
https://github.com/PDAL/PDAL/commit/73676be924a1a63ef57537d47c8860092a0d21ef
Author: Howard Butler <howard at hobu.co>
Date: 2017-09-19 (Tue, 19 Sep 2017)
Changed paths:
M pdal/Stage.hpp
Log Message:
Merge branch 'post1.6' of github.com:PDAL/PDAL
Commit: b6e613820477a6077d8713e30bcfb3747ccf328b
https://github.com/PDAL/PDAL/commit/b6e613820477a6077d8713e30bcfb3747ccf328b
Date: 2017-09-20 (Wed, 20 Sep 2017)
Log Message:
Merge branch 'master' of github.com:PDAL/PDAL
Commit: 43d3c540d5ca2a1169e31a2da00535f7cda17fef
https://github.com/PDAL/PDAL/commit/43d3c540d5ca2a1169e31a2da00535f7cda17fef
Date: 2017-09-21 (Thu, 21 Sep 2017)
Changed paths:
M apps/pdal.cpp
M doc/apps/delta.rst
M kernels/DeltaKernel.cpp
M kernels/DeltaKernel.hpp
M kernels/GroundKernel.cpp
M kernels/GroundKernel.hpp
M kernels/TIndexKernel.cpp
M kernels/TIndexKernel.hpp
M kernels/TranslateKernel.cpp
R pdal/KernelFactory.cpp
R pdal/KernelFactory.hpp
M pdal/StageFactory.cpp
M plugins/pcl/kernel/PCLKernel.cpp
M plugins/pcl/kernel/SmoothKernel.cpp
Log Message:
Commit: c5058f90610d7102484dcf2bc82a409cf5461fef
https://github.com/PDAL/PDAL/commit/c5058f90610d7102484dcf2bc82a409cf5461fef
Date: 2017-09-29 (Fri, 29 Sep 2017)
Changed paths:
M .gitignore
M .travis.yml
M CMakeLists.txt
M doc/stages/filters.cpd.rst
M doc/stages/readers.text.rst
M filters/AssignFilter.cpp
M filters/ColorizationFilter.cpp
M filters/private/DimRange.cpp
M io/LasReader.cpp
M io/LasWriter.cpp
M io/PlyReader.cpp
M kernels/SortKernel.cpp
M pdal/Kernel.cpp
M pdal/Metadata.hpp
M pdal/PDALUtils.hpp
M pdal/util/ProgramArgs.hpp
M pdal/util/Utils.cpp
M pdal/util/Utils.hpp
M plugins/cpd/filters/CpdFilter.cpp
M plugins/pcl/filters/IcpFilter.cpp
M scripts/ci/script.sh
A scripts/docker/1.4-maintenance/alpine/10-backtrace-guards.patch
A scripts/docker/1.4-maintenance/alpine/Dockerfile
A scripts/docker/1.4-maintenance/ubuntu/Dockerfile
A scripts/docker/1.5-maintenance/alpine/10-backtrace-guards.patch
A scripts/docker/1.5-maintenance/alpine/Dockerfile
A scripts/docker/1.5-maintenance/ubuntu/Dockerfile
A scripts/docker/master/alpine/Dockerfile
A scripts/docker/master/ubuntu/Dockerfile
M test/unit/MetadataTest.cpp
M test/unit/UtilsTest.cpp
M tools/lasdump/Dumper.cpp
M tools/lasdump/Dumper.hpp
M vendor/eigen/Eigen/CMakeLists.txt
M vendor/eigen/Eigen/Cholesky
M vendor/eigen/Eigen/CholmodSupport
M vendor/eigen/Eigen/Core
M vendor/eigen/Eigen/Eigen
M vendor/eigen/Eigen/Eigenvalues
M vendor/eigen/Eigen/Geometry
M vendor/eigen/Eigen/Householder
M vendor/eigen/Eigen/IterativeLinearSolvers
M vendor/eigen/Eigen/Jacobi
M vendor/eigen/Eigen/LU
M vendor/eigen/Eigen/MetisSupport
M vendor/eigen/Eigen/OrderingMethods
M vendor/eigen/Eigen/PaStiXSupport
M vendor/eigen/Eigen/PardisoSupport
M vendor/eigen/Eigen/QR
M vendor/eigen/Eigen/QtAlignedMalloc
M vendor/eigen/Eigen/SPQRSupport
M vendor/eigen/Eigen/SVD
M vendor/eigen/Eigen/Sparse
M vendor/eigen/Eigen/SparseCholesky
M vendor/eigen/Eigen/SparseCore
M vendor/eigen/Eigen/SparseLU
M vendor/eigen/Eigen/SparseQR
M vendor/eigen/Eigen/StdDeque
M vendor/eigen/Eigen/StdList
M vendor/eigen/Eigen/StdVector
M vendor/eigen/Eigen/SuperLUSupport
M vendor/eigen/Eigen/UmfPackSupport
M vendor/eigen/Eigen/src/Cholesky/LDLT.h
M vendor/eigen/Eigen/src/Cholesky/LLT.h
A vendor/eigen/Eigen/src/Cholesky/LLT_LAPACKE.h
M vendor/eigen/Eigen/src/CholmodSupport/CholmodSupport.h
M vendor/eigen/Eigen/src/Core/Array.h
M vendor/eigen/Eigen/src/Core/ArrayBase.h
M vendor/eigen/Eigen/src/Core/ArrayWrapper.h
M vendor/eigen/Eigen/src/Core/Assign.h
A vendor/eigen/Eigen/src/Core/AssignEvaluator.h
M vendor/eigen/Eigen/src/Core/Assign_MKL.h
M vendor/eigen/Eigen/src/Core/BandMatrix.h
M vendor/eigen/Eigen/src/Core/Block.h
M vendor/eigen/Eigen/src/Core/BooleanRedux.h
M vendor/eigen/Eigen/src/Core/CommaInitializer.h
A vendor/eigen/Eigen/src/Core/ConditionEstimator.h
A vendor/eigen/Eigen/src/Core/CoreEvaluators.h
M vendor/eigen/Eigen/src/Core/CoreIterators.h
M vendor/eigen/Eigen/src/Core/CwiseBinaryOp.h
M vendor/eigen/Eigen/src/Core/CwiseNullaryOp.h
A vendor/eigen/Eigen/src/Core/CwiseTernaryOp.h
M vendor/eigen/Eigen/src/Core/CwiseUnaryOp.h
M vendor/eigen/Eigen/src/Core/CwiseUnaryView.h
M vendor/eigen/Eigen/src/Core/DenseBase.h
M vendor/eigen/Eigen/src/Core/DenseCoeffsBase.h
M vendor/eigen/Eigen/src/Core/DenseStorage.h
M vendor/eigen/Eigen/src/Core/Diagonal.h
M vendor/eigen/Eigen/src/Core/DiagonalMatrix.h
M vendor/eigen/Eigen/src/Core/DiagonalProduct.h
M vendor/eigen/Eigen/src/Core/Dot.h
M vendor/eigen/Eigen/src/Core/EigenBase.h
M vendor/eigen/Eigen/src/Core/ForceAlignedAccess.h
M vendor/eigen/Eigen/src/Core/Fuzzy.h
M vendor/eigen/Eigen/src/Core/GeneralProduct.h
M vendor/eigen/Eigen/src/Core/GenericPacketMath.h
M vendor/eigen/Eigen/src/Core/GlobalFunctions.h
M vendor/eigen/Eigen/src/Core/IO.h
A vendor/eigen/Eigen/src/Core/Inverse.h
M vendor/eigen/Eigen/src/Core/Map.h
M vendor/eigen/Eigen/src/Core/MapBase.h
M vendor/eigen/Eigen/src/Core/MathFunctions.h
A vendor/eigen/Eigen/src/Core/MathFunctionsImpl.h
M vendor/eigen/Eigen/src/Core/Matrix.h
M vendor/eigen/Eigen/src/Core/MatrixBase.h
M vendor/eigen/Eigen/src/Core/NestByValue.h
M vendor/eigen/Eigen/src/Core/NoAlias.h
M vendor/eigen/Eigen/src/Core/NumTraits.h
M vendor/eigen/Eigen/src/Core/PermutationMatrix.h
M vendor/eigen/Eigen/src/Core/PlainObjectBase.h
A vendor/eigen/Eigen/src/Core/Product.h
A vendor/eigen/Eigen/src/Core/ProductEvaluators.h
M vendor/eigen/Eigen/src/Core/Random.h
M vendor/eigen/Eigen/src/Core/Redux.h
M vendor/eigen/Eigen/src/Core/Ref.h
M vendor/eigen/Eigen/src/Core/Replicate.h
M vendor/eigen/Eigen/src/Core/ReturnByValue.h
M vendor/eigen/Eigen/src/Core/Reverse.h
M vendor/eigen/Eigen/src/Core/Select.h
M vendor/eigen/Eigen/src/Core/SelfAdjointView.h
M vendor/eigen/Eigen/src/Core/SelfCwiseBinaryOp.h
A vendor/eigen/Eigen/src/Core/Solve.h
M vendor/eigen/Eigen/src/Core/SolveTriangular.h
A vendor/eigen/Eigen/src/Core/SolverBase.h
M vendor/eigen/Eigen/src/Core/StableNorm.h
M vendor/eigen/Eigen/src/Core/Stride.h
M vendor/eigen/Eigen/src/Core/Swap.h
M vendor/eigen/Eigen/src/Core/Transpose.h
M vendor/eigen/Eigen/src/Core/Transpositions.h
M vendor/eigen/Eigen/src/Core/TriangularMatrix.h
M vendor/eigen/Eigen/src/Core/VectorBlock.h
M vendor/eigen/Eigen/src/Core/VectorwiseOp.h
M vendor/eigen/Eigen/src/Core/Visitor.h
A vendor/eigen/Eigen/src/Core/arch/AVX/Complex.h
A vendor/eigen/Eigen/src/Core/arch/AVX/MathFunctions.h
A vendor/eigen/Eigen/src/Core/arch/AVX/PacketMath.h
A vendor/eigen/Eigen/src/Core/arch/AVX/TypeCasting.h
A vendor/eigen/Eigen/src/Core/arch/AVX512/MathFunctions.h
A vendor/eigen/Eigen/src/Core/arch/AVX512/PacketMath.h
M vendor/eigen/Eigen/src/Core/arch/AltiVec/Complex.h
A vendor/eigen/Eigen/src/Core/arch/AltiVec/MathFunctions.h
M vendor/eigen/Eigen/src/Core/arch/AltiVec/PacketMath.h
A vendor/eigen/Eigen/src/Core/arch/CUDA/Complex.h
A vendor/eigen/Eigen/src/Core/arch/CUDA/Half.h
A vendor/eigen/Eigen/src/Core/arch/CUDA/MathFunctions.h
A vendor/eigen/Eigen/src/Core/arch/CUDA/PacketMath.h
A vendor/eigen/Eigen/src/Core/arch/CUDA/PacketMathHalf.h
A vendor/eigen/Eigen/src/Core/arch/CUDA/TypeCasting.h
M vendor/eigen/Eigen/src/Core/arch/NEON/Complex.h
A vendor/eigen/Eigen/src/Core/arch/NEON/MathFunctions.h
M vendor/eigen/Eigen/src/Core/arch/NEON/PacketMath.h
M vendor/eigen/Eigen/src/Core/arch/SSE/Complex.h
M vendor/eigen/Eigen/src/Core/arch/SSE/MathFunctions.h
M vendor/eigen/Eigen/src/Core/arch/SSE/PacketMath.h
A vendor/eigen/Eigen/src/Core/arch/SSE/TypeCasting.h
A vendor/eigen/Eigen/src/Core/arch/ZVector/Complex.h
A vendor/eigen/Eigen/src/Core/arch/ZVector/MathFunctions.h
A vendor/eigen/Eigen/src/Core/arch/ZVector/PacketMath.h
A vendor/eigen/Eigen/src/Core/functors/AssignmentFunctors.h
A vendor/eigen/Eigen/src/Core/functors/BinaryFunctors.h
A vendor/eigen/Eigen/src/Core/functors/NullaryFunctors.h
A vendor/eigen/Eigen/src/Core/functors/StlFunctors.h
A vendor/eigen/Eigen/src/Core/functors/TernaryFunctors.h
A vendor/eigen/Eigen/src/Core/functors/UnaryFunctors.h
M vendor/eigen/Eigen/src/Core/products/GeneralBlockPanelKernel.h
M vendor/eigen/Eigen/src/Core/products/GeneralMatrixMatrix.h
M vendor/eigen/Eigen/src/Core/products/GeneralMatrixMatrixTriangular.h
A vendor/eigen/Eigen/src/Core/products/GeneralMatrixMatrixTriangular_BLAS.h
A vendor/eigen/Eigen/src/Core/products/GeneralMatrixMatrix_BLAS.h
M vendor/eigen/Eigen/src/Core/products/GeneralMatrixVector.h
A vendor/eigen/Eigen/src/Core/products/GeneralMatrixVector_BLAS.h
M vendor/eigen/Eigen/src/Core/products/Parallelizer.h
M vendor/eigen/Eigen/src/Core/products/SelfadjointMatrixMatrix.h
A vendor/eigen/Eigen/src/Core/products/SelfadjointMatrixMatrix_BLAS.h
M vendor/eigen/Eigen/src/Core/products/SelfadjointMatrixVector.h
A vendor/eigen/Eigen/src/Core/products/SelfadjointMatrixVector_BLAS.h
M vendor/eigen/Eigen/src/Core/products/SelfadjointProduct.h
M vendor/eigen/Eigen/src/Core/products/SelfadjointRank2Update.h
M vendor/eigen/Eigen/src/Core/products/TriangularMatrixMatrix.h
A vendor/eigen/Eigen/src/Core/products/TriangularMatrixMatrix_BLAS.h
M vendor/eigen/Eigen/src/Core/products/TriangularMatrixVector.h
A vendor/eigen/Eigen/src/Core/products/TriangularMatrixVector_BLAS.h
M vendor/eigen/Eigen/src/Core/products/TriangularSolverMatrix.h
A vendor/eigen/Eigen/src/Core/products/TriangularSolverMatrix_BLAS.h
M vendor/eigen/Eigen/src/Core/products/TriangularSolverVector.h
M vendor/eigen/Eigen/src/Core/util/BlasUtil.h
M vendor/eigen/Eigen/src/Core/util/Constants.h
M vendor/eigen/Eigen/src/Core/util/DisableStupidWarnings.h
M vendor/eigen/Eigen/src/Core/util/ForwardDeclarations.h
M vendor/eigen/Eigen/src/Core/util/MKL_support.h
M vendor/eigen/Eigen/src/Core/util/Macros.h
M vendor/eigen/Eigen/src/Core/util/Memory.h
M vendor/eigen/Eigen/src/Core/util/Meta.h
M vendor/eigen/Eigen/src/Core/util/ReenableStupidWarnings.h
M vendor/eigen/Eigen/src/Core/util/StaticAssert.h
M vendor/eigen/Eigen/src/Core/util/XprHelper.h
M vendor/eigen/Eigen/src/Eigenvalues/ComplexEigenSolver.h
M vendor/eigen/Eigen/src/Eigenvalues/ComplexSchur.h
A vendor/eigen/Eigen/src/Eigenvalues/ComplexSchur_LAPACKE.h
M vendor/eigen/Eigen/src/Eigenvalues/EigenSolver.h
M vendor/eigen/Eigen/src/Eigenvalues/GeneralizedEigenSolver.h
M vendor/eigen/Eigen/src/Eigenvalues/GeneralizedSelfAdjointEigenSolver.h
M vendor/eigen/Eigen/src/Eigenvalues/HessenbergDecomposition.h
M vendor/eigen/Eigen/src/Eigenvalues/RealQZ.h
M vendor/eigen/Eigen/src/Eigenvalues/RealSchur.h
A vendor/eigen/Eigen/src/Eigenvalues/RealSchur_LAPACKE.h
M vendor/eigen/Eigen/src/Eigenvalues/SelfAdjointEigenSolver.h
A vendor/eigen/Eigen/src/Eigenvalues/SelfAdjointEigenSolver_LAPACKE.h
M vendor/eigen/Eigen/src/Eigenvalues/Tridiagonalization.h
M vendor/eigen/Eigen/src/Geometry/AlignedBox.h
M vendor/eigen/Eigen/src/Geometry/AngleAxis.h
M vendor/eigen/Eigen/src/Geometry/EulerAngles.h
M vendor/eigen/Eigen/src/Geometry/Homogeneous.h
M vendor/eigen/Eigen/src/Geometry/Hyperplane.h
M vendor/eigen/Eigen/src/Geometry/OrthoMethods.h
M vendor/eigen/Eigen/src/Geometry/ParametrizedLine.h
M vendor/eigen/Eigen/src/Geometry/Quaternion.h
M vendor/eigen/Eigen/src/Geometry/Rotation2D.h
M vendor/eigen/Eigen/src/Geometry/RotationBase.h
M vendor/eigen/Eigen/src/Geometry/Scaling.h
M vendor/eigen/Eigen/src/Geometry/Transform.h
M vendor/eigen/Eigen/src/Geometry/Translation.h
M vendor/eigen/Eigen/src/Geometry/Umeyama.h
M vendor/eigen/Eigen/src/Geometry/arch/Geometry_SSE.h
M vendor/eigen/Eigen/src/Householder/BlockHouseholder.h
M vendor/eigen/Eigen/src/Householder/Householder.h
M vendor/eigen/Eigen/src/Householder/HouseholderSequence.h
M vendor/eigen/Eigen/src/IterativeLinearSolvers/BasicPreconditioners.h
M vendor/eigen/Eigen/src/IterativeLinearSolvers/BiCGSTAB.h
M vendor/eigen/Eigen/src/IterativeLinearSolvers/ConjugateGradient.h
A vendor/eigen/Eigen/src/IterativeLinearSolvers/IncompleteCholesky.h
M vendor/eigen/Eigen/src/IterativeLinearSolvers/IncompleteLUT.h
M vendor/eigen/Eigen/src/IterativeLinearSolvers/IterativeSolverBase.h
A vendor/eigen/Eigen/src/IterativeLinearSolvers/LeastSquareConjugateGradient.h
A vendor/eigen/Eigen/src/IterativeLinearSolvers/SolveWithGuess.h
M vendor/eigen/Eigen/src/Jacobi/Jacobi.h
M vendor/eigen/Eigen/src/LU/Determinant.h
M vendor/eigen/Eigen/src/LU/FullPivLU.h
A vendor/eigen/Eigen/src/LU/InverseImpl.h
M vendor/eigen/Eigen/src/LU/PartialPivLU.h
A vendor/eigen/Eigen/src/LU/PartialPivLU_LAPACKE.h
M vendor/eigen/Eigen/src/LU/arch/Inverse_SSE.h
M vendor/eigen/Eigen/src/MetisSupport/MetisSupport.h
M vendor/eigen/Eigen/src/OrderingMethods/Amd.h
M vendor/eigen/Eigen/src/OrderingMethods/Eigen_Colamd.h
M vendor/eigen/Eigen/src/OrderingMethods/Ordering.h
M vendor/eigen/Eigen/src/PaStiXSupport/PaStiXSupport.h
M vendor/eigen/Eigen/src/PardisoSupport/PardisoSupport.h
M vendor/eigen/Eigen/src/QR/ColPivHouseholderQR.h
A vendor/eigen/Eigen/src/QR/ColPivHouseholderQR_LAPACKE.h
A vendor/eigen/Eigen/src/QR/CompleteOrthogonalDecomposition.h
M vendor/eigen/Eigen/src/QR/FullPivHouseholderQR.h
M vendor/eigen/Eigen/src/QR/HouseholderQR.h
A vendor/eigen/Eigen/src/QR/HouseholderQR_LAPACKE.h
M vendor/eigen/Eigen/src/SPQRSupport/SuiteSparseQRSupport.h
A vendor/eigen/Eigen/src/SVD/BDCSVD.h
M vendor/eigen/Eigen/src/SVD/JacobiSVD.h
A vendor/eigen/Eigen/src/SVD/JacobiSVD_LAPACKE.h
A vendor/eigen/Eigen/src/SVD/SVDBase.h
M vendor/eigen/Eigen/src/SVD/UpperBidiagonalization.h
M vendor/eigen/Eigen/src/SparseCholesky/SimplicialCholesky.h
M vendor/eigen/Eigen/src/SparseCholesky/SimplicialCholesky_impl.h
M vendor/eigen/Eigen/src/SparseCore/AmbiVector.h
M vendor/eigen/Eigen/src/SparseCore/CompressedStorage.h
M vendor/eigen/Eigen/src/SparseCore/ConservativeSparseSparseProduct.h
M vendor/eigen/Eigen/src/SparseCore/MappedSparseMatrix.h
A vendor/eigen/Eigen/src/SparseCore/SparseAssign.h
M vendor/eigen/Eigen/src/SparseCore/SparseBlock.h
M vendor/eigen/Eigen/src/SparseCore/SparseColEtree.h
A vendor/eigen/Eigen/src/SparseCore/SparseCompressedBase.h
M vendor/eigen/Eigen/src/SparseCore/SparseCwiseBinaryOp.h
M vendor/eigen/Eigen/src/SparseCore/SparseCwiseUnaryOp.h
M vendor/eigen/Eigen/src/SparseCore/SparseDenseProduct.h
M vendor/eigen/Eigen/src/SparseCore/SparseDiagonalProduct.h
M vendor/eigen/Eigen/src/SparseCore/SparseDot.h
M vendor/eigen/Eigen/src/SparseCore/SparseFuzzy.h
A vendor/eigen/Eigen/src/SparseCore/SparseMap.h
M vendor/eigen/Eigen/src/SparseCore/SparseMatrix.h
M vendor/eigen/Eigen/src/SparseCore/SparseMatrixBase.h
M vendor/eigen/Eigen/src/SparseCore/SparsePermutation.h
M vendor/eigen/Eigen/src/SparseCore/SparseProduct.h
M vendor/eigen/Eigen/src/SparseCore/SparseRedux.h
A vendor/eigen/Eigen/src/SparseCore/SparseRef.h
M vendor/eigen/Eigen/src/SparseCore/SparseSelfAdjointView.h
A vendor/eigen/Eigen/src/SparseCore/SparseSolverBase.h
M vendor/eigen/Eigen/src/SparseCore/SparseSparseProductWithPruning.h
M vendor/eigen/Eigen/src/SparseCore/SparseTranspose.h
M vendor/eigen/Eigen/src/SparseCore/SparseTriangularView.h
M vendor/eigen/Eigen/src/SparseCore/SparseUtil.h
M vendor/eigen/Eigen/src/SparseCore/SparseVector.h
M vendor/eigen/Eigen/src/SparseCore/SparseView.h
M vendor/eigen/Eigen/src/SparseCore/TriangularSolver.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU.h
M vendor/eigen/Eigen/src/SparseLU/SparseLUImpl.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_Memory.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_Structs.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_SupernodalMatrix.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_Utils.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_column_bmod.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_column_dfs.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_copy_to_ucol.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_gemm_kernel.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_heap_relax_snode.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_kernel_bmod.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_panel_bmod.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_panel_dfs.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_pivotL.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_pruneL.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_relax_snode.h
M vendor/eigen/Eigen/src/SparseQR/SparseQR.h
M vendor/eigen/Eigen/src/StlSupport/StdDeque.h
M vendor/eigen/Eigen/src/StlSupport/StdList.h
M vendor/eigen/Eigen/src/StlSupport/StdVector.h
M vendor/eigen/Eigen/src/StlSupport/details.h
M vendor/eigen/Eigen/src/SuperLUSupport/SuperLUSupport.h
M vendor/eigen/Eigen/src/UmfPackSupport/UmfPackSupport.h
M vendor/eigen/Eigen/src/misc/Image.h
M vendor/eigen/Eigen/src/misc/Kernel.h
A vendor/eigen/Eigen/src/misc/RealSvd2x2.h
M vendor/eigen/Eigen/src/misc/blas.h
A vendor/eigen/Eigen/src/misc/lapack.h
A vendor/eigen/Eigen/src/misc/lapacke.h
A vendor/eigen/Eigen/src/misc/lapacke_mangling.h
M vendor/eigen/Eigen/src/plugins/ArrayCwiseBinaryOps.h
M vendor/eigen/Eigen/src/plugins/ArrayCwiseUnaryOps.h
M vendor/eigen/Eigen/src/plugins/BlockMethods.h
M vendor/eigen/Eigen/src/plugins/CommonCwiseBinaryOps.h
M vendor/eigen/Eigen/src/plugins/CommonCwiseUnaryOps.h
M vendor/eigen/Eigen/src/plugins/MatrixCwiseBinaryOps.h
M vendor/eigen/Eigen/src/plugins/MatrixCwiseUnaryOps.h
Log Message:
Commit: c3f2a5c10d06d0c8d7b987c1cf93e03c90addd9d
https://github.com/PDAL/PDAL/commit/c3f2a5c10d06d0c8d7b987c1cf93e03c90addd9d
Changed paths:
M doc/stages/filters.assign.rst
M pdal/GDALUtils.hpp
M test/unit/filters/ColorinterpFilterTest.cpp
Log Message:
Commit: 336f2dda45746674cd18573c6f77c0e9f43e397d
https://github.com/PDAL/PDAL/commit/336f2dda45746674cd18573c6f77c0e9f43e397d
Date: 2017-10-02 (Mon, 02 Oct 2017)
Changed paths:
M java/core-scala/src/main/scala/io/pdal/pipeline/PipelineExpressions.scala
M java/core-scala/src/main/scala/io/pdal/pipeline/json/Implicits.scala
Log Message:
Commit: 4d5581ade019c509ecc9ccd7c641b79df6cd3edf
https://github.com/PDAL/PDAL/commit/4d5581ade019c509ecc9ccd7c641b79df6cd3edf
Date: 2017-10-04 (Wed, 04 Oct 2017)
Changed paths:
M pdal/Stage.cpp
M pdal/Stage.hpp
Log Message:
Set debug based on log level.
Commit: 2d464ffd640cbb339c48b189f46edf064ab266c4
https://github.com/PDAL/PDAL/commit/2d464ffd640cbb339c48b189f46edf064ab266c4
Changed paths:
M pdal/Stage.cpp
M pdal/Stage.hpp
Log Message:
Centralize logging changes.
Commit: 875673efddfe44e59957989599354235f1e1e40f
https://github.com/PDAL/PDAL/commit/875673efddfe44e59957989599354235f1e1e40f
Date: 2017-10-05 (Thu, 05 Oct 2017)
Changed paths:
Log Message:
Set failbit on bad DimRange parse.
Commit: 31ca4b9c97f5998368566c577373689a66662bb9
https://github.com/PDAL/PDAL/commit/31ca4b9c97f5998368566c577373689a66662bb9
Changed paths:
M filters/SampleFilter.cpp
M scripts/docker/master/alpine/Dockerfile
M scripts/docker/master/ubuntu/Dockerfile
Log Message:
Merge remote-tracking branch 'origin/master'
Commit: 1bc5058d45fe9f1af3d1f9560aa21223c383bb57
https://github.com/PDAL/PDAL/commit/1bc5058d45fe9f1af3d1f9560aa21223c383bb57
Changed paths:
M pdal/Stage.cpp
M pdal/Stage.hpp
Log Message:
Merge pull request #1698 from PDAL/logfix
Get stage debug information from log level
Commit: 8b220022bbf9007ef5c0b56feedddc75154fd4d7
https://github.com/PDAL/PDAL/commit/8b220022bbf9007ef5c0b56feedddc75154fd4d7
Changed paths:
M filters/CropFilter.cpp
Log Message:
Get absolute distance to minimize math.
Commit: feafb68c014b040564065d288b23deb4aacb470c
https://github.com/PDAL/PDAL/commit/feafb68c014b040564065d288b23deb4aacb470c
Author: Piero Toffanin <pt at masseranolabs.com>
Date: 2017-10-10 (Tue, 10 Oct 2017)
Changed paths:
M doc/stages/filters.smrf.rst
Log Message:
Updated smrf's out directory parameter reference (#1699)
Commit: 591f10500b8601f4f8589cb173a337cd0516ad3e
https://github.com/PDAL/PDAL/commit/591f10500b8601f4f8589cb173a337cd0516ad3e
Changed paths:
M CMakeLists.txt
M doc/stages/filters.ferry.rst
M filters/FerryFilter.cpp
M filters/FerryFilter.hpp
M io/LasReader.cpp
M io/LasReader.hpp
M io/LasWriter.cpp
M io/LasWriter.hpp
M pdal/Dimension.json
M pdal/Stage.cpp
M pdal/Stage.hpp
M plugins/nitf/io/NitfWriter.cpp
M test/unit/filters/FerryFilterTest.cpp
M test/unit/io/LasWriterTest.cpp
Log Message:
Commit: e2690685079583414938d5c802e9e8928b3db5a8
https://github.com/PDAL/PDAL/commit/e2690685079583414938d5c802e9e8928b3db5a8
Changed paths:
M cmake/examples/hobu-config.sh
M cmake/modules/FindMatlab.cmake
M plugins/matlab/filters/MatlabFilter.cpp
M plugins/matlab/filters/MatlabFilter.hpp
M plugins/matlab/filters/Script.cpp
M plugins/matlab/filters/Script.hpp
M plugins/matlab/io/MatlabWriter.cpp
M plugins/matlab/test/MatlabFilterTest.cpp
Log Message:
Fix #1689 and support PDAL.metadata.pdalargs option as per docs (#1700)
* metadata and srs support for Matlab stages
* support 2017b
* update for 2017b matlab
* pdalargs option placed on PDAL.metadata.pdalargs member
Commit: 976821dd5180d7ab471e3d4a8663147e42e5b9ff
https://github.com/PDAL/PDAL/commit/976821dd5180d7ab471e3d4a8663147e42e5b9ff
Changed paths:
Log Message:
Commit: 2c8c67d05bb3074fbc417961459870e67b595c85
https://github.com/PDAL/PDAL/commit/2c8c67d05bb3074fbc417961459870e67b595c85
Changed paths:
M scripts/docker/dependencies/Dockerfile
Log Message:
use LASzip 3.1.1 for pdal/dependencies docker image
Commit: 70c913c4514c9841d730c7bc0c030089bbbeec3f
https://github.com/PDAL/PDAL/commit/70c913c4514c9841d730c7bc0c030089bbbeec3f
Author: Connor Manning <connor at hobu.co>
Changed paths:
M plugins/greyhound/io/GreyhoundReader.cpp
Log Message:
Fix dimension-name lookup in GreyhoundReader to work for proprietary dims.
Commit: 6a875ca1f8fadef465128a741d98c2a3bdc31fbf
https://github.com/PDAL/PDAL/commit/6a875ca1f8fadef465128a741d98c2a3bdc31fbf
Changed paths:
M CMakeLists.txt
M doc/quickstart.rst
M python/VERSION.txt
M python/pdal/__init__.py
Log Message:
increment versions in preparation for 1.6.0 release
Commit: bf6516bc0bfd5ead90dae770c49eac628fe2f8af
https://github.com/PDAL/PDAL/commit/bf6516bc0bfd5ead90dae770c49eac628fe2f8af
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2017-10-11 (Wed, 11 Oct 2017)
Changed paths:
M doc/development/docker.rst
M doc/development/index.rst
A doc/development/liblas_to_pdal.rst
A doc/development/using.rst
A doc/development/writing-filter.rst
A doc/development/writing-kernel.rst
A doc/development/writing-reader.rst
A doc/development/writing-writer.rst
A doc/development/writing.rst
M doc/tutorial/index.rst
R doc/tutorial/liblas_to_pdal.rst
R doc/tutorial/using.rst
R doc/tutorial/writing-filter.rst
R doc/tutorial/writing-kernel.rst
R doc/tutorial/writing-reader.rst
R doc/tutorial/writing-writer.rst
R doc/tutorial/writing.rst
Log Message:
Move any docs related to writing code from tutorials to development
Commit: 21e66c2900f8dac32a0d2186e04cda8242c8d956
https://github.com/PDAL/PDAL/commit/21e66c2900f8dac32a0d2186e04cda8242c8d956
Changed paths:
M doc/api/index.rst
A doc/api/transition/index.rst
M doc/development/contributors.rst
R doc/development/liblas_to_pdal.rst
Log Message:
libLAS migration guide may be more applicable to API
(Also, RadiantBlue should now be DigitalGlobe.)
Commit: 92064bcfed4825befb3ee0462d1480d8da4f3c68
https://github.com/PDAL/PDAL/commit/92064bcfed4825befb3ee0462d1480d8da4f3c68
Changed paths:
R doc/tutorial/after-front1.png
R doc/tutorial/after-front2.png
R doc/tutorial/after-front3.png
R doc/tutorial/after-top1.png
R doc/tutorial/after-top2.png
R doc/tutorial/after-top3.png
R doc/tutorial/original.png
R doc/tutorial/pcl_ground.rst
A doc/tutorial/pcl_ground/after-front1.png
A doc/tutorial/pcl_ground/after-front2.png
A doc/tutorial/pcl_ground/after-front3.png
A doc/tutorial/pcl_ground/after-top1.png
A doc/tutorial/pcl_ground/after-top2.png
A doc/tutorial/pcl_ground/after-top3.png
A doc/tutorial/pcl_ground/index.rst
A doc/tutorial/pcl_ground/original.png
Log Message:
Group ground tutorial and all iamges in a folder
Commit: adf773b287e2825967222b33b1d279c49aa675b0
https://github.com/PDAL/PDAL/commit/adf773b287e2825967222b33b1d279c49aa675b0
Changed paths:
R doc/tutorial/autzen-elevation.png
R doc/tutorial/autzen-height.png
R doc/tutorial/calculating-normalized-heights.rst
A doc/tutorial/normalized_heights/autzen-elevation.png
A doc/tutorial/normalized_heights/autzen-height.png
A doc/tutorial/normalized_heights/index.rst
Log Message:
Group normalized heights files
Commit: a49b334435a987fbdf2645c34885102adc0b23da
https://github.com/PDAL/PDAL/commit/a49b334435a987fbdf2645c34885102adc0b23da
Changed paths:
R doc/tutorial/autzen-shapes-clipped.png
R doc/tutorial/autzen-shapes-point-cloud.png
R doc/tutorial/autzen-shapes-to-clip.png
R doc/tutorial/clipping-with-shapefile.rst
A doc/tutorial/clipping/autzen-shapes-clipped.png
A doc/tutorial/clipping/autzen-shapes-point-cloud.png
A doc/tutorial/clipping/autzen-shapes-to-clip.png
A doc/tutorial/clipping/index.rst
Log Message:
Group clipping files
Commit: 78a23b041fbc5959a93d9619c889e2d336ebb843
https://github.com/PDAL/PDAL/commit/78a23b041fbc5959a93d9619c889e2d336ebb843
Changed paths:
R doc/tutorial/dart-throwing.rst
A doc/tutorial/pcl_ground/sor_pmf.json
A doc/tutorial/pcl_ground/sor_pmf2.json
A doc/tutorial/sampling/index.rst
A doc/tutorial/sampling/subsample-ex1.png
A doc/tutorial/sampling/subsample-ex2.png
A doc/tutorial/sampling/subsample-ex3.png
A doc/tutorial/sampling/subsample-ex4.png
A doc/tutorial/sampling/subsample-ex5.png
R doc/tutorial/sor_pmf.json
R doc/tutorial/sor_pmf2.json
R doc/tutorial/subsample-ex1.png
R doc/tutorial/subsample-ex2.png
R doc/tutorial/subsample-ex3.png
R doc/tutorial/subsample-ex4.png
R doc/tutorial/subsample-ex5.png
Log Message:
Grouping sampling files (and missed ground pipelines)
Commit: 6e3ea295ca979e0789ae9383c9e635dce19c79df
https://github.com/PDAL/PDAL/commit/6e3ea295ca979e0789ae9383c9e635dce19c79df
Changed paths:
Log Message:
Clarify what the tutorials section is all about, and redirect other users via Note
Commit: 313ad9f5a6f5aed4318eabd245ae9f9f8b6e1117
https://github.com/PDAL/PDAL/commit/313ad9f5a6f5aed4318eabd245ae9f9f8b6e1117
Changed paths:
M doc/api/index.rst
Log Message:
Point users to other types of documentation depending on where they've landed
Commit: 7a96b08d65e3d70a4625c95cd80c490bb89c25d6
https://github.com/PDAL/PDAL/commit/7a96b08d65e3d70a4625c95cd80c490bb89c25d6
Changed paths:
M doc/development/integration.rst
Log Message:
Light formatting and eliminate pdal/dependencies from the Travis dicussion, instead citing Alpine
Commit: 084841660559a8fa12ce38634275d940c8c11bc6
https://github.com/PDAL/PDAL/commit/084841660559a8fa12ce38634275d940c8c11bc6
Changed paths:
M doc/stages/writers.ogr.rst
Log Message:
Fix typo in OGR writer docs
Commit: 942f24d4ee898d07e6df4009798f41d792e5974f
https://github.com/PDAL/PDAL/commit/942f24d4ee898d07e6df4009798f41d792e5974f
Changed paths:
A doc/development/normalized_heights/autzen-elevation.png
A doc/development/normalized_heights/autzen-height.png
A doc/development/normalized_heights/index.rst
R doc/tutorial/normalized_heights/autzen-elevation.png
R doc/tutorial/normalized_heights/autzen-height.png
R doc/tutorial/normalized_heights/index.rst
Log Message:
Normalized heights tutorial (as written anyway) is more of a development topic
Commit: 822176059feb09862f1d45b0f8c97267a0118a07
https://github.com/PDAL/PDAL/commit/822176059feb09862f1d45b0f8c97267a0118a07
Changed paths:
M doc/development/normalized_heights/index.rst
Log Message:
remove pcl note
Commit: 9a9ea02685c4f05fcd71c8937e2ba9768058936d
https://github.com/PDAL/PDAL/commit/9a9ea02685c4f05fcd71c8937e2ba9768058936d
Changed paths:
R doc/development/normalized_heights/autzen-elevation.png
R doc/development/normalized_heights/autzen-height.png
R doc/development/normalized_heights/index.rst
Log Message:
Convert back to tutorials, we'll just remove the coding part of it
Commit: d2ef4088b887acbe4895419498d58dd47a1e4207
https://github.com/PDAL/PDAL/commit/d2ef4088b887acbe4895419498d58dd47a1e4207
Changed paths:
M doc/tutorial/normalized_heights/index.rst
Log Message:
Refining the HAG text, but also thinking it could just be part of filters.hag stage documentation
Commit: 359a98f2a4b2255fb8c44227c191751d3c41cf60
https://github.com/PDAL/PDAL/commit/359a98f2a4b2255fb8c44227c191751d3c41cf60
Changed paths:
M doc/stages/filters.hag.rst
A doc/stages/images/autzen-elevation.png
A doc/stages/images/autzen-height.png
Log Message:
Move the HAG tutorial to the filters.hag stage docs
Commit: a4fe5b3e12e26ddc2476734ddda750a47c1b3078
https://github.com/PDAL/PDAL/commit/a4fe5b3e12e26ddc2476734ddda750a47c1b3078
Changed paths:
M doc/community.rst
M doc/download.rst
M doc/faq.rst
M doc/index.rst
M doc/pipeline.rst
M doc/stages/readers.rst
Log Message:
doc tweaks in preparation for 1.6
Commit: e7e608be3f98dfa6c977550b39a5ee76a2079316
https://github.com/PDAL/PDAL/commit/e7e608be3f98dfa6c977550b39a5ee76a2079316
Changed paths:
M .travis.yml
Log Message:
point to 1.6-maintenance branch for website publish
Commit: dbfd47a138f7ae8e6e68ea7e06a5c0e512511336
https://github.com/PDAL/PDAL/commit/dbfd47a138f7ae8e6e68ea7e06a5c0e512511336
Author: chambbj <brad.chambers at gmail.com>
Changed paths:
M doc/api/index.rst
Log Message:
Merge pull request #1702 from PDAL/1.6-docs-chambbj
Rearrange docs prior to 1.6 release
Commit: dde8261d86127ff0c0ffca864d6f0463d789f617
https://github.com/PDAL/PDAL/commit/dde8261d86127ff0c0ffca864d6f0463d789f617
Date: 2017-10-12 (Thu, 12 Oct 2017)
Changed paths:
M cmake/laszip.cmake
Log Message:
require LASzip 3.1.1+ for PDAL 1.6+
Commit: b99ab7f26222d331828aa38b082449869ed4968d
https://github.com/PDAL/PDAL/commit/b99ab7f26222d331828aa38b082449869ed4968d
Changed paths:
M ChangeLog
Log Message:
ChangeLog update
Commit: b90dd4833ff2c283c6b899060824b4ea9e48c3e8
https://github.com/PDAL/PDAL/commit/b90dd4833ff2c283c6b899060824b4ea9e48c3e8
Changed paths:
M RELEASENOTES.txt
A doc/development/release-notes/1.3.0.md
A doc/development/release-notes/1.4.0.md
A doc/development/release-notes/1.5.0.md
A doc/development/release-notes/1.6.0.md
Log Message:
release notes
Commit: b469ab7f14d57ac8b85ac2f54c271f1cdd4fbcb8
https://github.com/PDAL/PDAL/commit/b469ab7f14d57ac8b85ac2f54c271f1cdd4fbcb8
Changed paths:
M io/TextWriter.hpp
M test/unit/io/TextWriterTest.cpp
Log Message:
Simplify includes for TextWriter.
Commit: ac17d3dd8601cffd966c2faa8a04330520505191
https://github.com/PDAL/PDAL/commit/ac17d3dd8601cffd966c2faa8a04330520505191
Changed paths:
M .travis.yml
M CMakeLists.txt
M ChangeLog
M RELEASENOTES.txt
M doc/api/index.rst
M doc/community.rst
M doc/download.rst
M doc/faq.rst
M doc/index.rst
M doc/pipeline.rst
M pdal/Stage.cpp
M pdal/Stage.hpp
Log Message:
Commit: 7f35d09cbe39fd48bc4dce5862a9be0def3de4c3
https://github.com/PDAL/PDAL/commit/7f35d09cbe39fd48bc4dce5862a9be0def3de4c3
Date: 2017-10-13 (Fri, 13 Oct 2017)
Changed paths:
M scripts/docker/1.4-maintenance/alpine/Dockerfile
M scripts/docker/1.5-maintenance/alpine/Dockerfile
A scripts/docker/1.6-maintenance/alpine/Dockerfile
A scripts/docker/1.6-maintenance/ubuntu/Dockerfile
Log Message:
Base all Alpine Docker images on Alpine v3.6 instead of edge; add 1.6-maintenance images
Compare: https://github.com/PDAL/PDAL/compare/17f7f2e8a786...7f35d09cbe39
More information about the pdal-commits
