[pdal-commits] [PDAL/PDAL] 13bda8: Don't initialize srsmap with each reader. (#2015)
GitHub
noreply at github.com
Wed May 16 10:43:41 PDT 2018
Branch: refs/heads/issue-2018
Home: https://github.com/PDAL/PDAL
Commit: 13bda8182401b9af04162e34d59e03fb11635ece
https://github.com/PDAL/PDAL/commit/13bda8182401b9af04162e34d59e03fb11635ece
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2018-05-14 (Mon, 14 May 2018)
Changed paths:
M pdal/Streamable.cpp
M pdal/Streamable.hpp
M test/unit/StreamingTest.cpp
Log Message:
* Don't re-initialize SRS map when we move to new input.
* Add test for issue 2009.
Close #2009
Commit: 1929f959b423588bcf5698665461c1af1f0d9e63
https://github.com/PDAL/PDAL/commit/1929f959b423588bcf5698665461c1af1f0d9e63
Changed paths:
M test/data/las/utm17.las
Log Message:
Use utm17.las that doesn't have bad Geotiff data. (#2014)
Commit: 678c593f7883318dfdc840f79af294cda6c1a360
https://github.com/PDAL/PDAL/commit/678c593f7883318dfdc840f79af294cda6c1a360
Date: 2018-05-15 (Tue, 15 May 2018)
Changed paths:
M doc/stages/writers.pgpointcloud.rst
Log Message:
Add missing comma.
Commit: 44bdb552a94a1dc7b8b5ae5853f7669ed3aaffa9
https://github.com/PDAL/PDAL/commit/44bdb552a94a1dc7b8b5ae5853f7669ed3aaffa9
Date: 2018-05-16 (Wed, 16 May 2018)
Changed paths:
Log Message:
Merge remote-tracking branch 'origin/master' into issue-2018
Commit: 378b6bb8cdb69a9835eaa616a1cee09343d5516e
https://github.com/PDAL/PDAL/commit/378b6bb8cdb69a9835eaa616a1cee09343d5516e
Changed paths:
M cmake/unix_compiler_options.cmake
Log Message:
Don't remove paren option.
Compare: https://github.com/PDAL/PDAL/compare/801fccd2b40b...378b6bb8cdb6
**NOTE:** This service been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits
