[pdal-commits] [PDAL/PDAL] 13bda8: Don't initialize srsmap with each reader. (#2015)
GitHub
noreply at github.com
Mon May 21 10:49:28 PDT 2018
Branch: refs/heads/issue-2023
Home: https://github.com/PDAL/PDAL
Commit: 13bda8182401b9af04162e34d59e03fb11635ece
https://github.com/PDAL/PDAL/commit/13bda8182401b9af04162e34d59e03fb11635ece
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2018-05-14 (Mon, 14 May 2018)
Changed paths:
M pdal/Streamable.cpp
M pdal/Streamable.hpp
M test/unit/StreamingTest.cpp
Log Message:
* Don't re-initialize SRS map when we move to new input.
* Add test for issue 2009.
Close #2009
Commit: 1929f959b423588bcf5698665461c1af1f0d9e63
https://github.com/PDAL/PDAL/commit/1929f959b423588bcf5698665461c1af1f0d9e63
Changed paths:
M test/data/las/utm17.las
Log Message:
Use utm17.las that doesn't have bad Geotiff data. (#2014)
Commit: 678c593f7883318dfdc840f79af294cda6c1a360
https://github.com/PDAL/PDAL/commit/678c593f7883318dfdc840f79af294cda6c1a360
Date: 2018-05-15 (Tue, 15 May 2018)
Changed paths:
M doc/stages/writers.pgpointcloud.rst
Log Message:
Add missing comma.
Commit: ce7c1fd23a764fd51d19b9f8229676d64221cd19
https://github.com/PDAL/PDAL/commit/ce7c1fd23a764fd51d19b9f8229676d64221cd19
Author: Howard Butler <howard at hobu.co>
Date: 2018-05-18 (Fri, 18 May 2018)
Changed paths:
M doc/workshop/slides/source/introduction.rst
A doc/workshop/slides/source/rasterization.rst
M doc/workshop/slides/source/software.rst
Log Message:
update slides for foss4gna
Commit: d19bef44a199b1da113e20b35152feb6db9fcafa
https://github.com/PDAL/PDAL/commit/d19bef44a199b1da113e20b35152feb6db9fcafa
Changed paths:
A doc/workshop/Makefile
Log Message:
add workshop makefile
Commit: 8ff21eeea275e8c3810dd184b3fcff5d62e92471
https://github.com/PDAL/PDAL/commit/8ff21eeea275e8c3810dd184b3fcff5d62e92471
Changed paths:
M doc/workshop/conf.py
M doc/workshop/index.rst
Log Message:
update workshop date
Commit: 16d05071e8d615352183b6937f6fcb8c1d6c6fd0
https://github.com/PDAL/PDAL/commit/16d05071e8d615352183b6937f6fcb8c1d6c6fd0
Author: Bradley J Chambers <brad.chambers at gmail.com>
Changed paths:
M doc/download.rst
Log Message:
Merge download doc updates from 1.7-maintenance branch
Commit: 458aa4cbbefe39ca8c9435064b51b2e9eda73929
https://github.com/PDAL/PDAL/commit/458aa4cbbefe39ca8c9435064b51b2e9eda73929
Author: Landry Breuil <landryb at users.noreply.github.com>
Date: 2018-05-21 (Mon, 21 May 2018)
Changed paths:
M pdal/PluginDirectory.cpp
M plugins/sqlite/io/SQLiteCommon.hpp
M test/unit/PluginManagerTest.cpp
Log Message:
Simplify os-specific #ifdefs (#2027)
Instead of manually listing all non-macos unix platforms, make it the fallback
case, this way all BSDs are included.
Commit: b95f870abd960ccd50a360eac90230e400281e11
https://github.com/PDAL/PDAL/commit/b95f870abd960ccd50a360eac90230e400281e11
Changed paths:
M cmake/unix_compiler_options.cmake
M cmake/win32_compiler_options.cmake
M examples/writing-reader/MyReader.cpp
M filters/ClusterFilter.cpp
M filters/DecimationFilter.cpp
M filters/GreedyProjection.cpp
M filters/HeadFilter.hpp
M filters/LOFFilter.cpp
M filters/LocateFilter.cpp
M filters/MongusFilter.cpp
M filters/SMRFilter.cpp
M filters/TailFilter.hpp
M filters/private/DimRange.cpp
M filters/private/pnp/GridPnp.hpp
M io/BpfHeader.cpp
M io/BpfReader.cpp
M io/BpfWriter.cpp
M io/GDALGrid.cpp
M io/GDALReader.cpp
M io/HeaderVal.hpp
M io/LasHeader.cpp
M io/LasReader.cpp
M io/LasWriter.cpp
M io/LasWriter.hpp
M io/OptechReader.cpp
M io/PlyWriter.cpp
M io/QfitReader.cpp
M io/TerrasolidReader.cpp
M pdal/DimUtil.hpp
M pdal/EigenUtils.cpp
M pdal/KDIndex.hpp
M pdal/PDALUtils.cpp
M pdal/PointLayout.cpp
M pdal/QuadIndex.cpp
M pdal/Reader.cpp
M pdal/Scaling.cpp
M pdal/compression/LazPerfCompression.cpp
M pdal/compression/LazPerfVlrCompression.cpp
M pdal/compression/LzmaCompression.cpp
M pdal/util/Utils.cpp
M pdal/util/Utils.hpp
M plugins/delaunay/filters/Delaunay_psm.cpp
M plugins/delaunay/filters/Delaunay_psm.h
M plugins/greyhound/io/bounds.cpp
M plugins/greyhound/io/bounds.hpp
M plugins/greyhound/io/point.hpp
M plugins/icebridge/io/Hdf5Handler.cpp
M plugins/icebridge/io/IcebridgeReader.cpp
M plugins/mbio/io/MbReader.cpp
M plugins/mrsid/io/MrsidReader.cpp
M plugins/oci/test/OCITest.cpp
M plugins/pcl/pipeline/PCLPipeline.hpp
M plugins/rxp/io/RxpPointcloud.cpp
M plugins/rxp/test/RxpReaderTest.cpp
M plugins/sqlite/io/SQLiteReader.cpp
M test/unit/DeflateTest.cpp
M test/unit/LazPerfTest.cpp
M test/unit/LzmaTest.cpp
M test/unit/ZstdTest.cpp
M test/unit/io/LasWriterTest.cpp
M tools/lasdump/Lasdump.hpp
M tools/nitfwrap/NitfWrap.cpp
M vendor/arbiter/arbiter.cpp
M vendor/kazhdan/MAT.inl
M vendor/kazhdan/PoissonRecon.h
M vendor/kazhdan/point_source/PointSource.h
M vendor/nanoflann/nanoflann.hpp
Log Message:
Protect min/max against #define in Windows (#2022)
* Don't bleed PDAL options into other projects.
* Don't make libraries PDAL needs part of the external link interface.
* Link with util since we haven't installed.
* Remove stray paren.
* Work around Windows min/max mess.
* Parens...
* Parens...
* Parens.
* Add back variable so we don't require boost libraries.
* Remove much boost.
* Guard max for Windows.
* More min/max guard.
* Paren-ify max/min for Windows so as not to bleed into people's code that
uses ours.
* More fixes.
* A couple more...
* Paren-ize max() in MAT.inl.
* And more...
* Laz-perf may not be "minmax" safe.
* More
* min/max guard
* Don't remove paren option.
* A few items caught on review.
Commit: d44eb0adf9524477cca8a3833b91e07edb1abba7
https://github.com/PDAL/PDAL/commit/d44eb0adf9524477cca8a3833b91e07edb1abba7
Author: John Wass <jwass3 at gmail.com>
Changed paths:
M pdal/ArtifactManager.hpp
M test/unit/ArtifactTest.cpp
Log Message:
access artifact manager keys (#2030)
Commit: 4e7fe68b05a3195f5529af43752e8ff580073394
https://github.com/PDAL/PDAL/commit/4e7fe68b05a3195f5529af43752e8ff580073394
Changed paths:
Log Message:
Fix test comparison types.
Formatting fix.
Commit: fbd7df19225ce44866ea6a04ace0b0ac5e25312b
https://github.com/PDAL/PDAL/commit/fbd7df19225ce44866ea6a04ace0b0ac5e25312b
Changed paths:
M doc/download.rst
M io/BpfHeader.cpp
M io/BpfReader.cpp
M io/BpfWriter.cpp
M io/GDALGrid.cpp
M io/GDALReader.cpp
M io/HeaderVal.hpp
M io/LasHeader.cpp
M io/LasReader.cpp
M io/LasWriter.cpp
M io/LasWriter.hpp
M io/PlyWriter.cpp
M io/QfitReader.cpp
M pdal/DimUtil.hpp
M pdal/KDIndex.hpp
M pdal/Reader.cpp
M pdal/Scaling.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into issue-2023
Compare: https://github.com/PDAL/PDAL/compare/662af9a214ba...fbd7df19225c
**NOTE:** This service been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits
