[pdal-commits] [PDAL/PDAL] 396aca: Eliminate need to specify bounds on writers.gdal (...
GitHub noreply at github.com
Mon Sep 24 11:47:14 PDT 2018
  Branch: refs/heads/readers.gdal-quickinfo-bounds
  Home:   https://github.com/PDAL/PDAL
  Commit: 396aca0e6cb820422eade74cc67f8c6ec6d9f200
      https://github.com/PDAL/PDAL/commit/396aca0e6cb820422eade74cc67f8c6ec6d9f200
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2018-09-24 (Mon, 24 Sep 2018)
  Changed paths:
    M io/GDALGrid.cpp
    M io/GDALWriter.cpp
    M io/GDALWriter.hpp
    M pdal/util/Bounds.cpp
    M pdal/util/Bounds.hpp
    M test/unit/io/GDALWriterTest.cpp
  Log Message:
  Eliminate need to specify bounds on writers.gdal (#2168)
* Fix calculation of verticalIndex().
* Export GDAL Grid for testing.
* Radius expansion for grid.  Tests broken.
* Remove radius adjustment.
* Add header.
* Remove unnecessary header.
* Put back assert.h.
  Commit: d472dade2b7ef1e291a60a9375f96cc4532ab6cb
      https://github.com/PDAL/PDAL/commit/d472dade2b7ef1e291a60a9375f96cc4532ab6cb
  Changed paths:
    M filters/PMFFilter.cpp
    M filters/RangeFilter.cpp
    M filters/RangeFilter.hpp
    M filters/SMRFilter.cpp
    M filters/private/DimRange.cpp
    M filters/private/DimRange.hpp
    M filters/private/Segmentation.cpp
    M filters/private/Segmentation.hpp
  Log Message:
  Multiple range support for ignore option on smrt and pmf (#2167)
* Use range list for ignore option on filters.smrf.
Close #2157
* Use DimRange code to handle point filtering.
* Add comment and remove unnecessary assignment.
* Replace inline range filter DimRange testing.
Close #2157
  Commit: be97bdb5837a3b524adf5c4dcca6b56e4c68ef24
      https://github.com/PDAL/PDAL/commit/be97bdb5837a3b524adf5c4dcca6b56e4c68ef24
  Changed paths:
    M plugins/mbio/io/MbReader.cpp
    M plugins/mbio/io/MbReader.hpp
  Log Message:
  Improvements to readers.mbio (#2166)
* Allow extraction of sidescan data.
* Add support for individual dimension precisions.
Close #1869
* Set proper dimensions based on datatype option.
* Add time support for mbio.
  Commit: e01aad69730692747e031418fe88bcc142b51f26
      https://github.com/PDAL/PDAL/commit/e01aad69730692747e031418fe88bcc142b51f26
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M io/GDALReader.cpp
    M pdal/GDALUtils.hpp
  Log Message:
  refactor to return a BOX2D or a BOX3D if given a bandID
  Commit: 87338399a9995311c1a675b6d7843195b89e3cbf
      https://github.com/PDAL/PDAL/commit/87338399a9995311c1a675b6d7843195b89e3cbf
  Changed paths:
    M doc/stages/readers.gdal.rst
    M io/GDALReader.cpp
    M io/GDALReader.hpp
  Log Message:
  add 'header' option to readers.gdal to allow mapping of band->dimension
  Commit: 19a711af16a10b5aa8dcd7a00733a142efe43491
      https://github.com/PDAL/PDAL/commit/19a711af16a10b5aa8dcd7a00733a142efe43491
  Changed paths:
    M test/unit/io/GDALReaderTest.cpp
  Log Message:
  test 'header' option
  Commit: 1c43d3d98175f5e46370304e8f1978d74692636f
      https://github.com/PDAL/PDAL/commit/1c43d3d98175f5e46370304e8f1978d74692636f
  Changed paths:
    M io/GDALGrid.cpp
    M io/GDALWriter.cpp
    M io/GDALWriter.hpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into readers.gdal-quickinfo-bounds
Compare: https://github.com/PDAL/PDAL/compare/a7a0c6aa1c51...1c43d3d98175
      **NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
      Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits mailing list
