[pdal-commits] [PDAL/PDAL] 396aca: Eliminate need to specify bounds on writers.gdal (...
GitHub
noreply at github.com
Wed Sep 26 08:38:49 PDT 2018
Branch: refs/heads/i3s
Home: https://github.com/PDAL/PDAL
Commit: 396aca0e6cb820422eade74cc67f8c6ec6d9f200
https://github.com/PDAL/PDAL/commit/396aca0e6cb820422eade74cc67f8c6ec6d9f200
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2018-09-24 (Mon, 24 Sep 2018)
Changed paths:
M io/GDALGrid.cpp
M io/GDALWriter.cpp
M io/GDALWriter.hpp
M pdal/util/Bounds.cpp
M pdal/util/Bounds.hpp
M test/unit/io/GDALWriterTest.cpp
Log Message:
Eliminate need to specify bounds on writers.gdal (#2168)
* Fix calculation of verticalIndex().
* Export GDAL Grid for testing.
* Radius expansion for grid. Tests broken.
* Remove radius adjustment.
* Add header.
* Remove unnecessary header.
* Put back assert.h.
Commit: d472dade2b7ef1e291a60a9375f96cc4532ab6cb
https://github.com/PDAL/PDAL/commit/d472dade2b7ef1e291a60a9375f96cc4532ab6cb
Changed paths:
M filters/PMFFilter.cpp
M filters/RangeFilter.cpp
M filters/RangeFilter.hpp
M filters/SMRFilter.cpp
M filters/private/DimRange.cpp
M filters/private/DimRange.hpp
M filters/private/Segmentation.cpp
M filters/private/Segmentation.hpp
Log Message:
Multiple range support for ignore option on smrt and pmf (#2167)
* Use range list for ignore option on filters.smrf.
Close #2157
* Use DimRange code to handle point filtering.
* Add comment and remove unnecessary assignment.
* Replace inline range filter DimRange testing.
Close #2157
Commit: be97bdb5837a3b524adf5c4dcca6b56e4c68ef24
https://github.com/PDAL/PDAL/commit/be97bdb5837a3b524adf5c4dcca6b56e4c68ef24
Changed paths:
M plugins/mbio/io/MbReader.cpp
M plugins/mbio/io/MbReader.hpp
Log Message:
Improvements to readers.mbio (#2166)
* Allow extraction of sidescan data.
* Add support for individual dimension precisions.
Close #1869
* Set proper dimensions based on datatype option.
* Add time support for mbio.
Commit: 758b6255cdc479ec8dfb7523e4e16622bf134ca1
https://github.com/PDAL/PDAL/commit/758b6255cdc479ec8dfb7523e4e16622bf134ca1
Author: Howard Butler <howard at hobu.co>
Changed paths:
M doc/stages/readers.gdal.rst
M io/GDALReader.cpp
M io/GDALReader.hpp
M pdal/GDALUtils.hpp
M test/unit/io/GDALReaderTest.cpp
Log Message:
support fetching bounds information for readers.gdal QuickInfo (#2177)
* support fetching bounds information for readers.gdal QuickInfo
* rearrange into Raster::bounds method
* refactor to return a BOX2D or a BOX3D if given a bandID
* add 'header' option to readers.gdal to allow mapping of band->dimension
* test 'header' option
Commit: d0f7d0646c04baf68249a2ba60dc51971f21c97b
https://github.com/PDAL/PDAL/commit/d0f7d0646c04baf68249a2ba60dc51971f21c97b
Changed paths:
M io/GDALReader.cpp
Log Message:
clean up readers.gdal header setting loop
Commit: 9c5e9da5e06db1a0c51573fe5efb9a5a13b80164
https://github.com/PDAL/PDAL/commit/9c5e9da5e06db1a0c51573fe5efb9a5a13b80164
Date: 2018-09-25 (Tue, 25 Sep 2018)
Changed paths:
M plugins/fbx/io/FbxWriter.cpp
Log Message:
Diagnostic fixes for new clang compiler.
Commit: c29473f4aee767fa1059f8d98df3c4e8f3ac2fe9
https://github.com/PDAL/PDAL/commit/c29473f4aee767fa1059f8d98df3c4e8f3ac2fe9
Author: Connor Manning <connor at hobu.co>
Changed paths:
M pdal/SpatialReference.cpp
M pdal/SpatialReference.hpp
M test/unit/SpatialReferenceTest.cpp
Log Message:
Add auto-identify horizontal/vertical EPSG methods to SpatialReference. (#2180)
Commit: b214f4eb6f6a8f2345fe93971d87dd592b8c3c3f
https://github.com/PDAL/PDAL/commit/b214f4eb6f6a8f2345fe93971d87dd592b8c3c3f
Date: 2018-09-26 (Wed, 26 Sep 2018)
Changed paths:
M cmake/examples/hobu-config.sh
M plugins/i3s/CMakeLists.txt
A plugins/i3s/test/SlpkReaderTest.cpp
M plugins/i3s/test/i3sReaderTest.cpp
Log Message:
make I3S tests an optional build/run -- the SLPK reader tests the basic software, and the I3S does remote-over-the-internet requests which take about 60s. to run
Commit: fd23b00028a9b88356cdbb4769b5451dfc413fe6
https://github.com/PDAL/PDAL/commit/fd23b00028a9b88356cdbb4769b5451dfc413fe6
Changed paths:
M io/GDALGrid.cpp
M io/GDALReader.cpp
M io/GDALReader.hpp
M io/GDALWriter.cpp
M io/GDALWriter.hpp
Log Message:
Merge remote-tracking branch 'origin/master' into i3s
Compare: https://github.com/PDAL/PDAL/compare/a7e0b228c3d0...fd23b00028a9
**NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits
