[pdal-commits] [PDAL/PDAL] 8129c3: Add 2-pass check for streamable pipelines (#2655)
Andrew Bell
noreply at github.com
Fri Aug 9 14:12:57 PDT 2019
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 8129c3c97615323fe6e90ce9875d19c598cb8c6b
https://github.com/PDAL/PDAL/commit/8129c3c97615323fe6e90ce9875d19c598cb8c6b
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2019-08-09 (Fri, 09 Aug 2019)
Changed paths:
M doc/apps/pipeline.rst
M doc/apps/translate.rst
M kernels/InfoKernel.cpp
M kernels/PipelineKernel.cpp
M kernels/PipelineKernel.hpp
M kernels/TranslateKernel.cpp
M kernels/TranslateKernel.hpp
M pdal/PipelineManager.cpp
M pdal/PipelineManager.hpp
M pdal/pdal_types.hpp
A test/data/pipeline/colorinterp.json.in
M test/unit/apps/pcpipelineTestJSON.cpp
Log Message:
* Add 2-pass check for streamable pipelines.
* If we're adding an interface, it needs to be better than the
last attempt.
* Add test for colorinterp with min/max.
* Change handling of stream option to ONLY run streaming for translate
and pipeline.
* Add doc and error support.
More information about the pdal-commits
