[pdal-commits] [PDAL/PDAL] 8129c3: Add 2-pass check for streamable pipelines (#2655)
Andrew Bell
noreply at github.com
Wed Aug 21 11:31:23 PDT 2019
Branch: refs/heads/issue-2663
Home: https://github.com/PDAL/PDAL
Commit: 8129c3c97615323fe6e90ce9875d19c598cb8c6b
https://github.com/PDAL/PDAL/commit/8129c3c97615323fe6e90ce9875d19c598cb8c6b
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2019-08-09 (Fri, 09 Aug 2019)
Changed paths:
M doc/apps/pipeline.rst
M doc/apps/translate.rst
M kernels/InfoKernel.cpp
M kernels/PipelineKernel.cpp
M kernels/PipelineKernel.hpp
M kernels/TranslateKernel.cpp
M kernels/TranslateKernel.hpp
M pdal/PipelineManager.cpp
M pdal/PipelineManager.hpp
M pdal/pdal_types.hpp
A test/data/pipeline/colorinterp.json.in
M test/unit/apps/pcpipelineTestJSON.cpp
Log Message:
* Add 2-pass check for streamable pipelines.
* If we're adding an interface, it needs to be better than the
last attempt.
* Add test for colorinterp with min/max.
* Change handling of stream option to ONLY run streaming for translate
and pipeline.
* Add doc and error support.
Commit: 17961b70c644155bcd275ccfbda251285dd88c41
https://github.com/PDAL/PDAL/commit/17961b70c644155bcd275ccfbda251285dd88c41
Author: Nicolas Chaulet <nicolas.chaulet at gmail.com>
Date: 2019-08-12 (Mon, 12 Aug 2019)
Changed paths:
M doc/stages/filters.assign.rst
Log Message:
Assign is streamable (#2666)
Commit: 0c9c24605ec3a57863c8d7bafc9903d170160507
https://github.com/PDAL/PDAL/commit/0c9c24605ec3a57863c8d7bafc9903d170160507
Changed paths:
M dimbuilder/DimBuilder.cpp
M pdal/Dimension.json
Log Message:
Add alternate names for R/G/B/Normals for PLY. (#2665)
Commit: 93f928658c6483787caa854c2f10d4099c263ac7
https://github.com/PDAL/PDAL/commit/93f928658c6483787caa854c2f10d4099c263ac7
Date: 2019-08-13 (Tue, 13 Aug 2019)
Changed paths:
M filters/StatsFilter.cpp
Log Message:
Don't parse JSON for no reason.
Commit: 6dbcd6ea89712e37a4581942c17f94d1b826c79a
https://github.com/PDAL/PDAL/commit/6dbcd6ea89712e37a4581942c17f94d1b826c79a
Changed paths:
M pdal/StageExtensions.cpp
Log Message:
Remove unnecessary JSON.
Commit: 7d9f3b25c493b2a8a9efdd9470e8eea097e4ea06
https://github.com/PDAL/PDAL/commit/7d9f3b25c493b2a8a9efdd9470e8eea097e4ea06
Date: 2019-08-15 (Thu, 15 Aug 2019)
Changed paths:
M filters/ColorinterpFilter.cpp
M filters/ColorinterpFilter.hpp
M filters/ColorizationFilter.cpp
M filters/ColorizationFilter.hpp
M filters/CropFilter.cpp
M filters/DEMFilter.cpp
M filters/DEMFilter.hpp
M filters/OverlayFilter.cpp
M io/GDALReader.cpp
M io/GDALReader.hpp
M io/Ilvis2MetadataReader.cpp
M io/OGRWriter.cpp
M io/OGRWriter.hpp
R io/OGRWriterV1.cpp
M io/TIndexReader.hpp
M kernels/DensityKernel.cpp
M kernels/TIndexKernel.cpp
M kernels/TIndexKernel.hpp
M kernels/private/density/OGR.cpp
M pdal/GDALUtils.cpp
M pdal/GDALUtils.hpp
M pdal/Geometry.cpp
M pdal/Geometry.hpp
M pdal/Polygon.cpp
M plugins/oci/io/OciWriter.cpp
M plugins/oci/io/OciWriter.hpp
Log Message:
Remove GDAL 2.1 cruft. (#2672)
Don't include GDALUtils in headers.
Commit: b65725eb7ecae77562f284f8f1e53f031389f370
https://github.com/PDAL/PDAL/commit/b65725eb7ecae77562f284f8f1e53f031389f370
Changed paths:
M io/EptReader.cpp
M io/EptReader.hpp
M plugins/python/filters/PythonFilter.cpp
M plugins/python/filters/PythonFilter.hpp
M test/unit/io/EptReaderTest.cpp
Log Message:
Don't stick json.cpp in public headers.
Commit: c26b03645d556c7352cc56cd33dae5129acb0a5f
https://github.com/PDAL/PDAL/commit/c26b03645d556c7352cc56cd33dae5129acb0a5f
Author: Howard Butler <howard at hobu.co>
Date: 2019-08-19 (Mon, 19 Aug 2019)
Changed paths:
M doc/stages/readers.ept.rst
M io/EptReader.cpp
M io/EptReader.hpp
M pdal/Geometry.cpp
M pdal/Polygon.cpp
M pdal/Polygon.hpp
M test/data/autzen/autzen-selection.json
A test/data/ept/1.2-with-color/ept-build.json
A test/data/ept/1.2-with-color/ept-data/0-0-0-0.laz
A test/data/ept/1.2-with-color/ept-hierarchy/0-0-0-0.json
A test/data/ept/1.2-with-color/ept-sources/0.json
A test/data/ept/1.2-with-color/ept-sources/list.json
A test/data/ept/1.2-with-color/ept.json
M test/unit/CMakeLists.txt
M test/unit/PolygonTest.cpp
Log Message:
support 'polygon' query limiter, which smartly limits fetches based on box intersections of the polygon(s) given (#2667)
* support 'polygon' query limiter, which smartly limits fetches based on box intersections of the polygon(s) given
* update ept doc
* need to link GDAL for Ept for polygon clipping
* support polygon cropping in readers.ept
* fill out D9IM for #2670
* test 'polygon' option for EPT reader
* use disjoint instead of intersects for testing bbox - polygon interaction
* attempt to support reprojected input polys -- WIP
* Support SRS at the end of geometry specifications.
* Remove dead code.
* Finish getting tests working for EPT polygon clipping.
* Add check in case SRS was included with new geometry.
Commit: 5b553e8a70522bb332aefc9dbb3d19c091ae38aa
https://github.com/PDAL/PDAL/commit/5b553e8a70522bb332aefc9dbb3d19c091ae38aa
Changed paths:
Log Message:
createFromGeoJson is pdal::oldgdalsupport::createFromGeoJson(char**)
Commit: 47ab8e9e89e14e95e1b77c74814f1f9aabd7dcf9
https://github.com/PDAL/PDAL/commit/47ab8e9e89e14e95e1b77c74814f1f9aabd7dcf9
Changed paths:
Log Message:
cast to const for oldgdalsupport::createFromGeoJson
Commit: 8960ae22145fa0c80ab34fae2d4f403e51441a5c
https://github.com/PDAL/PDAL/commit/8960ae22145fa0c80ab34fae2d4f403e51441a5c
Changed paths:
A scripts/proj-datumshift
Log Message:
Eliminate warning by changing tab to spaces.
Add script to fetch PROJ datum shift files.
Commit: 5855c6a933192d5b22cb766cb6a99385a764b433
https://github.com/PDAL/PDAL/commit/5855c6a933192d5b22cb766cb6a99385a764b433
Changed paths:
Log Message:
Merge remote-tracking branch 'origin/master'
Commit: 16e5d5a3e93e3b14ad85b3a91023ae33b780c85e
https://github.com/PDAL/PDAL/commit/16e5d5a3e93e3b14ad85b3a91023ae33b780c85e
Changed paths:
Log Message:
const char** for oldgdalsupport
Commit: bfe287a4269f5270fed928cd07f89d1b9aee52b7
https://github.com/PDAL/PDAL/commit/bfe287a4269f5270fed928cd07f89d1b9aee52b7
Changed paths:
Log Message:
Merge branch 'master' of github.com:PDAL/PDAL
Commit: 08dbe5d5a22e1bc697e874dae52b56964bb5789c
https://github.com/PDAL/PDAL/commit/08dbe5d5a22e1bc697e874dae52b56964bb5789c
Changed paths:
M test/data/filters/ferry.json.in
Log Message:
Don't do tricky proj stuff that might not work.
Commit: 5e820868fafc5df19da07a724d053f6d33bb16b0
https://github.com/PDAL/PDAL/commit/5e820868fafc5df19da07a724d053f6d33bb16b0
Changed paths:
Log Message:
Commit: f855b62d9acb744f650923f450c885bfe3689d9a
https://github.com/PDAL/PDAL/commit/f855b62d9acb744f650923f450c885bfe3689d9a
Changed paths:
M io/EptReader.cpp
M io/EptReader.hpp
M io/GDALReader.cpp
M io/GDALReader.hpp
M io/OGRWriter.cpp
M io/OGRWriter.hpp
M pdal/Geometry.cpp
M pdal/Geometry.hpp
M pdal/Polygon.cpp
M pdal/Polygon.hpp
Log Message:
Merge remote-tracking branch 'origin/master' into issue-2663
Commit: d156dbfe2cfa9d7ae4facc87f3f4b13fd09a4b44
https://github.com/PDAL/PDAL/commit/d156dbfe2cfa9d7ae4facc87f3f4b13fd09a4b44
Date: 2019-08-20 (Tue, 20 Aug 2019)
Changed paths:
Log Message:
Don't build Ept tests if we don't have laszip. (#2678)
Commit: e20b41ab42a5b53e3a43407cc27e2408574fdcec
https://github.com/PDAL/PDAL/commit/e20b41ab42a5b53e3a43407cc27e2408574fdcec
Changed paths:
M test/unit/io/PcdReaderTest.cpp
M test/unit/io/PcdWriterTest.cpp
Log Message:
Fix type comparisons for PCD tests.
Commit: bf5d5dfbf06f0a53f6a7185add83120f851dfe0a
https://github.com/PDAL/PDAL/commit/bf5d5dfbf06f0a53f6a7185add83120f851dfe0a
Changed paths:
Log Message:
Commit: 71699b43de91bbd302f1d56d390572bdef498c76
https://github.com/PDAL/PDAL/commit/71699b43de91bbd302f1d56d390572bdef498c76
Changed paths:
Log Message:
try again on oldgdalsupport::createFromGeoJson call
Commit: fdc4a0c78774d86d41d0487df532716011f7e005
https://github.com/PDAL/PDAL/commit/fdc4a0c78774d86d41d0487df532716011f7e005
Changed paths:
M vendor/kazhdan/PoissonRecon.h
Log Message:
Eliminate profiling output.
Commit: 1f6f5a7b1b0c9cdba8ad6c5b5d00e08e7440643d
https://github.com/PDAL/PDAL/commit/1f6f5a7b1b0c9cdba8ad6c5b5d00e08e7440643d
Changed paths:
Log Message:
Merge remote-tracking branch 'origin/issue-2682'
Commit: 4b21da137fbd6ec66698b503f2f884f68900dcd9
https://github.com/PDAL/PDAL/commit/4b21da137fbd6ec66698b503f2f884f68900dcd9
Author: Adam Steer <adamsteer at users.noreply.github.com>
Date: 2019-08-21 (Wed, 21 Aug 2019)
Changed paths:
M doc/development/compilation/dependencies.rst
M doc/workshop/agenda.rst
M doc/workshop/capstone.rst
A doc/workshop/conda.rst
M doc/workshop/conf.py
M doc/workshop/exercises/analysis/boundary/boundary-command-boundary.txt
A doc/workshop/exercises/analysis/boundary/boundary-command-tindex-win.txt
M doc/workshop/exercises/analysis/boundary/boundary-command-tindex.txt
M doc/workshop/exercises/analysis/boundary/boundary.rst
M doc/workshop/exercises/analysis/clipping/attributes.vrt
M doc/workshop/exercises/analysis/clipping/clipping-run-command.txt
M doc/workshop/exercises/analysis/clipping/clipping.json
M doc/workshop/exercises/analysis/clipping/clipping.rst
M doc/workshop/exercises/analysis/colorization/colorization-run-command.txt
M doc/workshop/exercises/analysis/colorization/colorization.rst
M doc/workshop/exercises/analysis/colorization/colorize.json
M doc/workshop/exercises/analysis/denoising/denoise.json
R doc/workshop/exercises/analysis/denoising/denoising-docker-machine-create.txt
R doc/workshop/exercises/analysis/denoising/denoising-docker-machine-delete.txt
M doc/workshop/exercises/analysis/denoising/denoising-run-command.txt
M doc/workshop/exercises/analysis/denoising/denoising.rst
A doc/workshop/exercises/analysis/density/density-command-win.txt
M doc/workshop/exercises/analysis/density/density-command.txt
M doc/workshop/exercises/analysis/density/density.rst
A doc/workshop/exercises/analysis/dtm/dtm-hillshade-command-win.txt
M doc/workshop/exercises/analysis/dtm/dtm-hillshade-command.txt
M doc/workshop/exercises/analysis/dtm/dtm-run-command.txt
M doc/workshop/exercises/analysis/dtm/dtm.rst
M doc/workshop/exercises/analysis/dtm/gdal.json
A doc/workshop/exercises/analysis/ground/ground-run-ground-only-win.txt
M doc/workshop/exercises/analysis/ground/ground-run-ground-only.txt
A doc/workshop/exercises/analysis/ground/ground-run-no-filter-win.txt
M doc/workshop/exercises/analysis/ground/ground-run-no-filter.txt
M doc/workshop/exercises/analysis/ground/ground.rst
A doc/workshop/exercises/analysis/ground/translate-run-ground-only-win.txt
M doc/workshop/exercises/analysis/ground/translate-run-ground-only.txt
A doc/workshop/exercises/analysis/meshing/meshing-buildings-win.txt
A doc/workshop/exercises/analysis/meshing/meshing-buildings.txt
A doc/workshop/exercises/analysis/meshing/meshing-terrain.txt
A doc/workshop/exercises/analysis/meshing/meshing-win.txt
A doc/workshop/exercises/analysis/meshing/meshing.rst
A doc/workshop/exercises/analysis/meshing/meshing.txt
M doc/workshop/exercises/analysis/rasterize/classification.json
M doc/workshop/exercises/analysis/rasterize/classify-command.txt
M doc/workshop/exercises/analysis/rasterize/gdaldem-run-command.txt
A doc/workshop/exercises/analysis/rasterize/intensity-run-command-win.txt
M doc/workshop/exercises/analysis/rasterize/intensity-run-command.txt
M doc/workshop/exercises/analysis/rasterize/ramp.txt
M doc/workshop/exercises/analysis/rasterize/rasterize-run-command.txt
M doc/workshop/exercises/analysis/rasterize/rasterize.rst
A doc/workshop/exercises/analysis/thinning/thinning-run-dartsample-win.txt
M doc/workshop/exercises/analysis/thinning/thinning-run-dartsample.txt
M doc/workshop/exercises/analysis/thinning/thinning.rst
A doc/workshop/exercises/batch_processing/batch-dtm-bash.txt
A doc/workshop/exercises/batch_processing/batch-dtm-powershell.txt
A doc/workshop/exercises/batch_processing/batch-processing.rst
R doc/workshop/exercises/batch_processing/batch-processing.rst.save
R doc/workshop/exercises/batch_processing/batch_dtm-powershell.txt
M doc/workshop/exercises/batch_processing/batch_srs_gdal.json
A doc/workshop/exercises/georeferencing/georeferencing-command-win.txt
M doc/workshop/exercises/georeferencing/georeferencing-command.txt
M doc/workshop/exercises/georeferencing/index.rst
M doc/workshop/exercises/index.rst
A doc/workshop/exercises/info/metadata-command-jq-win.txt
M doc/workshop/exercises/info/metadata-command-jq.txt
M doc/workshop/exercises/info/metadata-command.txt
M doc/workshop/exercises/info/metadata.rst
M doc/workshop/exercises/info/near-command-1.txt
M doc/workshop/exercises/info/near-command-2.txt
M doc/workshop/exercises/info/single-point-command.txt
M doc/workshop/exercises/info/single-point.rst
M doc/workshop/exercises/python/histogram-command.txt
M doc/workshop/exercises/python/histogram.json
M doc/workshop/exercises/python/histogram.py
M doc/workshop/exercises/python/histogram.rst
A doc/workshop/exercises/translation/compression-command-verify-win.txt
M doc/workshop/exercises/translation/compression-command-verify.txt
A doc/workshop/exercises/translation/compression-command-win.txt
M doc/workshop/exercises/translation/compression-command.txt
M doc/workshop/exercises/translation/compression.rst
A doc/workshop/exercises/translation/entwine-build-command.txt
A doc/workshop/exercises/translation/entwine-cd-command.txt
A doc/workshop/exercises/translation/entwine-command.txt
A doc/workshop/exercises/translation/entwine-info-command.txt
A doc/workshop/exercises/translation/entwine.json
A doc/workshop/exercises/translation/entwine.rst
R doc/workshop/exercises/translation/greyhound-cd-command.txt
R doc/workshop/exercises/translation/greyhound-command.txt
R doc/workshop/exercises/translation/greyhound-info-command.txt
R doc/workshop/exercises/translation/greyhound.json
R doc/workshop/exercises/translation/greyhound.rst
A doc/workshop/exercises/translation/reprojection-command-1-win.txt
M doc/workshop/exercises/translation/reprojection-command-1.txt
A doc/workshop/exercises/translation/reprojection-command-2-win.txt
M doc/workshop/exercises/translation/reprojection-command-2.txt
M doc/workshop/exercises/translation/reprojection.rst
A doc/workshop/images/batch-processing-dtm-qgis.png
M doc/workshop/images/boundary-text-output.png
M doc/workshop/images/boundary-tindex-run.png
M doc/workshop/images/clipping-run-command.png
M doc/workshop/images/colorize-run-command.png
M doc/workshop/images/compression-verify.png
M doc/workshop/images/denoise-run-command.png
M doc/workshop/images/density-command-run.png
M doc/workshop/images/dtm-run-command.png
A doc/workshop/images/entwine-command.png
A doc/workshop/images/entwine-info-verify.png
A doc/workshop/images/entwine-view.png
A doc/workshop/images/first-mesh.png
M doc/workshop/images/georeferencing-run-command.png
M doc/workshop/images/ground-run-command.png
M doc/workshop/images/info-interesting-metadata-jq.png
M doc/workshop/images/info-interesting-metadata.png
M doc/workshop/images/info-interesting-single-point.png
M doc/workshop/images/info-near-bbox.png
M doc/workshop/images/info-near-point.png
A doc/workshop/images/meshing-building-result.png
A doc/workshop/images/meshing-buildings.png
A doc/workshop/images/meshing.png
M doc/workshop/images/python-histogram-command.png
M doc/workshop/images/python-histogram.png
M doc/workshop/images/rasterization-classification-run-command.png
M doc/workshop/images/rasterization-colored-classification.png
M doc/workshop/images/rasterization-colored-intensity.png
M doc/workshop/images/rasterization-denmark-no-ramp.png
A doc/workshop/images/rasterization-qgis-load-color-palette.png
M doc/workshop/images/reprojection-first-point.png
M doc/workshop/images/reprojection-proper-scale.png
M doc/workshop/images/reprojection-run-command.png
M doc/workshop/images/reprojection-run-with-scale.png
M doc/workshop/images/reprojection-wrong-scale.png
M doc/workshop/images/thinning-command-run.png
M doc/workshop/includes/substitutions.rst
M doc/workshop/index.rst
M doc/workshop/slides/source/analysis.rst
M doc/workshop/slides/source/basic_info.rst
M doc/workshop/slides/source/boundary.rst
M doc/workshop/slides/source/clipping.rst
M doc/workshop/slides/source/colorization.rst
M doc/workshop/slides/source/conf.py
M doc/workshop/slides/source/denoising.rst
M doc/workshop/slides/source/density.rst
M doc/workshop/slides/source/dtm.rst
M doc/workshop/slides/source/ground.rst
A doc/workshop/slides/source/img/terminal.png
M doc/workshop/slides/source/index.rst
M doc/workshop/slides/source/introduction.rst
A doc/workshop/slides/source/meshing.rst
M doc/workshop/slides/source/rasterization.rst
M doc/workshop/slides/source/software.rst
M doc/workshop/slides/source/thinning.rst
M doc/workshop/slides/source/translation.rst
M doc/workshop/software.rst
Log Message:
Workshop updates (#2683)
* Add windows powershell batch processing exercise to workshop
* Update batch exercise, correct references, move include file to inside
* adding workshop branch
* more entwine replacing
* mds updates based on adam steer fork
* add conda and correct toc
* more workshop updates
* remove data
* de-windows path
* added meshing skeleton
* workshop updates
* add windows style commands, p1
* more updates
* more updates, complete except for meshing
* working on meshing instructions
* removing greyhound references
* added Mike Smith and Adam Steer as authors, date to FOSS4G workshop date
* tidied ept resource URL
* using entwine now
* command for building meshing works
* meshing page update
* tidying up meshing commands
* meshing updates
* updates for pdf
* update agenda urls and links
* update slides
* fix sphinx conf files
* adding Python module to conda setup line
Commit: aefeea8403bed94c539871bcb91841bd9af8b9cc
https://github.com/PDAL/PDAL/commit/aefeea8403bed94c539871bcb91841bd9af8b9cc
Changed paths:
M cmake/gdal.cmake
Log Message:
Use our own version checking for GDAL. (#2681)
Commit: f1c56e0d522c9088a0a8ff3d6b7b57bed20ee2d6
https://github.com/PDAL/PDAL/commit/f1c56e0d522c9088a0a8ff3d6b7b57bed20ee2d6
Author: chambbj <brad.chambers at gmail.com>
Changed paths:
M doc/stages/filters.eigenvalues.rst
M filters/EigenvaluesFilter.cpp
M filters/EigenvaluesFilter.hpp
Log Message:
Add option to normalize eigenvalues (#2679)
* Add option to normalize eigenvalues
* Document normalize argument for eigenvalues filter
Commit: 9b8afcc545dcb2a4db88230e979b54eb06331099
https://github.com/PDAL/PDAL/commit/9b8afcc545dcb2a4db88230e979b54eb06331099
Changed paths:
M cmake/macros.cmake
M pdal/Stage.hpp
M pdal/pdal_export.hpp
M pdal/util/pdal_util_export.hpp
M plugins/sqlite/CMakeLists.txt
M plugins/sqlite/io/SQLiteCommon.hpp
Log Message:
Isolate SQLite symbols in shared library (#2686)
* Isolate SQLite in SQLiteCommon to specific shared libraries.
* Define PDAL_LOCAL to nothing on Windows since everything is local by default.
Commit: e239d4e8fdc3ea58373210c2afaab3090410aa71
https://github.com/PDAL/PDAL/commit/e239d4e8fdc3ea58373210c2afaab3090410aa71
Changed paths:
M cmake/gdal.cmake
M pdal/Stage.hpp
Log Message:
Compare: https://github.com/PDAL/PDAL/compare/0eb75f53ad43...e239d4e8fdc3
More information about the pdal-commits
