[pdal-commits] [PDAL/PDAL] c3cde5: E57 fixes (#2530)
Jim Klassen noreply at github.com
Mon May 20 07:07:52 PDT 2019
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: c3cde59853d3d4f272880df86b0707c4cd51dac1
      https://github.com/PDAL/PDAL/commit/c3cde59853d3d4f272880df86b0707c4cd51dac1
  Author: Jim Klassen <klassen.js at gmail.com>
  Date:   2019-05-20 (Mon, 20 May 2019)
  Changed paths:
    A doc/stages/readers.e57.rst
    A doc/stages/writers.e57.rst
    M plugins/e57/io/Utils.cpp
  Log Message:
  E57 fixes (#2530)
* E57: Keep track of cartesianInvalidState dimension.
Map cartesianInvalidState to pdal::Dimension::Id::Omit.  Allows
filtering out invalid points later in the pipeline.
Also map nor:normal[XYZ] to pdal::Dimension::Id::Normal[XYZ].
* E57: Add reader/writer stage documentation.
More information about the pdal-commits mailing list
