[pdal-commits] [PDAL/PDAL] 33ed30: Documentation fixes (#2770)
Howard Butler
noreply at github.com
Fri Oct 4 08:21:02 PDT 2019
Branch: refs/heads/ogr-filter-options
Home: https://github.com/PDAL/PDAL
Commit: 33ed30374007a94cf9d3295a954a43a32f003865
https://github.com/PDAL/PDAL/commit/33ed30374007a94cf9d3295a954a43a32f003865
Author: Jules Robichaud-Gagnon <j.robichaudg at gmail.com>
Date: 2019-10-01 (Tue, 01 Oct 2019)
Changed paths:
M doc/stages/filters.stats.rst
M doc/stages/writers.tiledb.rst
M doc/tutorial/reading.rst
M doc/type-table.csv
Log Message:
* Fix incorrect bit counts
* Fix extra space
* Fix incorrect section title
* Fix cross-reference that has to be unique
Commit: a10d12be688a4d6d48380c14963bd521dd6de121
https://github.com/PDAL/PDAL/commit/a10d12be688a4d6d48380c14963bd521dd6de121
Author: Connor Manning <connor at hobu.co>
Date: 2019-10-02 (Wed, 02 Oct 2019)
Changed paths:
M filters/private/pnp/GridPnp.hpp
Log Message:
Make non-mutating methods in GridPnp const. (#2773)
Commit: 8b72131fd15cb40072204217fbf1caf451598aa4
https://github.com/PDAL/PDAL/commit/8b72131fd15cb40072204217fbf1caf451598aa4
Author: chambbj <brad.chambers at gmail.com>
Changed paths:
M doc/references.rst
M doc/stages/filters.rst
A doc/stages/filters.skewnessbalancing.rst
A filters/SkewnessBalancingFilter.cpp
A filters/SkewnessBalancingFilter.hpp
Log Message:
Add Bartels & Wei skewness balancing approach to ground segmentation (#2741)
* Add Bartels & Wei skewness balancing approach to ground segmentation
* Change skewness map to vector
Commit: 763a668fce27e49651b5a53252eaf7c9518dc5e1
https://github.com/PDAL/PDAL/commit/763a668fce27e49651b5a53252eaf7c9518dc5e1
Author: Norman Barker <norman at tiledb.io>
Changed paths:
Log Message:
fixed tiledb writer typo (#2764)
Commit: b2a0b0ff0bbcd76e8fc0abc41b34a84baa20a670
https://github.com/PDAL/PDAL/commit/b2a0b0ff0bbcd76e8fc0abc41b34a84baa20a670
Author: Nicolai Mogensen <nicolaimogensen at outlook.dk>
Date: 2019-10-03 (Thu, 03 Oct 2019)
Changed paths:
M doc/pipeline.rst
M doc/python.rst
M doc/stages/filters.chipper.rst
M doc/stages/filters.merge.rst
M doc/stages/filters.miniball.rst
M doc/stages/filters.planefit.rst
M doc/stages/filters.shell.rst
M doc/stages/readers.gdal.rst
M doc/stages/readers.las.rst
M doc/stages/readers.pgpointcloud.rst
M doc/stages/writers.bpf.rst
M doc/stages/writers.e57.rst
M doc/stages/writers.fbx.rst
M doc/stages/writers.null.rst
Log Message:
JSON fixes in documentation codeblocks (#2774)
* fix JSON in pdal.io/python.html
* Fix JSON in pipeline.rst
* Fix JSON in filters.chipper.rst
* more JSON fixes in various .rst files
* more JSON fixes in documentation
* Removing "pipeline" as example is a snippet
Commit: 8cd353df30dfaa28db342b543b4ae6ea65c941a5
https://github.com/PDAL/PDAL/commit/8cd353df30dfaa28db342b543b4ae6ea65c941a5
Changed paths:
M io/EptReader.cpp
M io/EptReader.hpp
M io/private/EptSupport.hpp
M test/unit/io/EptReaderTest.cpp
Log Message:
Make EPT reader asynchronous in streaming mode (#2772)
* Make EPT streaming occur asynchronously with a lookahead buffer of nodes.
* Handle zero-point overlaps in streaming EPT reader, for when octree bounds overlap a query but no contained points overlap.
* Respect the threads option for EPT reader streaming.
* Update EPT streaming test, correct usage of the output point layout.
* Remove constness changes unrelated to EPT streaming for PR.
* Add a utility function for near-duplicate code in EPT reader.
* Remove a redundant condition check.
* Use a better setField call for EPT reader streaming rather than transiting every dimension through a double.
* Replace git status coercion.
* Remove a bit of duplication.
* Use a list instead of a map with an unused key for EPT reader streaming buffers. Add a few missing includes.
Commit: bfd479c7e0ed461b9b465af28b3d37f0be25a652
https://github.com/PDAL/PDAL/commit/bfd479c7e0ed461b9b465af28b3d37f0be25a652
Author: Howard Butler <howard at hobu.co>
Date: 2019-10-04 (Fri, 04 Oct 2019)
Changed paths:
M doc/pipeline.rst
M doc/python.rst
M io/EptReader.cpp
M io/EptReader.hpp
Log Message:
Merge remote-tracking branch 'origin/master' into ogr-filter-options
Compare: https://github.com/PDAL/PDAL/compare/1f9f2eb76581...bfd479c7e0ed
More information about the pdal-commits
