[pdal-commits] [PDAL/PDAL] 33ed30: Documentation fixes (#2770)
Connor Manning noreply at github.com
Mon Oct 14 11:14:22 PDT 2019
  Branch: refs/heads/ept-zstandard-updates
  Home:   https://github.com/PDAL/PDAL
  Commit: 33ed30374007a94cf9d3295a954a43a32f003865
      https://github.com/PDAL/PDAL/commit/33ed30374007a94cf9d3295a954a43a32f003865
  Author: Jules Robichaud-Gagnon <j.robichaudg at gmail.com>
  Date:   2019-10-01 (Tue, 01 Oct 2019)
  Changed paths:
    M doc/stages/filters.stats.rst
    M doc/stages/writers.tiledb.rst
    M doc/tutorial/reading.rst
    M doc/type-table.csv
  Log Message:
* Fix incorrect bit counts
* Fix extra space
* Fix incorrect section title
* Fix cross-reference that has to be unique
  Commit: a10d12be688a4d6d48380c14963bd521dd6de121
      https://github.com/PDAL/PDAL/commit/a10d12be688a4d6d48380c14963bd521dd6de121
  Author: Connor Manning <connor at hobu.co>
  Date:   2019-10-02 (Wed, 02 Oct 2019)
  Changed paths:
    M filters/private/pnp/GridPnp.hpp
  Log Message:
  Make non-mutating methods in GridPnp const. (#2773)
  Commit: 8b72131fd15cb40072204217fbf1caf451598aa4
      https://github.com/PDAL/PDAL/commit/8b72131fd15cb40072204217fbf1caf451598aa4
  Author: chambbj <brad.chambers at gmail.com>
  Changed paths:
    M doc/references.rst
    M doc/stages/filters.rst
    A doc/stages/filters.skewnessbalancing.rst
    A filters/SkewnessBalancingFilter.cpp
    A filters/SkewnessBalancingFilter.hpp
  Log Message:
  Add Bartels & Wei skewness balancing approach to ground segmentation (#2741)
* Add Bartels & Wei skewness balancing approach to ground segmentation
* Change skewness map to vector
  Commit: 763a668fce27e49651b5a53252eaf7c9518dc5e1
      https://github.com/PDAL/PDAL/commit/763a668fce27e49651b5a53252eaf7c9518dc5e1
  Author: Norman Barker <norman at tiledb.io>
  Changed paths:
  Log Message:
  fixed tiledb writer typo (#2764)
  Commit: b2a0b0ff0bbcd76e8fc0abc41b34a84baa20a670
      https://github.com/PDAL/PDAL/commit/b2a0b0ff0bbcd76e8fc0abc41b34a84baa20a670
  Author: Nicolai Mogensen <nicolaimogensen at outlook.dk>
  Date:   2019-10-03 (Thu, 03 Oct 2019)
  Changed paths:
    M doc/pipeline.rst
    M doc/python.rst
    M doc/stages/filters.chipper.rst
    M doc/stages/filters.merge.rst
    M doc/stages/filters.miniball.rst
    M doc/stages/filters.planefit.rst
    M doc/stages/filters.shell.rst
    M doc/stages/readers.gdal.rst
    M doc/stages/readers.las.rst
    M doc/stages/readers.pgpointcloud.rst
    M doc/stages/writers.bpf.rst
    M doc/stages/writers.e57.rst
    M doc/stages/writers.fbx.rst
    M doc/stages/writers.null.rst
  Log Message:
  JSON fixes in documentation codeblocks (#2774)
* fix JSON in pdal.io/python.html
* Fix JSON in pipeline.rst
* Fix JSON in filters.chipper.rst
* more JSON fixes in various .rst files
* more JSON fixes in documentation
* Removing "pipeline" as example is a snippet
  Commit: 8cd353df30dfaa28db342b543b4ae6ea65c941a5
      https://github.com/PDAL/PDAL/commit/8cd353df30dfaa28db342b543b4ae6ea65c941a5
  Changed paths:
    M io/EptReader.cpp
    M io/EptReader.hpp
    M io/private/EptSupport.hpp
    M test/unit/io/EptReaderTest.cpp
  Log Message:
  Make EPT reader asynchronous in streaming mode (#2772)
* Make EPT streaming occur asynchronously with a lookahead buffer of nodes.
* Handle zero-point overlaps in streaming EPT reader, for when octree bounds overlap a query but no contained points overlap.
* Respect the threads option for EPT reader streaming.
* Update EPT streaming test, correct usage of the output point layout.
* Remove constness changes unrelated to EPT streaming for PR.
* Add a utility function for near-duplicate code in EPT reader.
* Remove a redundant condition check.
* Use a better setField call for EPT reader streaming rather than transiting every dimension through a double.
* Replace git status coercion.
* Remove a bit of duplication.
* Use a list instead of a map with an unused key for EPT reader streaming buffers.  Add a few missing includes.
  Commit: 531b21c614139495d4f1b62e90322b724a5f80df
      https://github.com/PDAL/PDAL/commit/531b21c614139495d4f1b62e90322b724a5f80df
  Author: Howard Butler <howard at hobu.co>
  Date:   2019-10-07 (Mon, 07 Oct 2019)
  Changed paths:
    M io/EptReader.cpp
    M pdal/GDALUtils.cpp
    M pdal/GDALUtils.hpp
    M pdal/Geometry.hpp
    M pdal/Polygon.cpp
    M pdal/SpatialReference.hpp
    M scripts/conda/osx.sh
    A test/data/autzen/autzen-attribute-cropped.las
    M test/data/ept/1.2-with-color/ept.json
  Log Message:
  Support filtering EPT by OGR datasources (#2771)
* initial implementation of OGR filtering with an 'ogr' json block for readers.ept
* remove lint
* remove more lint
* hammer CFLAGS and CXXFLAGS due to conda injecting them
* support driver specification and openoptions
* simplify filtering with OGR
* initialize m_queryGrids in initialize()
* add test of OGR filtering
* clean up ctors that are not needed
  Commit: 1806d35d918d3c54d8f5f61751b72dc212efc332
      https://github.com/PDAL/PDAL/commit/1806d35d918d3c54d8f5f61751b72dc212efc332
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
    M io/EptReader.cpp
    M pdal/Geometry.cpp
    M pdal/Geometry.hpp
    M pdal/Polygon.cpp
    M pdal/Polygon.hpp
  Log Message:
  Remove OGR code for EPT (#2777)
* Remove OGR code for EPT
* Consolidate code.
  Commit: 2033fdd8dcbd54551a8e1646939155590d277888
      https://github.com/PDAL/PDAL/commit/2033fdd8dcbd54551a8e1646939155590d277888
  Changed paths:
    M doc/stages/filters.hexbin.rst
    M filters/HexBinFilter.cpp
    M filters/HexBinFilter.hpp
    M pdal/Polygon.cpp
    M pdal/Polygon.hpp
  Log Message:
  Support simplification without topology (#2776)
* support simplification without preserving topology in pdal::Polygon and reflect in filters.hexbin
* add missing m_preserve_topology call in simplify
  Commit: efcc6f49153aab0fcbbcf7b1e452f6de4aee4aa3
      https://github.com/PDAL/PDAL/commit/efcc6f49153aab0fcbbcf7b1e452f6de4aee4aa3
  Date:   2019-10-14 (Mon, 14 Oct 2019)
  Changed paths:
  Log Message:
  Add zstandard stream test.
  Commit: 32fccfa3741f813e9f2da31bc2894d261c133df1
      https://github.com/PDAL/PDAL/commit/32fccfa3741f813e9f2da31bc2894d261c133df1
  Changed paths:
    M doc/pipeline.rst
    M doc/python.rst
    M io/EptReader.cpp
    M io/EptReader.hpp
    M pdal/Geometry.cpp
    M pdal/Geometry.hpp
    M pdal/Polygon.cpp
    M pdal/Polygon.hpp
  Log Message:
  Merge branch 'master' into ept-zstandard-updates
Compare: https://github.com/PDAL/PDAL/compare/35fdf8cf7786...32fccfa3741f
More information about the pdal-commits mailing list
