[pdal-commits] [PDAL/PDAL] ccd2b4: Fix potential inf. loop (#2979)
Andrew Bell
noreply at github.com
Thu Mar 12 15:55:00 PDT 2020
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: ccd2b4a8a971603b69050c7e80b6ce3b082357d5
https://github.com/PDAL/PDAL/commit/ccd2b4a8a971603b69050c7e80b6ce3b082357d5
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2020-03-12 (Thu, 12 Mar 2020)
Changed paths:
M io/LasVLR.cpp
M pdal/util/Utils.cpp
M test/unit/UtilsTest.cpp
Log Message:
* Make user VLR handling robust.
* Cleanup.
* Remove dead header.
* Make things with with Ext VLRs.
* Add more test.
* One more test.
* Remove unnecessary cast.
* Add a real test for the original problem.
* Cleaner logic.
* Make valid base64-encoded value.
* Remove merge conflict.
* Missed a character.
* Fix potential inf. loop in parsing VLR.
Trap error in bad base64 decoding.
More information about the pdal-commits
