[pdal-commits] [PDAL/PDAL] ccd2b4: Fix potential inf. loop (#2979)
Andrew Bell
noreply at github.com
Fri Mar 13 11:25:13 PDT 2020
Branch: refs/heads/issue-2262
Home: https://github.com/PDAL/PDAL
Commit: ccd2b4a8a971603b69050c7e80b6ce3b082357d5
https://github.com/PDAL/PDAL/commit/ccd2b4a8a971603b69050c7e80b6ce3b082357d5
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2020-03-12 (Thu, 12 Mar 2020)
Changed paths:
M io/LasVLR.cpp
M pdal/util/Utils.cpp
M test/unit/UtilsTest.cpp
Log Message:
* Make user VLR handling robust.
* Cleanup.
* Remove dead header.
* Make things with with Ext VLRs.
* Add more test.
* One more test.
* Remove unnecessary cast.
* Add a real test for the original problem.
* Cleaner logic.
* Make valid base64-encoded value.
* Remove merge conflict.
* Missed a character.
* Fix potential inf. loop in parsing VLR.
Trap error in bad base64 decoding.
Commit: f71523419bc0b04a2272411447591dda99afc475
https://github.com/PDAL/PDAL/commit/f71523419bc0b04a2272411447591dda99afc475
Author: Jim Klassen <klassen.js at gmail.com>
Date: 2020-03-13 (Fri, 13 Mar 2020)
Changed paths:
M doc/stages/filters.icp.rst
M filters/IterativeClosestPoint.cpp
Log Message:
filters.icp: output centroid to metadata (#2962)
This is needed to apply the same transformation to a different set
of points using filters.transform. (#2939)
Commit: 4bfd10b7adb1379bd4e5611739fd569b435cc078
https://github.com/PDAL/PDAL/commit/4bfd10b7adb1379bd4e5611739fd569b435cc078
Changed paths:
M kernels/TileKernel.cpp
Log Message:
Call setSpatialReference() on the table when we switch stages. (#2980)
Commit: c52c1876e500da23d2d3f1d6efe2fb72b9d0f262
https://github.com/PDAL/PDAL/commit/c52c1876e500da23d2d3f1d6efe2fb72b9d0f262
Changed paths:
M io/LasVLR.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into issue-2262
Commit: 0e318bcb8860ea2861859566b23394e0dbfd86d2
https://github.com/PDAL/PDAL/commit/0e318bcb8860ea2861859566b23394e0dbfd86d2
Changed paths:
M CMakeLists.txt
Log Message:
Add pdal_util, just in case.
Compare: https://github.com/PDAL/PDAL/compare/7d0f3c215cfd...0e318bcb8860
More information about the pdal-commits
