[pdal-commits] [PDAL/PDAL] 3755bd: Migrate from Azure Pipelines to Github Actions (#3...
Howard Butler
noreply at github.com
Thu Sep 17 07:24:32 PDT 2020
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 3755bd3fe9a8f6b773e783ccbd6e8041b380e0eb
https://github.com/PDAL/PDAL/commit/3755bd3fe9a8f6b773e783ccbd6e8041b380e0eb
Author: Howard Butler <howard at hobu.co>
Date: 2020-09-17 (Thu, 17 Sep 2020)
Changed paths:
A .github/workflows/conda.yml
M .github/workflows/docs.yml
A .github/workflows/linux.yml
A .github/workflows/osx.yml
A .github/workflows/win.yml
R .travis.yml
M HOWTORELEASE.txt
M README.md
R azure-pipelines.yml
M doc/project/docs.rst
M doc/project/integration.rst
M plugins/hdf/io/HdfReader.cpp
R scripts/appveyor/conda/build.cmd
R scripts/appveyor/conda/recipe/bld.bat
R scripts/appveyor/conda/recipe/build.sh
R scripts/appveyor/conda/recipe/meta.yaml
R scripts/appveyor/conda/recipe/scripts/activate.bat
R scripts/appveyor/conda/recipe/scripts/activate.sh
R scripts/appveyor/conda/recipe/scripts/deactivate.bat
R scripts/appveyor/conda/recipe/scripts/deactivate.sh
R scripts/appveyor/config.cmd
R scripts/appveyor/test/build.cmd
R scripts/appveyor/test/test.cmd
R scripts/azp/doc.yml
R scripts/azp/linux-conda.yml
R scripts/azp/linux.yml
R scripts/azp/osx.yml
R scripts/azp/win.yml
R scripts/ci/add_deploy_key.sh
R scripts/ci/after_success.sh
R scripts/ci/build_docs.sh
A scripts/ci/conda/compile.sh
A scripts/ci/conda/examples.sh
A scripts/ci/conda/setup.sh
R scripts/ci/deploy_website.sh
A scripts/ci/docs/deploy_website.sh
A scripts/ci/linux/cmake.sh
A scripts/ci/linux/compile.sh
A scripts/ci/linux/examples.sh
A scripts/ci/linux/setup.sh
A scripts/ci/linux/test.sh
A scripts/ci/osx/cmake.sh
A scripts/ci/osx/compile.sh
A scripts/ci/osx/examples.sh
A scripts/ci/osx/setup.sh
A scripts/ci/osx/test.sh
R scripts/ci/pdaldocs-private.key.enc
R scripts/ci/script.sh
A scripts/ci/win/cmake.sh
A scripts/ci/win/compile.sh
A scripts/ci/win/examples.sh
A scripts/ci/win/setup.sh
A scripts/ci/win/test.sh
R scripts/osgeo4w/config.cmd
Log Message:
Migrate from Azure Pipelines to Github Actions (#3192)
* Github Action for Linux/Conda build
* conda linux build
* syntax
* no CPD
* actually test
* add osx builder
* add windows build
* use cmd instead of bash
* syntax
* print cd
* build dir
* conda shell for win
* lint
* explicit activation
* call conda
* try using bash instead of cmd
* directory
* shell subs
* remove cmd continuations
* lint
* more lint
* line continuations
* quoting
* fetch explicit string for datasetName in readers.hdf
* CMAKE_BUILD_TYPE
* put each step into its own script
* directory paths
* source
* doc pushing
* doc deploy script
* trigger build
* syntax
* checkout into root dir
* doc push churn
* clone above root
* git directory name
* git checkout for docs
* documentation build/push
* executable bit for doc deploy_website
* deploy conditional
* syntax
* small layout tweaks
* doc deploy path
* split linux and osx workflows
* gdal-config lint
* remove conda strict
* typo'd install path
* update fixed conda config
* quit failing at logic
* install into CONDA_PREFIX for linux
* cleanups
* docs
* no md
* don't build svgs for latex
* remove AzP reference
* add win examples
* fixed/float build matrix for OSX and Windows
* correct path to win examples
* no gdal-config on win
* turn off abseil on win/osx
* export cl.exe
* remove conda-build usage
* start adding conda feedstock build/test loop
* clobber
* wipe sha256 and url params
* use https url for feedstock build fetch
* conda install
* dont build twice
* typo
* need ninja and compilers to do things
* artifact upload
* use local packages directory for install
* permute runs-on
* set CXX and CC variables for windows
* bump build number to 2112 so it doesn't clash
* use correct env var
* need msvc enabled if windows-latest
* reinstall compilers
More information about the pdal-commits
