[pdal-commits] [PDAL/PDAL] d1871a: No longer need to check cmake version.
Andrew Bell
noreply at github.com
Thu Sep 17 10:37:47 PDT 2020
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: d1871a4bb851d2a2d2c355394741fca70e53c277
https://github.com/PDAL/PDAL/commit/d1871a4bb851d2a2d2c355394741fca70e53c277
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2020-09-17 (Thu, 17 Sep 2020)
Changed paths:
M cmake/unix_compiler_options.cmake
Log Message:
Commit: 49719854f6a118276174ca0633632b925d76d0f3
https://github.com/PDAL/PDAL/commit/49719854f6a118276174ca0633632b925d76d0f3
Changed paths:
A .github/workflows/conda.yml
M .github/workflows/docs.yml
A .github/workflows/linux.yml
A .github/workflows/osx.yml
A .github/workflows/win.yml
R .travis.yml
M HOWTORELEASE.txt
M README.md
R azure-pipelines.yml
M doc/project/docs.rst
M doc/project/integration.rst
M pdal/Geometry.cpp
M plugins/hdf/io/HdfReader.cpp
R scripts/appveyor/conda/build.cmd
R scripts/appveyor/conda/recipe/bld.bat
R scripts/appveyor/conda/recipe/build.sh
R scripts/appveyor/conda/recipe/meta.yaml
R scripts/appveyor/conda/recipe/scripts/activate.bat
R scripts/appveyor/conda/recipe/scripts/activate.sh
R scripts/appveyor/conda/recipe/scripts/deactivate.bat
R scripts/appveyor/conda/recipe/scripts/deactivate.sh
R scripts/appveyor/config.cmd
R scripts/appveyor/test/build.cmd
R scripts/appveyor/test/test.cmd
R scripts/azp/doc.yml
R scripts/azp/linux-conda.yml
R scripts/azp/linux.yml
R scripts/azp/osx.yml
R scripts/azp/win.yml
R scripts/ci/add_deploy_key.sh
R scripts/ci/after_success.sh
R scripts/ci/build_docs.sh
A scripts/ci/conda/compile.sh
A scripts/ci/conda/examples.sh
A scripts/ci/conda/setup.sh
R scripts/ci/deploy_website.sh
A scripts/ci/docs/deploy_website.sh
A scripts/ci/linux/cmake.sh
A scripts/ci/linux/compile.sh
A scripts/ci/linux/examples.sh
A scripts/ci/linux/setup.sh
A scripts/ci/linux/test.sh
A scripts/ci/osx/cmake.sh
A scripts/ci/osx/compile.sh
A scripts/ci/osx/examples.sh
A scripts/ci/osx/setup.sh
A scripts/ci/osx/test.sh
R scripts/ci/pdaldocs-private.key.enc
R scripts/ci/script.sh
A scripts/ci/win/cmake.sh
A scripts/ci/win/compile.sh
A scripts/ci/win/examples.sh
A scripts/ci/win/setup.sh
A scripts/ci/win/test.sh
R scripts/osgeo4w/config.cmd
Log Message:
Merge remote-tracking branch 'origin/master'
Compare: https://github.com/PDAL/PDAL/compare/3755bd3fe9a8...49719854f6a1
More information about the pdal-commits
