[pdal-commits] [PDAL/PDAL] 431de7: EPT reader filtering with both polygon and bounds ...
Andrew Bell
noreply at github.com
Wed Sep 1 12:00:17 PDT 2021
Branch: refs/heads/issue-3525
Home: https://github.com/PDAL/PDAL
Commit: 431de7a785eb8911adb36b2dfb11fa05416dc5fe
https://github.com/PDAL/PDAL/commit/431de7a785eb8911adb36b2dfb11fa05416dc5fe
Author: Connor Manning <connor at hobu.co>
Date: 2021-08-31 (Tue, 31 Aug 2021)
Changed paths:
M doc/stages/readers.ept.rst
M io/EptReader.cpp
M test/unit/io/EptReaderTest.cpp
Log Message:
EPT reader filtering with both polygon and bounds (#3506)
* Fix EPT reader polygon/bounds interaction to require both to pass, matching 2.2 behavior.
* Fix spatial filter checks when filters are not present.
* Add EPT reader test for polygon/bounds combination query.
* Add doc note for readers.ept polygon/bounds combination behavior.
Commit: 9448ade4f33c510ab05ec837e7295cae2b198803
https://github.com/PDAL/PDAL/commit/9448ade4f33c510ab05ec837e7295cae2b198803
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2021-09-01 (Wed, 01 Sep 2021)
Changed paths:
M cmake/win32_compiler_options.cmake
M filters/GreedyProjection.hpp
M io/OptechReader.cpp
M io/SbetReader.cpp
M io/SbetWriter.cpp
M test/unit/GeoreferenceTest.cpp
Log Message:
Don't use _USE_MATH_DEFINES locally (#3524)
* Initialize UUID to null.
Close #3483
* Catch bounds exceptions.
* Remove local _USE_MATH_DEFINES
Commit: 85bfead5fe8f17098cb2cf43b3e66cd985d0b003
https://github.com/PDAL/PDAL/commit/85bfead5fe8f17098cb2cf43b3e66cd985d0b003
Changed paths:
M io/EptReader.cpp
M io/SbetReader.cpp
M io/SbetWriter.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into issue-3525
Compare: https://github.com/PDAL/PDAL/compare/60a9475da529...85bfead5fe8f
More information about the pdal-commits
