[pdal-commits] [PDAL/PDAL] 431de7: EPT reader filtering with both polygon and bounds ...
Andrew Bell
noreply at github.com
Fri Sep 3 11:32:50 PDT 2021
Branch: refs/heads/issue-3527
Home: https://github.com/PDAL/PDAL
Commit: 431de7a785eb8911adb36b2dfb11fa05416dc5fe
https://github.com/PDAL/PDAL/commit/431de7a785eb8911adb36b2dfb11fa05416dc5fe
Author: Connor Manning <connor at hobu.co>
Date: 2021-08-31 (Tue, 31 Aug 2021)
Changed paths:
M doc/stages/readers.ept.rst
M io/EptReader.cpp
M test/unit/io/EptReaderTest.cpp
Log Message:
EPT reader filtering with both polygon and bounds (#3506)
* Fix EPT reader polygon/bounds interaction to require both to pass, matching 2.2 behavior.
* Fix spatial filter checks when filters are not present.
* Add EPT reader test for polygon/bounds combination query.
* Add doc note for readers.ept polygon/bounds combination behavior.
Commit: 9448ade4f33c510ab05ec837e7295cae2b198803
https://github.com/PDAL/PDAL/commit/9448ade4f33c510ab05ec837e7295cae2b198803
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2021-09-01 (Wed, 01 Sep 2021)
Changed paths:
M cmake/win32_compiler_options.cmake
M filters/GreedyProjection.hpp
M io/OptechReader.cpp
M io/SbetReader.cpp
M io/SbetWriter.cpp
M test/unit/GeoreferenceTest.cpp
Log Message:
Don't use _USE_MATH_DEFINES locally (#3524)
* Initialize UUID to null.
Close #3483
* Catch bounds exceptions.
* Remove local _USE_MATH_DEFINES
Commit: 1a2b3d6a8e30200be0f761a3cbafe7e3e052b42c
https://github.com/PDAL/PDAL/commit/1a2b3d6a8e30200be0f761a3cbafe7e3e052b42c
Date: 2021-09-02 (Thu, 02 Sep 2021)
Changed paths:
M io/GeotiffSupport.cpp
M pdal/pdal_internal.hpp
Log Message:
Add more meaningful capability macros (#3526)
Make some more descriptive macros for windows-y stuff.
Simplify internal file.
Commit: 6be96eb17ace4415a9637f43ff2a31ce67a11dca
https://github.com/PDAL/PDAL/commit/6be96eb17ace4415a9637f43ff2a31ce67a11dca
Changed paths:
M io/EptReader.cpp
M io/SbetReader.cpp
M io/SbetWriter.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into issue-3527
Commit: cc299ac6bfdd93b9b69ad3613f5b18a5ed6e7509
https://github.com/PDAL/PDAL/commit/cc299ac6bfdd93b9b69ad3613f5b18a5ed6e7509
Date: 2021-09-03 (Fri, 03 Sep 2021)
Changed paths:
M io/LasReader.cpp
M pdal/compression/LazPerfVlrCompression.cpp
M pdal/compression/LazPerfVlrCompression.hpp
A test/data/laz/ellipsoid.copc.laz
M test/unit/io/LasReaderTest.cpp
Log Message:
Support reading and seeking with variable-sized chunks.
Compare: https://github.com/PDAL/PDAL/compare/c08f05160d27...cc299ac6bfdd
More information about the pdal-commits
