[pgrouting-dev] Implementation of core Time Dependent Dijkstra function
Stephen Woodbridge woodbri at swoodbridge.com
Fri Apr 29 20:44:10 EDT 2011
On 4/29/2011 5:03 PM, Jay Mahadeokar wrote:
> Hi.
> As already discussed in the proposal for Time Dependent Shortest Path
> (TDSP) basically core part would be the extension of basic dijkstra
> algorithm to work for time dependent edge weights.
> This will involve a major change in the usual approach of pgRouting in
> the sense that no boost algorithm for time dependent edge weights is
> already implemented. So, we have to code the core algorithm ourselves.
> I was looking at the boost implementation of dijkstra algorithm here:
> http://www.boost.org/doc/libs/1_46_1/boost/graph/dijkstra_shortest_paths.hpp
> I figured we can reuse much of the code and ideas.
> Before I look deeper into the code, and see how we can modify it to make
> it time dependent, I wanted to know: if we reuse the static boost
> dijkstra code (and some other code that would be required with it), will
> there be any licencing issues?
Boost has a very liberal license and since we are already including
boost code in pgRouting, I do no think it should be a problem.
I assume the "some other code" you reference would be code that you
write for the project? If so then this should not be a problem.
-Steve
More information about the pgrouting-dev mailing list
