[pgrouting-dev] pgRouting Debian Package
"Christophe Damour (SIGéal)"
sigeal at sigeal.com
Sat Dec 10 05:20:08 EST 2011
Hi Daniel,
I got the server up with Ubuntu 11.04.
I tried the following with no success :
- Installation following pgRouting doc
(http://www.pgrouting.org/docs/1.x/install_ubuntu.html)
It failed at step 2 (Comile pgRouting core), saying it couldn't find
POSTGRESQL_EXECUTABLE...
The postgresql executable path seems to be : /usr/lib/postgresql/8.4/bin
- Intallation of your pgRouting package
(postgresql-8.4-pgrouting_1.05-1~natty2_i386.deb)
It failed saying postgresql-8.4-postgis is not installed.
I installed indeed postgresql-8.4 (apt-get install postgresql-8.4), but
when I try apt-get install postgresql-8.4-postgis, I get a
"postgresql-8.4-postgis is not available" message.
As you understand, I am quite a linux newbie, so I apologize for stupid
questions...
Any hint appreciated.
Christophe
Le 09/12/2011 17:01, Daniel Kastl a écrit :
> On Sat, Dec 10, 2011 at 12:19 AM, "Christophe Damour (SIGéal)"
> <sigeal at sigeal.com <mailto:sigeal at sigeal.com>> wrote:
> Hi Daniel,
> I am in the process of setting a virtual private server for my
> development needs.
> As I can chose the linux distribution, I would like to know if you
> manage to build a pgRouting package for PostgreSQL 9.0 ?
> Hi Christophe,
> I have build packages for Ubuntu 11.10 with PostgreSQL 9.1, but
> haven't published them yet on Launchpad.
> And on OpenSuse 11.4 with PostgreSQL 9.0 it was also possible to
> compile pgRouting.
> So I assume that PostgreSQL 9.0 and 9.1 are both OK.
> For CGAL dependency on the latest Ubuntu you need this fix:
> https://github.com/sanak/pgrouting/commit/6ec1672f79f7070c60fb6095342d7d0b55cf2659
> Daniel
> Thanks,
> Christophe
> Le 14/10/2011 18:41, Daniel Kastl a écrit :
>> On Sat, Oct 15, 2011 at 12:59 AM, "Christophe Damour (SIGéal)"
>> I asked the provider and he answered that an official Debian
>> package was not absolutely required, but at least a package
>> supported by pgRouting development team. Could this be possible ?
>> Theoretically it is possible, but since most of my community work
>> is on a volunteer base, I can only do this if I have enough spare
>> time or if you're able to sponsor the work or find a sponsor.
>> Also, what about PostgreSql 9 compatibility. Is this on the
>> roadmap ?
>> I use mainly Ubuntu and the new version that was released
>> yesterday, should include PostgreSQL 9.0 as far as I remember.
>> So I'm also interested to make it work with 9.0 and will probably
>> build packages for 11.10 in the next weeks. If it works with
>> Ubuntu, it should also be compatible with PostgreSQL on Debian.
>> Daniel
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de
>> <mailto:daniel.kastl at georepublic.de>
>> Web: http://georepublic.de <http://georepublic.de/>
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20111210/8816ae2c/attachment-0001.html
More information about the pgrouting-dev
