[pgrouting-dev] pgRouting Debian Package
Daniel Kastl
daniel at georepublic.de
Sat Dec 10 09:08:18 EST 2011
Hi Christophe,
Here is a link to the workshop documentation:
http://workshop.pgrouting.org/chapters/installation.html#pgrouting
Like this pgRouting is also installed on the OSGeo LiveDVD,
where postgresql-8.4-postgis is installed as well.
Can you make sure that you have the "multiverse" repository enabled? It
could be the reason, that you can't find PostGIS package.
Daniel
On Sat, Dec 10, 2011 at 7:20 PM, "Christophe Damour (SIGéal)" <
sigeal at sigeal.com> wrote:
> Hi Daniel,
> I got the server up with Ubuntu 11.04.
> I tried the following with no success :
> - Installation following pgRouting doc (
> http://www.pgrouting.org/docs/1.x/install_ubuntu.html)
> It failed at step 2 (Comile pgRouting core), saying it couldn't find
> POSTGRESQL_EXECUTABLE...
> The postgresql executable path seems to be : /usr/lib/postgresql/8.4/bin
> - Intallation of your pgRouting package
> (postgresql-8.4-pgrouting_1.05-1~natty2_i386.deb)
> It failed saying postgresql-8.4-postgis is not installed.
> I installed indeed postgresql-8.4 (apt-get install postgresql-8.4), but
> when I try apt-get install postgresql-8.4-postgis, I get a
> "postgresql-8.4-postgis is not available" message.
> As you understand, I am quite a linux newbie, so I apologize for stupid
> questions...
> Any hint appreciated.
> Christophe
> Le 09/12/2011 17:01, Daniel Kastl a écrit :
> On Sat, Dec 10, 2011 at 12:19 AM, "Christophe Damour (SIGéal)" <
>> Hi Daniel,
>> I am in the process of setting a virtual private server for my
>> development needs.
>> As I can chose the linux distribution, I would like to know if you manage
>> to build a pgRouting package for PostgreSQL 9.0 ?
> Hi Christophe,
> I have build packages for Ubuntu 11.10 with PostgreSQL 9.1, but haven't
> published them yet on Launchpad.
> And on OpenSuse 11.4 with PostgreSQL 9.0 it was also possible to compile
> pgRouting.
> So I assume that PostgreSQL 9.0 and 9.1 are both OK.
> For CGAL dependency on the latest Ubuntu you need this fix:
> https://github.com/sanak/pgrouting/commit/6ec1672f79f7070c60fb6095342d7d0b55cf2659
> Daniel
>> Thanks,
>> Christophe
>> Le 14/10/2011 18:41, Daniel Kastl a écrit :
>> On Sat, Oct 15, 2011 at 12:59 AM, "Christophe Damour (SIGéal)" <
>>> I asked the provider and he answered that an official Debian package
>>> was not absolutely required, but at least a package supported by pgRouting
>>> development team. Could this be possible ?
>> Theoretically it is possible, but since most of my community work is on
>> a volunteer base, I can only do this if I have enough spare time or if
>> you're able to sponsor the work or find a sponsor.
>>> Also, what about PostgreSql 9 compatibility. Is this on the roadmap ?
>> I use mainly Ubuntu and the new version that was released yesterday,
>> should include PostgreSQL 9.0 as far as I remember.
>> So I'm also interested to make it work with 9.0 and will probably build
>> packages for 11.10 in the next weeks. If it works with Ubuntu, it should
>> also be compatible with PostgreSQL on Debian.
>> Daniel
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de
>> Web: http://georepublic.de
>> pgrouting-dev mailing listpgrouting-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/pgrouting-dev
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20111210/8c1acb51/attachment.html
More information about the pgrouting-dev
