[pgrouting-dev] change geometry column name
    Mohammed Rashad
    mohammedrashadkm at gmail.com
    Fri Jan 14 08:04:13 EST 2011
I am using dijkstra_sp function on my table names roads
my table has the geometry column named geometry
When I execute this sql
SELECT the_geom FROM dijkstra_sp('roads');
I am getting this error
ERROR: column "geometry" does not exist
  Position: 47
but if I change my table roads geometry column to the_geom it works.
Is there anyway to do routing on table which has different geometry column
other than the_geom
Rashad
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110114/3522d090/attachment.html
More information about the pgrouting-dev
