[pgrouting-dev] Public Transport Topology
Anton Patrushev anton.patrushev at georepublic.de
Thu Jun 2 22:08:38 EDT 2011
Hi Kishore,
Nice job!
I like your idea to pass schema as an argument. I wish I was smart
enough before to use such approach for another function I recently
made (DARP).
Anton.
On 6/3/11, Kishore Kumar <justjkk at gmail.com> wrote:
> Hi Anton,
> Glad to see you are back. I was working with producing GTFS data over the
> last week and am planning to use GTFS format[1][2] tables for holding public
> transit topology.
> Since a lot of tables are involved(like trips, routes, stops, stop_times),
> we cannot use the regular syntax of passing a select query as the first
> argument to the core routing function. Hence, I encapsulated all the tables
> into a Schema and pass it as the first argument[3] Will there be any
> problems in this case?
> With GTFS data, we get the following information about a route:
> 1. Locations of stops visited(thus, straight line distance),
> 2. Sequence of stops visited(used for Non-scheduled routing),
> 3. Trip timetable(used for scheduled routing, optional),
> 4. Frequency of trips(used for Non-scheduled routing)
> Fare attributes are also in the GTFS specification but I cut it down because
> of the complexity involved.
> Am I missing storing any other information to find the ideal route?
> Thanks & Regards,
> J Kishore kumar.
> [1] - http://code.google.com/transit/spec/transit_feed_specification.html
> [2] -
> https://github.com/pgRouting/pgrouting/tree/gsoc-multimodal/tests/loaders/gtfs
> [3] -
> https://github.com/pgRouting/pgrouting/blob/gsoc-multimodal/tests/test_mmptr.py#L30
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Anton Patrushev
CTO
eMail: anton.patrushev at georepublic.de
Web: http://georepublic.de
Tel: +49 (089) 420 959 519
Sip: 1959519 at sipgate.de
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
More information about the pgrouting-dev mailing list
