[pgrouting-dev] pgRouting 2.x idea
Kishore Kumar
justjkk at gmail.com
Wed Jun 22 17:58:13 EDT 2011
I want to contribute to this effort and want to cover every piece of
code with unit tests. Having a solid set of tests gives the confidence
to accomplish the envisioned goals. I wish to hear criticisms on the
testing framework from the other developers so that it can be altered
to fit the actual needs.
Thanks & Regards,
J Kishore kumar.
On Sun, Jun 19, 2011 at 11:27 PM, Daniel Kastl <daniel at georepublic.de> wrote:
> Hi list,
> Already quickly mentioned in a previous post [1], some of the pgRouting
> developers think that it might be the right time to get started with a new
> major release.
> There are several reasons for that, such as renaming functions (think about
> "assign_vertex_id" or "shortest_path_shootingstar_directed") or getting rid
> of the troublesome CGAL dependency, not to forget compatibility with PostGIS
> 2.0. Furthermore pgRouting will get some new functions in the next
> months thanks to Jay's and Kishore's great work during GSoC. We think there
> could be a better way to put together all the functions.
> To keep this post short I created a Wiki page on GitHub for collecting ideas
> and feedback:
> https://github.com/pgRouting/pgrouting/wiki/2.0-Development-Plan (should be
> editable by everyone)
> So if you want to back this plan, give some comment, add a request or new
> idea, ... just write to the Wiki or to the mailing list.
> If you want to participate and contribute, even better!
> Daniel
> [1] http://lists.osgeo.org/pipermail/pgrouting-dev/2011-June/000268.html
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev
