[pgrouting-dev] cloning boost_drivedist.cpp to return predecessors
Stephen Woodbridge woodbri at swoodbridge.com
Tue May 17 11:31:11 EDT 2011
Hi Anton,
I'm looking at boost_drivedist.cpp with the idea of clone it to also
return the predecessor with each record output, but I have not worked in
C++ before. So I think I have the idea but want to bounce it off you first.
   vertex_descriptor source_vertex = vertex( source_vertex_id, graph );
   std::vector<vertex_descriptor> predecessors(num_vertices(graph));
   std::vector<float8> distances(num_vertices(graph));
   dijkstra_shortest_paths(graph, source_vertex,
                           predecessor_map(&predecessors[0])
                           .weight_map(get(&Edge::cost, graph))
                           .distance_map(&distances[0]));
   graph_traits < graph_t >::vertex_iterator vi, vend;
   vector<path_element> path_vector;                // <<<< ????????
   int j=0;
   for(tie(vi, vend) = vertices(graph); vi != vend; vi++) {
     if( (double)distances[*vi] <= rdistance ) {
       path_element pe;
       graph_traits<graph_t>::vertex_descriptor s;
       graph_traits<graph_t>::vertex_descriptor p;   // <<<< add this
       s = vertex(*vi, graph);
       p = vertex(predecessor[*vi], graph);          // <<<< add this
       pe.vertex_id = graph[s].id;
       pe.parent_id = graph[p].id;                   // <<<< add this
       pe.edge_id   = graph[s].edge_id;
       pe.cost      = distances[*vi];
       path_vector.push_back( pe );
   if( path_vector.size() == 0 ) {
     *err_msg = (char *)"No path found";
     return 0;
   vector<path_element>::iterator itr;
   *path = (path_element_t *) malloc( sizeof(path_element_t) *
                                      (path_vector.size() + 1) );
   *path_count = path_vector.size();
   for(j=0,itr=path_vector.begin();itr != path_vector.end();itr++,j++) {
     path_element pe = *itr;
     (*path)[j].vertex_id = pe.vertex_id;
     (*path)[j].parent_id = pe.parent_id;           // <<<< add this
     (*path)[j].edge_id   = pe.edge_id;
     (*path)[j].cost      = pe.cost;
   return EXIT_SUCCESS;
So in addition to the above 3 lines, I would need to modify
core/src/dijkstra.h
typedef struct path_element
     int vertex_id;
     int parent_id;   // <<< add this
     int edge_id;
     float8 cost;
} path_element_t;
What I'm not sure on is how (or if it is possible) to modify
path_element pe to include parent_id item.
And finally in the C wrapper to this function I would need to update
parent_id along with vertex_id to uncompress the range shift that was done.
Does this look like it will work? Did I forget anything?
Thoughts?
-Steve
More information about the pgrouting-dev mailing list
