[pgrouting-dev] GSoC branches and unit tests
Daniel Kastl
daniel at georepublic.de
Sun May 22 22:53:45 EDT 2011
Kishore started adding unit tests as described here:
https://github.com/pgRouting/pgrouting/wiki/Automated-Testing-%28Unit-Tests%29
Three libraries are used: CUnit, CTest and Python "unittest".
As explained in the document, each library seems to have its advantages. I'm
probably most concerned about adding Python as another language.
No problem? Recommendations? Any thoughts?
And I merged the changes into a branch called "unittests":
https://github.com/pgRouting/pgrouting/network
Maybe someone is interested to test it and/or give some comments.
I would take the "unittests" branch as base for creating the GSoC project
branches. (@Jay: is that OK for you?)
Thanks a lot to Kishore and Jay, who are doing a great GSoC!
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110523/b0a85dd5/attachment.html
More information about the pgrouting-dev
