[pgrouting-dev] Re: Implementation of core Time Dependent Dijkstra function
Jay Mahadeokar jai.mahadeokar at gmail.com
Tue May 24 19:06:05 EDT 2011
On Mon, May 23, 2011 at 8:03 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> I'm not a C++ programmer, but from what I have read on the boost list, it
> seems that the path to writing generic templates is to write the code first
> in regular C++ so it works and then refactor it to be more generic. So step
> 1 is to do as you proposed.
> Also since this project is to implement a "time dependent dijkstra
> algorithm" in pgRouting, the generic templates seems to be out of scope. It
> would be fine to do if you had the time and skill, but I think your approach
> makes sense, use the tools that make your job easier and allow you to
> achieve success.
> Any contrary opinions to this?
> -Steve
> On 5/23/2011 10:20 AM, Jay Mahadeokar wrote:
>> Hi,
>> As initially discussed, I was trying to reuse the boost's dijkstra code
>> to write the core time dependent dijkstra algorithm.
>> Since Boost makes extensive use of generic programming, and I have no
>> prior experience with such deep generic programming concepts, I was
>> wondering if we really need all these features that boost provides.
>> Another option would be to write the time-dependent dijkstra on our own.
>> This will be a light-weight code without extensive use of generic
>> programming like boost.
>> So, i was thinking of using following:
>> *1. *Boost::AdjecencyList - for storing graph.
>> *2. *Std::Map - for storing distanceMap, predecessorMap.
>> *3. *For weightMap:
>> typedef struct weight_map_element
>>         pair<int,double> edge;
>>         double travel_time;
>> weight_map_element_t;
>> class weight_map
>>     vector<weight_map_element_t> weight_map_set;
>>     public:
>>     void insert(weight_map_element_t element);
>>     double get_travel_time(int edge_id, double start_time);
>> *4. *std::priority_queue  for the priority queue that will be used for
>> dijkstra search.
Well,
The std::prority_queue does not support the decrease_key operation which
will be needed for the dijkstra search. I dont think stl provides a heap
data structure with decrease_key, delete_min and insert operations.
The make_heap, and sort_heap would be too costly to maintain for dijkstra.
Do you have any idea of open-source library that provides the heap
datastructure with above functionality?
I am thinking of implementing binary heap myself to support the required
functionality.
Thoughts?
>> Will this be sufficient for our implementation?  If yes, I will come up
>> with the detailed internal function prototypes soon.
>> On Wed, May 18, 2011 at 8:09 PM, Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>>    On 5/18/2011 8:08 AM, Jay Mahadeokar wrote:
>>        Hi,
>>        I think what we need is a function on following lines:
>>        Given a query_start_time, it should query the TimeDepCosts
>>        table, and
>>        return the set of entries which have their start_time within
>>        query_start_time + delta. This delta might be x hours, depending
>>        on the
>>        upper bound of the expected journey time.
>>        We need following things handled in our model:
>>        If query_start_time is 11PM Sunday and delta is 10 hours, we
>>        will need
>>        to query entries with start time between 11PM Sunday and 9AM
>>        Monday. So,
>>        basically the function needs to be periodic in terms of
>>        time_of_day and
>>        day_of_week.
>>        As Steve suggested, we can maintain conventions for day_of_week
>>        like:
>>        -3   - holidays
>>        -2   - weekend days
>>        -1   - week days
>>        0    - all days
>>        1-7 Mon - Sun.
>>        If we just assume entries for -3,-2,-1,0 and ignore each entry
>>        for Sun -
>>        Sat, that would reduce the space required assuming that the
>>        entries for
>>        weekdays is same. If times for different weekdays is different
>>        then we
>>        would have separate entries for each day.
>>        So, the query should properly examine the query_day_of_week and
>>        select
>>        the proper entries. Ex: For above query, if it is sunday, then
>> after
>>        12AM, next entries will be queried with time_of_day as -1, but
>>        if it was
>>        Saturday, next entries will be queried with time_of_day as -2.
>>        We can have a boolean parameter like *isHoliday* in query
>>        itself, which
>>        will tell if a given day (may be weekday) is holiday or not.Then
>>        again
>>        the query will have to be modified accordingly (query for -3).
>>        This will
>>        take care of query for local holiday etc and we do not have to
>> worry
>>        about calenders. The user will have to worry about that.. :-)
>>    This (isHoliday) might work for a single day, but will not work if
>>    the query crosses into the next day(s). Holidays are an input
>>    convenience to describe recurring events. So say we have a
>>    convenient way to input that data and store it into tables as we
>>    have described, then the query for costs would need to decide is a
>>    given day is a holiday or not and then select the correct entries to
>>    return based on that. For ease of implementation, we could just
>>    start with a stub function the returns false and later implement a
>>    table lookup based on the date or day of year that determines if
>>    isHoliday=t/f for any given start_time+offset.
>>    Then when querying schedules, for example, we would select holiday
>>    schedules if they exist and its a holiday otherwise search the
>>    regular tables.
>>        There can be time_from and time_to entries as well. But, if we
>>        just have
>>        entries like:
>>          day_of_week: -1, time_of_day: 00:01, 55mph
>>          day_of_week: -1, time_of_day: 07:00, 30mph
>>          day_of_week: -1, time_of_day: 10:01, 55mph
>>          day_of_week: -1, time_of_day: 16:31, 30mph
>>        we can assume that the entry with time_of_day 00:01 is valid upto
>>        07:00.  And if query_start_time is 02:00 and delta is 10 hours,
>>        we can
>>        query entries which have time_of_day < query_start_time + delta
>>        (taking
>>        care of change of day).
>>        Is this assumption reasonable?
>>    This sounds reasonable if the response is in units of time (offset)
>>    from query_start_time. Assuming we use a resolution of seconds, then
>>    the response would be in seconds from start time.
>>        *weightMap Abstraction*
>>        I think the design would be more modular if we keep the weightMap
>>        independent of the underlying time conventions. Since as Daniel
>>        pointed
>>        out, this algorithm can also be used for non-road networks.
>>        So, whatever the underlying time conventions, we can assume that
>>        in the
>>        end the query should return pairs like:
>>        < <edgeId, offset_time> , travel_time/speed >
>>        We will assume that query_start_time is 0, i.e we offset every
>>        thing by
>>        query_start_time.
>>        The offset_time will be as follows:
>>        As in above example,
>>        If start_tme is 02:00 and day_of_week is -1, and delta as 10 hours.
>>        Then, edge entries for edgeId 1 will be:
>>        < <1, 05:00 > , 30 mph>
>>        < <1, 08:01 > , 55 mph>
>>        < <1, 14:31 > , 30 mph>
>>        Basically, the offset_time will abstract out any internal details
>> of
>>        weekdays, change of days etc and it will just contain the offset
>>        from
>>        start_time.
>>    I suggested seconds above, but if someone is modeling events in say
>>    glacier flow, geological times or the big bang, they might need
>>    other units of time. I would say that because we are talking about
>>    time based schedules and need to deal with days, hours minutes we
>>    should probably not worry about these other timeframes as the solver
>>    will be offset based it will work with any units and then only the
>>    wrappers for extracting the costs from the schedules would need to
>>    change to deal with other timeframes. So lets not get hung up on
>>    this, I think this is a sound plan.
>>    -Steve
>>        This will greatly simplify the core time dependent dijkstra
>>        implementation.
>>        Thoughts?
>>        On Wed, May 18, 2011 at 10:46 AM, Stephen Woodbridge
>>        <mailto:woodbri at swoodbridge.com>>> wrote:
>>            Hi Daniel,
>>            These are good points.
>>            I agree that turn restrictions should be thought about but only
>>            implemented if there is time. I think we should take the
>>        discussion
>>            of turn restriction into a separate thread. I'm interested
>>        in what
>>            you think is a limitation that can't be modeled in Dijkstra
>>        or A*.
>>            Regarding the time modeling, my point was just that we
>>        needed more
>>            thought there and a richer model developed. The crontab
>>        model is a
>>            good idea. I'm not opposed to modeling monthly or yearly
>>        events, but
>>            they rarely exist other than holidays which I tried to
>>        capture. I
>>            suppose you could model something like the Boston Marathon
>>        and model
>>            all the road closures and restrictions, but it seems to be a
>>        lot of
>>            work for a one day event, but I can see city government's
>>        deploying
>>            the resources to model something like this.
>>            Regarding timezones: Times need to be entered with zones for
>>        models
>>            that cross zones but all the data should be converted to UTC
>>            internally so it runs in a consistent time model. Timezones
>>        are for
>>            input and output, but the solver should be ignorant of them,
>>        in my
>>            opinion.
>>            I have carried my GPS from the Eastern to central time zone,
>>        and it
>>            knew the local time when I powered it up. So my guess is that
>> it
>>            would auto correct when crossing the time zone.
>>            -Steve
>>            On 5/17/2011 10:42 PM, Daniel Kastl wrote:
>>                Hi Jay and Steve,
>>                This looks really nice, but let me give some comments
>>        regarding
>>                how to
>>                model time, because this is really tricky in my opinion.
>>                Especially when
>>                thinking about an abstract network that isn't a road
>>        network.
>>                    Would it be possible to support turn restrictions in
>>        the static
>>                    Dijkstra also? I'm thinking just use all the same
>>        structures but
>>                    ignore the the time components to keep things
>>        simple. So if
>>                the the
>>                    turn restrictions table is present we use it, otherwise
>>                assume no
>>                    restrictions. If doing static shortest path with turn
>>                restrictions
>>                    then ignore the time components otherwise we use
>>        them. And
>>                it is up
>>                    to the user to make sure the turn restriction table
>>        is valid
>>                for the
>>                    analysis being requested.
>>                Currently in pgRouting Dijkstra and A* don't support turn
>>                restrictions
>>                modelling. What I actually like on Shooting Star is, that
>> it
>>                routes from
>>                edge to edge instead of node to node. So it allows to model
>>                relations
>>                between edges rather than nodes, which I think is more
>>        close to how
>>                humans would think of this.
>>                Dijkstra can only visit one node one times (as Shooting
>> star
>>                only visits
>>                an edge once). Well, there can be turn restriction cases
>>        where a
>>                node is
>>                passed twice and which can't be done correctly with
>>        Dijkstra as
>>                far as I
>>                know.
>>                In the beginning I wouldn't think about the turn
>>        restrictions
>>                too much.
>>                Let's take it as an extra when we see we still have
>>        enough time.
>>                Of course if you have a good idea to implement it all at
>>        once
>>                with only
>>                little extra work, then that's fine.
>>                    For time definitions in your tables I think you need
>>        to probably
>>                    define some common structure for handling a time entry.
>>                Another problem might be time zones. Plain day field + time
>>                field might
>>                not be able to allow driving from one time zone to
>>        another (or just
>>                think about a flight network). I never went from one
>>        timezone to
>>                another
>>                by car or train, but Steve and Anton, you might have this
>>                experience.
>>                How does car navigation software handle this when you
>>        cross the
>>                timezone
>>                border? ;-)
>>                So taking "timestamp with timezone" for those fields
>>        might be a good
>>                idea to be able to support such a functionality.
>>                    For example time_from and time_to might need to be
>>        defined as a
>>                    structure that includes day_of_week. day_of week
>>        might take
>>                values like:
>>                    -3   - holidays
>>                    -2   - weekend days
>>                    -1   - week days
>>                    0    - all days
>>                    1..7 - Sun,...,Sat
>>                I think the problem here is how to model recurring time
>>                dependent costs,
>>                right?
>>                If you think about weekdays, then you can't for example
>>        model
>>                monthly or
>>                yearly events.
>>                I'm not really sure this is useful information here, but
>>        I once saw
>>                about how the "iCal" format models recurring calendar
>>        events:
>> http://ext.ensible.com/deploy/dev/examples/calendar/recurrence-widget.html
>>                Maybe we can learn something from there. The example
>>        needed to be
>>                extended with some duration probably. But looking about
>>        calendar
>>                formats
>>                might be a good idea to model holidays etc.
>>                Or another (stupid) example would be cron job syntax.
>>        Something
>>                I always
>>                need to google for as I can't remember it ;-)
>>                All this time dependent stuff, events and schedules is
>>        also an
>>                issue in
>>                Darp solver.
>>                And it probably is important also for the multi-modal
>>        routing,
>>                so if we
>>                can find some clever way how to model this and can share
>>        it between
>>                algorihtms, that would be great.
>>                Daniel
>>                Georepublic UG & Georepublic Japan
>>                eMail: daniel.kastl at georepublic.de
>>        <mailto:daniel.kastl at georepublic.de>
>>        <mailto:daniel.kastl at georepublic.de>>
>>        <mailto:daniel.kastl at georepublic.de>>>
>>                Web: http://georepublic.de <http://georepublic.de/>
>>                _______________________________________________
>>                pgrouting-dev mailing list
>>        pgrouting-dev at lists.osgeo.org
>>        <mailto:pgrouting-dev at lists.osgeo.org>
>>        <mailto:pgrouting-dev at lists.osgeo.org>>
>>        http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>>        Regards,
>>        -Jay Mahadeokar
>>        pgrouting-dev at lists.osgeo.org <mailto:
>>    pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
>> Regards,
>> -Jay Mahadeokar
Regards,
-Jay Mahadeokar
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110525/87312f2e/attachment-0001.html
More information about the pgrouting-dev mailing list
