[pgrouting-dev] Re: Implementation of core Time Dependent Dijkstra function
Jay Mahadeokar jai.mahadeokar at gmail.com
Tue May 24 19:08:05 EDT 2011
On Wed, May 25, 2011 at 4:36 AM, Jay Mahadeokar <jai.mahadeokar at gmail.com>wrote:
> On Mon, May 23, 2011 at 8:03 PM, Stephen Woodbridge <
> woodbri at swoodbridge.com> wrote:
>> I'm not a C++ programmer, but from what I have read on the boost list, it
>> seems that the path to writing generic templates is to write the code first
>> in regular C++ so it works and then refactor it to be more generic. So step
>> 1 is to do as you proposed.
>> Also since this project is to implement a "time dependent dijkstra
>> algorithm" in pgRouting, the generic templates seems to be out of scope. It
>> would be fine to do if you had the time and skill, but I think your approach
>> makes sense, use the tools that make your job easier and allow you to
>> achieve success.
>> Any contrary opinions to this?
>> -Steve
>> On 5/23/2011 10:20 AM, Jay Mahadeokar wrote:
>>> Hi,
>>> As initially discussed, I was trying to reuse the boost's dijkstra code
>>> to write the core time dependent dijkstra algorithm.
>>> Since Boost makes extensive use of generic programming, and I have no
>>> prior experience with such deep generic programming concepts, I was
>>> wondering if we really need all these features that boost provides.
>>> Another option would be to write the time-dependent dijkstra on our own.
>>> This will be a light-weight code without extensive use of generic
>>> programming like boost.
>>> So, i was thinking of using following:
>>> *1. *Boost::AdjecencyList - for storing graph.
>>> *2. *Std::Map - for storing distanceMap, predecessorMap.
>>> *3. *For weightMap:
>>> typedef struct weight_map_element
>>>         pair<int,double> edge;
>>>         double travel_time;
>>> weight_map_element_t;
>>> class weight_map
>>>     vector<weight_map_element_t> weight_map_set;
>>>     public:
>>>     void insert(weight_map_element_t element);
>>>     double get_travel_time(int edge_id, double start_time);
>>> *4. *std::priority_queue  for the priority queue that will be used for
>>> dijkstra search.
> Well,
> The std::prority_queue does not support the decrease_key operation which
> will be needed for the dijkstra search. I dont think stl provides a heap
> data structure with decrease_key, delete_min and insert operations.
> The make_heap, and sort_heap would be too costly to maintain for dijkstra.
Forgot to mention that - make_heap() and sort_heap() are provided by stl
algorithms.But as mentioned, it would be very costly and inefficient to use
sort_heap() each time.
> Do you have any idea of open-source library that provides the heap
> datastructure with above functionality?
> I am thinking of implementing binary heap myself to support the required
> functionality.
> Thoughts?
>>> Will this be sufficient for our implementation?  If yes, I will come up
>>> with the detailed internal function prototypes soon.
>>> On Wed, May 18, 2011 at 8:09 PM, Stephen Woodbridge
>>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>>>    On 5/18/2011 8:08 AM, Jay Mahadeokar wrote:
>>>        Hi,
>>>        I think what we need is a function on following lines:
>>>        Given a query_start_time, it should query the TimeDepCosts
>>>        table, and
>>>        return the set of entries which have their start_time within
>>>        query_start_time + delta. This delta might be x hours, depending
>>>        on the
>>>        upper bound of the expected journey time.
>>>        We need following things handled in our model:
>>>        If query_start_time is 11PM Sunday and delta is 10 hours, we
>>>        will need
>>>        to query entries with start time between 11PM Sunday and 9AM
>>>        Monday. So,
>>>        basically the function needs to be periodic in terms of
>>>        time_of_day and
>>>        day_of_week.
>>>        As Steve suggested, we can maintain conventions for day_of_week
>>>        like:
>>>        -3   - holidays
>>>        -2   - weekend days
>>>        -1   - week days
>>>        0    - all days
>>>        1-7 Mon - Sun.
>>>        If we just assume entries for -3,-2,-1,0 and ignore each entry
>>>        for Sun -
>>>        Sat, that would reduce the space required assuming that the
>>>        entries for
>>>        weekdays is same. If times for different weekdays is different
>>>        then we
>>>        would have separate entries for each day.
>>>        So, the query should properly examine the query_day_of_week and
>>>        select
>>>        the proper entries. Ex: For above query, if it is sunday, then
>>> after
>>>        12AM, next entries will be queried with time_of_day as -1, but
>>>        if it was
>>>        Saturday, next entries will be queried with time_of_day as -2.
>>>        We can have a boolean parameter like *isHoliday* in query
>>>        itself, which
>>>        will tell if a given day (may be weekday) is holiday or not.Then
>>>        again
>>>        the query will have to be modified accordingly (query for -3).
>>>        This will
>>>        take care of query for local holiday etc and we do not have to
>>> worry
>>>        about calenders. The user will have to worry about that.. :-)
>>>    This (isHoliday) might work for a single day, but will not work if
>>>    the query crosses into the next day(s). Holidays are an input
>>>    convenience to describe recurring events. So say we have a
>>>    convenient way to input that data and store it into tables as we
>>>    have described, then the query for costs would need to decide is a
>>>    given day is a holiday or not and then select the correct entries to
>>>    return based on that. For ease of implementation, we could just
>>>    start with a stub function the returns false and later implement a
>>>    table lookup based on the date or day of year that determines if
>>>    isHoliday=t/f for any given start_time+offset.
>>>    Then when querying schedules, for example, we would select holiday
>>>    schedules if they exist and its a holiday otherwise search the
>>>    regular tables.
>>>        There can be time_from and time_to entries as well. But, if we
>>>        just have
>>>        entries like:
>>>          day_of_week: -1, time_of_day: 00:01, 55mph
>>>          day_of_week: -1, time_of_day: 07:00, 30mph
>>>          day_of_week: -1, time_of_day: 10:01, 55mph
>>>          day_of_week: -1, time_of_day: 16:31, 30mph
>>>        we can assume that the entry with time_of_day 00:01 is valid upto
>>>        07:00.  And if query_start_time is 02:00 and delta is 10 hours,
>>>        we can
>>>        query entries which have time_of_day < query_start_time + delta
>>>        (taking
>>>        care of change of day).
>>>        Is this assumption reasonable?
>>>    This sounds reasonable if the response is in units of time (offset)
>>>    from query_start_time. Assuming we use a resolution of seconds, then
>>>    the response would be in seconds from start time.
>>>        *weightMap Abstraction*
>>>        I think the design would be more modular if we keep the weightMap
>>>        independent of the underlying time conventions. Since as Daniel
>>>        pointed
>>>        out, this algorithm can also be used for non-road networks.
>>>        So, whatever the underlying time conventions, we can assume that
>>>        in the
>>>        end the query should return pairs like:
>>>        < <edgeId, offset_time> , travel_time/speed >
>>>        We will assume that query_start_time is 0, i.e we offset every
>>>        thing by
>>>        query_start_time.
>>>        The offset_time will be as follows:
>>>        As in above example,
>>>        If start_tme is 02:00 and day_of_week is -1, and delta as 10
>>> hours.
>>>        Then, edge entries for edgeId 1 will be:
>>>        < <1, 05:00 > , 30 mph>
>>>        < <1, 08:01 > , 55 mph>
>>>        < <1, 14:31 > , 30 mph>
>>>        Basically, the offset_time will abstract out any internal details
>>> of
>>>        weekdays, change of days etc and it will just contain the offset
>>>        from
>>>        start_time.
>>>    I suggested seconds above, but if someone is modeling events in say
>>>    glacier flow, geological times or the big bang, they might need
>>>    other units of time. I would say that because we are talking about
>>>    time based schedules and need to deal with days, hours minutes we
>>>    should probably not worry about these other timeframes as the solver
>>>    will be offset based it will work with any units and then only the
>>>    wrappers for extracting the costs from the schedules would need to
>>>    change to deal with other timeframes. So lets not get hung up on
>>>    this, I think this is a sound plan.
>>>    -Steve
>>>        This will greatly simplify the core time dependent dijkstra
>>>        implementation.
>>>        Thoughts?
>>>        On Wed, May 18, 2011 at 10:46 AM, Stephen Woodbridge
>>>        <mailto:woodbri at swoodbridge.com>>> wrote:
>>>            Hi Daniel,
>>>            These are good points.
>>>            I agree that turn restrictions should be thought about but
>>> only
>>>            implemented if there is time. I think we should take the
>>>        discussion
>>>            of turn restriction into a separate thread. I'm interested
>>>        in what
>>>            you think is a limitation that can't be modeled in Dijkstra
>>>        or A*.
>>>            Regarding the time modeling, my point was just that we
>>>        needed more
>>>            thought there and a richer model developed. The crontab
>>>        model is a
>>>            good idea. I'm not opposed to modeling monthly or yearly
>>>        events, but
>>>            they rarely exist other than holidays which I tried to
>>>        capture. I
>>>            suppose you could model something like the Boston Marathon
>>>        and model
>>>            all the road closures and restrictions, but it seems to be a
>>>        lot of
>>>            work for a one day event, but I can see city government's
>>>        deploying
>>>            the resources to model something like this.
>>>            Regarding timezones: Times need to be entered with zones for
>>>        models
>>>            that cross zones but all the data should be converted to UTC
>>>            internally so it runs in a consistent time model. Timezones
>>>        are for
>>>            input and output, but the solver should be ignorant of them,
>>>        in my
>>>            opinion.
>>>            I have carried my GPS from the Eastern to central time zone,
>>>        and it
>>>            knew the local time when I powered it up. So my guess is that
>>> it
>>>            would auto correct when crossing the time zone.
>>>            -Steve
>>>            On 5/17/2011 10:42 PM, Daniel Kastl wrote:
>>>                Hi Jay and Steve,
>>>                This looks really nice, but let me give some comments
>>>        regarding
>>>                how to
>>>                model time, because this is really tricky in my opinion.
>>>                Especially when
>>>                thinking about an abstract network that isn't a road
>>>        network.
>>>                    Would it be possible to support turn restrictions in
>>>        the static
>>>                    Dijkstra also? I'm thinking just use all the same
>>>        structures but
>>>                    ignore the the time components to keep things
>>>        simple. So if
>>>                the the
>>>                    turn restrictions table is present we use it,
>>> otherwise
>>>                assume no
>>>                    restrictions. If doing static shortest path with turn
>>>                restrictions
>>>                    then ignore the time components otherwise we use
>>>        them. And
>>>                it is up
>>>                    to the user to make sure the turn restriction table
>>>        is valid
>>>                for the
>>>                    analysis being requested.
>>>                Currently in pgRouting Dijkstra and A* don't support turn
>>>                restrictions
>>>                modelling. What I actually like on Shooting Star is, that
>>> it
>>>                routes from
>>>                edge to edge instead of node to node. So it allows to
>>> model
>>>                relations
>>>                between edges rather than nodes, which I think is more
>>>        close to how
>>>                humans would think of this.
>>>                Dijkstra can only visit one node one times (as Shooting
>>> star
>>>                only visits
>>>                an edge once). Well, there can be turn restriction cases
>>>        where a
>>>                node is
>>>                passed twice and which can't be done correctly with
>>>        Dijkstra as
>>>                far as I
>>>                know.
>>>                In the beginning I wouldn't think about the turn
>>>        restrictions
>>>                too much.
>>>                Let's take it as an extra when we see we still have
>>>        enough time.
>>>                Of course if you have a good idea to implement it all at
>>>        once
>>>                with only
>>>                little extra work, then that's fine.
>>>                    For time definitions in your tables I think you need
>>>        to probably
>>>                    define some common structure for handling a time
>>> entry.
>>>                Another problem might be time zones. Plain day field +
>>> time
>>>                field might
>>>                not be able to allow driving from one time zone to
>>>        another (or just
>>>                think about a flight network). I never went from one
>>>        timezone to
>>>                another
>>>                by car or train, but Steve and Anton, you might have this
>>>                experience.
>>>                How does car navigation software handle this when you
>>>        cross the
>>>                timezone
>>>                border? ;-)
>>>                So taking "timestamp with timezone" for those fields
>>>        might be a good
>>>                idea to be able to support such a functionality.
>>>                    For example time_from and time_to might need to be
>>>        defined as a
>>>                    structure that includes day_of_week. day_of week
>>>        might take
>>>                values like:
>>>                    -3   - holidays
>>>                    -2   - weekend days
>>>                    -1   - week days
>>>                    0    - all days
>>>                    1..7 - Sun,...,Sat
>>>                I think the problem here is how to model recurring time
>>>                dependent costs,
>>>                right?
>>>                If you think about weekdays, then you can't for example
>>>        model
>>>                monthly or
>>>                yearly events.
>>>                I'm not really sure this is useful information here, but
>>>        I once saw
>>>                about how the "iCal" format models recurring calendar
>>>        events:
>>> http://ext.ensible.com/deploy/dev/examples/calendar/recurrence-widget.html
>>>                Maybe we can learn something from there. The example
>>>        needed to be
>>>                extended with some duration probably. But looking about
>>>        calendar
>>>                formats
>>>                might be a good idea to model holidays etc.
>>>                Or another (stupid) example would be cron job syntax.
>>>        Something
>>>                I always
>>>                need to google for as I can't remember it ;-)
>>>                All this time dependent stuff, events and schedules is
>>>        also an
>>>                issue in
>>>                Darp solver.
>>>                And it probably is important also for the multi-modal
>>>        routing,
>>>                so if we
>>>                can find some clever way how to model this and can share
>>>        it between
>>>                algorihtms, that would be great.
>>>                Daniel
>>>                Georepublic UG & Georepublic Japan
>>>                eMail: daniel.kastl at georepublic.de
>>>        <mailto:daniel.kastl at georepublic.de>
>>>        <mailto:daniel.kastl at georepublic.de>>
>>>        <mailto:daniel.kastl at georepublic.de>>>
>>>                Web: http://georepublic.de <http://georepublic.de/>
>>>                _______________________________________________
>>>                pgrouting-dev mailing list
>>>        pgrouting-dev at lists.osgeo.org
>>>        <mailto:pgrouting-dev at lists.osgeo.org>
>>>        <mailto:pgrouting-dev at lists.osgeo.org>>
>>>        http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>>>        Regards,
>>>        -Jay Mahadeokar
>>>        pgrouting-dev at lists.osgeo.org <mailto:
>>>    pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
>>> Regards,
>>> -Jay Mahadeokar
> Regards,
> -Jay Mahadeokar
Regards,
-Jay Mahadeokar
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110525/e81a3690/attachment-0001.html
More information about the pgrouting-dev mailing list
