[pgrouting-dev] Re: Implementation of core Time Dependent Dijkstra function
Jay Mahadeokar jai.mahadeokar at gmail.com
Tue May 24 23:58:56 EDT 2011
On Wed, May 25, 2011 at 8:47 AM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> On 5/24/2011 7:06 PM, Jay Mahadeokar wrote:
>> On Mon, May 23, 2011 at 8:03 PM, Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>>    I'm not a C++ programmer, but from what I have read on the boost
>>    list, it seems that the path to writing generic templates is to
>>    write the code first in regular C++ so it works and then refactor it
>>    to be more generic. So step 1 is to do as you proposed.
>>    Also since this project is to implement a "time dependent dijkstra
>>    algorithm" in pgRouting, the generic templates seems to be out of
>>    scope. It would be fine to do if you had the time and skill, but I
>>    think your approach makes sense, use the tools that make your job
>>    easier and allow you to achieve success.
>>    Any contrary opinions to this?
>>    -Steve
>>    On 5/23/2011 10:20 AM, Jay Mahadeokar wrote:
>>        Hi,
>>        As initially discussed, I was trying to reuse the boost's
>>        dijkstra code
>>        to write the core time dependent dijkstra algorithm.
>>        Since Boost makes extensive use of generic programming, and I
>>        have no
>>        prior experience with such deep generic programming concepts, I was
>>        wondering if we really need all these features that boost provides.
>>        Another option would be to write the time-dependent dijkstra on
>>        our own.
>>        This will be a light-weight code without extensive use of generic
>>        programming like boost.
>>        So, i was thinking of using following:
>>        *1. *Boost::AdjecencyList - for storing graph.
>>        *2. *Std::Map - for storing distanceMap, predecessorMap.
>>        *3. *For weightMap:
>>        typedef struct weight_map_element
>>                 pair<int,double> edge;
>>                 double travel_time;
>>        weight_map_element_t;
>>        class weight_map
>>             vector<weight_map_element_t> weight_map_set;
>>             public:
>>             void insert(weight_map_element_t element);
>>             double get_travel_time(int edge_id, double start_time);
>>        *4. *std::priority_queue  for the priority queue that will be
>>        used for
>>        dijkstra search.
>> Well,
>> The std::prority_queue does not support the decrease_key operation which
>> will be needed for the dijkstra search. I dont think stl provides a heap
>> data structure with decrease_key, delete_min and insert operations.
>> The make_heap, and sort_heap would be too costly to maintain for dijkstra.
>> Do you have any idea of open-source library that provides the heap
>> datastructure with above functionality?
>> I am thinking of implementing binary heap myself to support the required
>> functionality.
>> Thoughts?
> Jay,
> What about looking at the code in Booost Graph that does this. There is
> probably some generic template code, but maybe you can just reuse the
> algorithms and recode your own specific to this problem implementation.
> Ashraf,
> You implemented your own Dijkstra algorithm in OpenGraphRouter, can you
> point Jay to your code there so that he can assess reusing some of that fore
> this project. I think the following might do the trick
> http://sourceforge.net/projects/opengraphrouter/
> Look here at ShortestPathDikjstra.cpp, it looks like Ashraf is using a
> Boost Mutable Queue:
> http://opengraphrouter.svn.sourceforge.net/viewvc/opengraphrouter/tags/Newstructure/tags/gsoc2009/src/?pathrev=111
Thanks Steve for the suggestion. I actually implemented a BinaryHeap class
for exact requirements, and it seems to be solving the purpose.
The basic functions in class are:
class binary_heap
    vector<Vertex> heap;
    void heapify(int index);
    public:
    void insert(Vertex v);  //inserts v into heap and rebalances it so that
heap property is maintained.
    double decrease_key(int index, double delta); // Decreases key of vertex
with id = index, by delta.
    Vertex delete_min();  //deletes the min key vertex and rebalances heap.
Note that in binary heap all above operations need O(log n) time.
I will complete the initial draft of the algorithm soon and update it on
github in next few days.
We can see what else is needed then.
-Steve
>         Will this be sufficient for our implementation?  If yes, I will
>>        come up
>>        with the detailed internal function prototypes soon.
>>        On Wed, May 18, 2011 at 8:09 PM, Stephen Woodbridge
>>        <mailto:woodbri at swoodbridge.com>>> wrote:
>>            On 5/18/2011 8:08 AM, Jay Mahadeokar wrote:
>>                Hi,
>>                I think what we need is a function on following lines:
>>                Given a query_start_time, it should query the TimeDepCosts
>>                table, and
>>                return the set of entries which have their start_time
>> within
>>                query_start_time + delta. This delta might be x hours,
>>        depending
>>                on the
>>                upper bound of the expected journey time.
>>                We need following things handled in our model:
>>                If query_start_time is 11PM Sunday and delta is 10 hours,
>> we
>>                will need
>>                to query entries with start time between 11PM Sunday and
>> 9AM
>>                Monday. So,
>>                basically the function needs to be periodic in terms of
>>                time_of_day and
>>                day_of_week.
>>                As Steve suggested, we can maintain conventions for
>>        day_of_week
>>                like:
>>                -3   - holidays
>>                -2   - weekend days
>>                -1   - week days
>>                0    - all days
>>                1-7 Mon - Sun.
>>                If we just assume entries for -3,-2,-1,0 and ignore each
>>        entry
>>                for Sun -
>>                Sat, that would reduce the space required assuming that the
>>                entries for
>>                weekdays is same. If times for different weekdays is
>>        different
>>                then we
>>                would have separate entries for each day.
>>                So, the query should properly examine the
>>        query_day_of_week and
>>                select
>>                the proper entries. Ex: For above query, if it is
>>        sunday, then after
>>                12AM, next entries will be queried with time_of_day as
>>        -1, but
>>                if it was
>>                Saturday, next entries will be queried with time_of_day
>>        as -2.
>>                We can have a boolean parameter like *isHoliday* in query
>>                itself, which
>>                will tell if a given day (may be weekday) is holiday or
>>        not.Then
>>                again
>>                the query will have to be modified accordingly (query
>>        for -3).
>>                This will
>>                take care of query for local holiday etc and we do not
>>        have to worry
>>                about calenders. The user will have to worry about
>>        that.. :-)
>>            This (isHoliday) might work for a single day, but will not
>>        work if
>>            the query crosses into the next day(s). Holidays are an input
>>            convenience to describe recurring events. So say we have a
>>            convenient way to input that data and store it into tables as
>> we
>>            have described, then the query for costs would need to
>>        decide is a
>>            given day is a holiday or not and then select the correct
>>        entries to
>>            return based on that. For ease of implementation, we could just
>>            start with a stub function the returns false and later
>>        implement a
>>            table lookup based on the date or day of year that determines
>> if
>>            isHoliday=t/f for any given start_time+offset.
>>            Then when querying schedules, for example, we would select
>>        holiday
>>            schedules if they exist and its a holiday otherwise search the
>>            regular tables.
>>                There can be time_from and time_to entries as well. But,
>>        if we
>>                just have
>>                entries like:
>>                  day_of_week: -1, time_of_day: 00:01, 55mph
>>                  day_of_week: -1, time_of_day: 07:00, 30mph
>>                  day_of_week: -1, time_of_day: 10:01, 55mph
>>                  day_of_week: -1, time_of_day: 16:31, 30mph
>>                we can assume that the entry with time_of_day 00:01 is
>>        valid upto
>>                07:00.  And if query_start_time is 02:00 and delta is 10
>>        hours,
>>                we can
>>                query entries which have time_of_day < query_start_time
>>        + delta
>>                (taking
>>                care of change of day).
>>                Is this assumption reasonable?
>>            This sounds reasonable if the response is in units of time
>>        (offset)
>>            from query_start_time. Assuming we use a resolution of
>>        seconds, then
>>            the response would be in seconds from start time.
>>                *weightMap Abstraction*
>>                I think the design would be more modular if we keep the
>>        weightMap
>>                independent of the underlying time conventions. Since as
>>        Daniel
>>                pointed
>>                out, this algorithm can also be used for non-road networks.
>>                So, whatever the underlying time conventions, we can
>>        assume that
>>                in the
>>                end the query should return pairs like:
>>        < <edgeId, offset_time> , travel_time/speed >
>>                We will assume that query_start_time is 0, i.e we offset
>>        every
>>                thing by
>>                query_start_time.
>>                The offset_time will be as follows:
>>                As in above example,
>>                If start_tme is 02:00 and day_of_week is -1, and delta
>>        as 10 hours.
>>                Then, edge entries for edgeId 1 will be:
>>        < <1, 05:00 > , 30 mph>
>>        < <1, 08:01 > , 55 mph>
>>        < <1, 14:31 > , 30 mph>
>>                Basically, the offset_time will abstract out any
>>        internal details of
>>                weekdays, change of days etc and it will just contain
>>        the offset
>>                from
>>                start_time.
>>            I suggested seconds above, but if someone is modeling events
>>        in say
>>            glacier flow, geological times or the big bang, they might need
>>            other units of time. I would say that because we are talking
>>        about
>>            time based schedules and need to deal with days, hours
>>        minutes we
>>            should probably not worry about these other timeframes as
>>        the solver
>>            will be offset based it will work with any units and then
>>        only the
>>            wrappers for extracting the costs from the schedules would
>>        need to
>>            change to deal with other timeframes. So lets not get hung up
>> on
>>            this, I think this is a sound plan.
>>            -Steve
>>                This will greatly simplify the core time dependent dijkstra
>>                implementation.
>>                Thoughts?
>>                On Wed, May 18, 2011 at 10:46 AM, Stephen Woodbridge
>>        <mailto:woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>>
>>        <mailto:woodbri at swoodbridge.com>>>> wrote:
>>                    Hi Daniel,
>>                    These are good points.
>>                    I agree that turn restrictions should be thought
>>        about but only
>>                    implemented if there is time. I think we should take
>> the
>>                discussion
>>                    of turn restriction into a separate thread. I'm
>>        interested
>>                in what
>>                    you think is a limitation that can't be modeled in
>>        Dijkstra
>>                or A*.
>>                    Regarding the time modeling, my point was just that we
>>                needed more
>>                    thought there and a richer model developed. The crontab
>>                model is a
>>                    good idea. I'm not opposed to modeling monthly or
>> yearly
>>                events, but
>>                    they rarely exist other than holidays which I tried to
>>                capture. I
>>                    suppose you could model something like the Boston
>>        Marathon
>>                and model
>>                    all the road closures and restrictions, but it seems
>>        to be a
>>                lot of
>>                    work for a one day event, but I can see city
>>        government's
>>                deploying
>>                    the resources to model something like this.
>>                    Regarding timezones: Times need to be entered with
>>        zones for
>>                models
>>                    that cross zones but all the data should be
>>        converted to UTC
>>                    internally so it runs in a consistent time model.
>>        Timezones
>>                are for
>>                    input and output, but the solver should be ignorant
>>        of them,
>>                in my
>>                    opinion.
>>                    I have carried my GPS from the Eastern to central
>>        time zone,
>>                and it
>>                    knew the local time when I powered it up. So my
>>        guess is that it
>>                    would auto correct when crossing the time zone.
>>                    -Steve
>>                    On 5/17/2011 10:42 PM, Daniel Kastl wrote:
>>                        Hi Jay and Steve,
>>                        This looks really nice, but let me give some
>>        comments
>>                regarding
>>                        how to
>>                        model time, because this is really tricky in my
>>        opinion.
>>                        Especially when
>>                        thinking about an abstract network that isn't a
>> road
>>                network.
>>                            Would it be possible to support turn
>>        restrictions in
>>                the static
>>                            Dijkstra also? I'm thinking just use all the
>>        same
>>                structures but
>>                            ignore the the time components to keep things
>>                simple. So if
>>                        the the
>>                            turn restrictions table is present we use
>>        it, otherwise
>>                        assume no
>>                            restrictions. If doing static shortest path
>>        with turn
>>                        restrictions
>>                            then ignore the time components otherwise we
>> use
>>                them. And
>>                        it is up
>>                            to the user to make sure the turn
>>        restriction table
>>                is valid
>>                        for the
>>                            analysis being requested.
>>                        Currently in pgRouting Dijkstra and A* don't
>>        support turn
>>                        restrictions
>>                        modelling. What I actually like on Shooting Star
>>        is, that it
>>                        routes from
>>                        edge to edge instead of node to node. So it
>>        allows to model
>>                        relations
>>                        between edges rather than nodes, which I think
>>        is more
>>                close to how
>>                        humans would think of this.
>>                        Dijkstra can only visit one node one times (as
>>        Shooting star
>>                        only visits
>>                        an edge once). Well, there can be turn
>>        restriction cases
>>                where a
>>                        node is
>>                        passed twice and which can't be done correctly with
>>                Dijkstra as
>>                        far as I
>>                        know.
>>                        In the beginning I wouldn't think about the turn
>>                restrictions
>>                        too much.
>>                        Let's take it as an extra when we see we still have
>>                enough time.
>>                        Of course if you have a good idea to implement
>>        it all at
>>                once
>>                        with only
>>                        little extra work, then that's fine.
>>                            For time definitions in your tables I think
>>        you need
>>                to probably
>>                            define some common structure for handling a
>>        time entry.
>>                        Another problem might be time zones. Plain day
>>        field + time
>>                        field might
>>                        not be able to allow driving from one time zone to
>>                another (or just
>>                        think about a flight network). I never went from
>> one
>>                timezone to
>>                        another
>>                        by car or train, but Steve and Anton, you might
>>        have this
>>                        experience.
>>                        How does car navigation software handle this
>>        when you
>>                cross the
>>                        timezone
>>                        border? ;-)
>>                        So taking "timestamp with timezone" for those
>> fields
>>                might be a good
>>                        idea to be able to support such a functionality.
>>                            For example time_from and time_to might need
>>        to be
>>                defined as a
>>                            structure that includes day_of_week. day_of
>> week
>>                might take
>>                        values like:
>>                            -3   - holidays
>>                            -2   - weekend days
>>                            -1   - week days
>>                            0    - all days
>>                            1..7 - Sun,...,Sat
>>                        I think the problem here is how to model
>>        recurring time
>>                        dependent costs,
>>                        right?
>>                        If you think about weekdays, then you can't for
>>        example
>>                model
>>                        monthly or
>>                        yearly events.
>>                        I'm not really sure this is useful information
>>        here, but
>>                I once saw
>>                        about how the "iCal" format models recurring
>>        calendar
>>                events:
>> http://ext.ensible.com/deploy/dev/examples/calendar/recurrence-widget.html
>>                        Maybe we can learn something from there. The
>> example
>>                needed to be
>>                        extended with some duration probably. But
>>        looking about
>>                calendar
>>                        formats
>>                        might be a good idea to model holidays etc.
>>                        Or another (stupid) example would be cron job
>>        syntax.
>>                Something
>>                        I always
>>                        need to google for as I can't remember it ;-)
>>                        All this time dependent stuff, events and
>>        schedules is
>>                also an
>>                        issue in
>>                        Darp solver.
>>                        And it probably is important also for the
>>        multi-modal
>>                routing,
>>                        so if we
>>                        can find some clever way how to model this and
>>        can share
>>                it between
>>                        algorihtms, that would be great.
>>                        Daniel
>>  _______________________________________________
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Regards,
-Jay Mahadeokar
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110525/bfa5f93a/attachment-0001.html
More information about the pgrouting-dev mailing list
