[pgrouting-dev] Re: Implementation of core Time Dependent Dijkstra function
Jay Mahadeokar jai.mahadeokar at gmail.com
Wed May 25 19:27:04 EDT 2011
I have coded a initial draft of the core tdsp algorithm. I have implemented
a binary heap for doing delete_min() and decrease_key() to guide the
dijkstra search.
Also, used many data structures like weight_map - for storing time dependent
edge traversal times
edge_wrapper - for mapping edge ids with source and target vertex.
For graph, I have used boost adjecency list - since it helps in fast lookup
of out-edges in any node during dijkstra search.
The distance map and predecessor map are types of std::map.
I have tested on a small dummy graph. The graph is currently read from a
file. Format:
*Graph Input convension:*
Line1 contains 3 integers: V E R    -V is no of vertices, E - edges and R -
the discrete range of values.
Next V lines have following format:
Start with integer e denoting number of edges going out from that vertex.
And next e values in same
line tell the target vertex of edge.
Next we have E*R lines each conaining 3 integers eid , start_time,
travel_time. These are used to generate
weight map.
Last line contains source id.
The distance_map and predecessor_map are printed.
You can find the code in /extra/tdsp/ folder. Test graph is in
/extra/tdsp/test_data folder.
To test, you can go to tdsp folder and do:
g++ -Wno-deprecated tdsp_core.cpp
./a.out < ./test_data/graph1.dat
*TODO:*
There will be many ways to optimize this code. I will list the possible
improvements soon.
Organise the code into header files etc.
Test for larger input graphs. Create test cases that cover all scenarios.
Thoughts / suggestions?
On Wed, May 25, 2011 at 9:28 AM, Jay Mahadeokar <jai.mahadeokar at gmail.com>wrote:
> On Wed, May 25, 2011 at 8:47 AM, Stephen Woodbridge <
> woodbri at swoodbridge.com> wrote:
>> On 5/24/2011 7:06 PM, Jay Mahadeokar wrote:
>>> On Mon, May 23, 2011 at 8:03 PM, Stephen Woodbridge
>>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>>>    I'm not a C++ programmer, but from what I have read on the boost
>>>    list, it seems that the path to writing generic templates is to
>>>    write the code first in regular C++ so it works and then refactor it
>>>    to be more generic. So step 1 is to do as you proposed.
>>>    Also since this project is to implement a "time dependent dijkstra
>>>    algorithm" in pgRouting, the generic templates seems to be out of
>>>    scope. It would be fine to do if you had the time and skill, but I
>>>    think your approach makes sense, use the tools that make your job
>>>    easier and allow you to achieve success.
>>>    Any contrary opinions to this?
>>>    -Steve
>>>    On 5/23/2011 10:20 AM, Jay Mahadeokar wrote:
>>>        Hi,
>>>        As initially discussed, I was trying to reuse the boost's
>>>        dijkstra code
>>>        to write the core time dependent dijkstra algorithm.
>>>        Since Boost makes extensive use of generic programming, and I
>>>        have no
>>>        prior experience with such deep generic programming concepts, I
>>> was
>>>        wondering if we really need all these features that boost
>>> provides.
>>>        Another option would be to write the time-dependent dijkstra on
>>>        our own.
>>>        This will be a light-weight code without extensive use of generic
>>>        programming like boost.
>>>        So, i was thinking of using following:
>>>        *1. *Boost::AdjecencyList - for storing graph.
>>>        *2. *Std::Map - for storing distanceMap, predecessorMap.
>>>        *3. *For weightMap:
>>>        typedef struct weight_map_element
>>>                 pair<int,double> edge;
>>>                 double travel_time;
>>>        weight_map_element_t;
>>>        class weight_map
>>>             vector<weight_map_element_t> weight_map_set;
>>>             public:
>>>             void insert(weight_map_element_t element);
>>>             double get_travel_time(int edge_id, double start_time);
>>>        *4. *std::priority_queue  for the priority queue that will be
>>>        used for
>>>        dijkstra search.
>>> Well,
>>> The std::prority_queue does not support the decrease_key operation which
>>> will be needed for the dijkstra search. I dont think stl provides a heap
>>> data structure with decrease_key, delete_min and insert operations.
>>> The make_heap, and sort_heap would be too costly to maintain for
>>> dijkstra.
>>> Do you have any idea of open-source library that provides the heap
>>> datastructure with above functionality?
>>> I am thinking of implementing binary heap myself to support the required
>>> functionality.
>>> Thoughts?
>> Jay,
>> What about looking at the code in Booost Graph that does this. There is
>> probably some generic template code, but maybe you can just reuse the
>> algorithms and recode your own specific to this problem implementation.
>> Ashraf,
>> You implemented your own Dijkstra algorithm in OpenGraphRouter, can you
>> point Jay to your code there so that he can assess reusing some of that fore
>> this project. I think the following might do the trick
>> http://sourceforge.net/projects/opengraphrouter/
>> Look here at ShortestPathDikjstra.cpp, it looks like Ashraf is using a
>> Boost Mutable Queue:
>> http://opengraphrouter.svn.sourceforge.net/viewvc/opengraphrouter/tags/Newstructure/tags/gsoc2009/src/?pathrev=111
> Thanks Steve for the suggestion. I actually implemented a BinaryHeap class
> for exact requirements, and it seems to be solving the purpose.
> The basic functions in class are:
> class binary_heap
>     vector<Vertex> heap;
>     void heapify(int index);
>     public:
>     void insert(Vertex v);  //inserts v into heap and rebalances it so that
> heap property is maintained.
>     double decrease_key(int index, double delta); // Decreases key of
> vertex with id = index, by delta.
>     Vertex delete_min();  //deletes the min key vertex and rebalances heap.
> Note that in binary heap all above operations need O(log n) time.
> I will complete the initial draft of the algorithm soon and update it on
> github in next few days.
> We can see what else is needed then.
> -Steve
>>         Will this be sufficient for our implementation?  If yes, I will
>>>        come up
>>>        with the detailed internal function prototypes soon.
>>>        On Wed, May 18, 2011 at 8:09 PM, Stephen Woodbridge
>>>        <mailto:woodbri at swoodbridge.com>>> wrote:
>>>            On 5/18/2011 8:08 AM, Jay Mahadeokar wrote:
>>>                Hi,
>>>                I think what we need is a function on following lines:
>>>                Given a query_start_time, it should query the TimeDepCosts
>>>                table, and
>>>                return the set of entries which have their start_time
>>> within
>>>                query_start_time + delta. This delta might be x hours,
>>>        depending
>>>                on the
>>>                upper bound of the expected journey time.
>>>                We need following things handled in our model:
>>>                If query_start_time is 11PM Sunday and delta is 10 hours,
>>> we
>>>                will need
>>>                to query entries with start time between 11PM Sunday and
>>> 9AM
>>>                Monday. So,
>>>                basically the function needs to be periodic in terms of
>>>                time_of_day and
>>>                day_of_week.
>>>                As Steve suggested, we can maintain conventions for
>>>        day_of_week
>>>                like:
>>>                -3   - holidays
>>>                -2   - weekend days
>>>                -1   - week days
>>>                0    - all days
>>>                1-7 Mon - Sun.
>>>                If we just assume entries for -3,-2,-1,0 and ignore each
>>>        entry
>>>                for Sun -
>>>                Sat, that would reduce the space required assuming that
>>> the
>>>                entries for
>>>                weekdays is same. If times for different weekdays is
>>>        different
>>>                then we
>>>                would have separate entries for each day.
>>>                So, the query should properly examine the
>>>        query_day_of_week and
>>>                select
>>>                the proper entries. Ex: For above query, if it is
>>>        sunday, then after
>>>                12AM, next entries will be queried with time_of_day as
>>>        -1, but
>>>                if it was
>>>                Saturday, next entries will be queried with time_of_day
>>>        as -2.
>>>                We can have a boolean parameter like *isHoliday* in query
>>>                itself, which
>>>                will tell if a given day (may be weekday) is holiday or
>>>        not.Then
>>>                again
>>>                the query will have to be modified accordingly (query
>>>        for -3).
>>>                This will
>>>                take care of query for local holiday etc and we do not
>>>        have to worry
>>>                about calenders. The user will have to worry about
>>>        that.. :-)
>>>            This (isHoliday) might work for a single day, but will not
>>>        work if
>>>            the query crosses into the next day(s). Holidays are an input
>>>            convenience to describe recurring events. So say we have a
>>>            convenient way to input that data and store it into tables as
>>> we
>>>            have described, then the query for costs would need to
>>>        decide is a
>>>            given day is a holiday or not and then select the correct
>>>        entries to
>>>            return based on that. For ease of implementation, we could
>>> just
>>>            start with a stub function the returns false and later
>>>        implement a
>>>            table lookup based on the date or day of year that determines
>>> if
>>>            isHoliday=t/f for any given start_time+offset.
>>>            Then when querying schedules, for example, we would select
>>>        holiday
>>>            schedules if they exist and its a holiday otherwise search the
>>>            regular tables.
>>>                There can be time_from and time_to entries as well. But,
>>>        if we
>>>                just have
>>>                entries like:
>>>                  day_of_week: -1, time_of_day: 00:01, 55mph
>>>                  day_of_week: -1, time_of_day: 07:00, 30mph
>>>                  day_of_week: -1, time_of_day: 10:01, 55mph
>>>                  day_of_week: -1, time_of_day: 16:31, 30mph
>>>                we can assume that the entry with time_of_day 00:01 is
>>>        valid upto
>>>                07:00.  And if query_start_time is 02:00 and delta is 10
>>>        hours,
>>>                we can
>>>                query entries which have time_of_day < query_start_time
>>>        + delta
>>>                (taking
>>>                care of change of day).
>>>                Is this assumption reasonable?
>>>            This sounds reasonable if the response is in units of time
>>>        (offset)
>>>            from query_start_time. Assuming we use a resolution of
>>>        seconds, then
>>>            the response would be in seconds from start time.
>>>                *weightMap Abstraction*
>>>                I think the design would be more modular if we keep the
>>>        weightMap
>>>                independent of the underlying time conventions. Since as
>>>        Daniel
>>>                pointed
>>>                out, this algorithm can also be used for non-road
>>> networks.
>>>                So, whatever the underlying time conventions, we can
>>>        assume that
>>>                in the
>>>                end the query should return pairs like:
>>>        < <edgeId, offset_time> , travel_time/speed >
>>>                We will assume that query_start_time is 0, i.e we offset
>>>        every
>>>                thing by
>>>                query_start_time.
>>>                The offset_time will be as follows:
>>>                As in above example,
>>>                If start_tme is 02:00 and day_of_week is -1, and delta
>>>        as 10 hours.
>>>                Then, edge entries for edgeId 1 will be:
>>>        < <1, 05:00 > , 30 mph>
>>>        < <1, 08:01 > , 55 mph>
>>>        < <1, 14:31 > , 30 mph>
>>>                Basically, the offset_time will abstract out any
>>>        internal details of
>>>                weekdays, change of days etc and it will just contain
>>>        the offset
>>>                from
>>>                start_time.
>>>            I suggested seconds above, but if someone is modeling events
>>>        in say
>>>            glacier flow, geological times or the big bang, they might
>>> need
>>>            other units of time. I would say that because we are talking
>>>        about
>>>            time based schedules and need to deal with days, hours
>>>        minutes we
>>>            should probably not worry about these other timeframes as
>>>        the solver
>>>            will be offset based it will work with any units and then
>>>        only the
>>>            wrappers for extracting the costs from the schedules would
>>>        need to
>>>            change to deal with other timeframes. So lets not get hung up
>>> on
>>>            this, I think this is a sound plan.
>>>            -Steve
>>>                This will greatly simplify the core time dependent
>>> dijkstra
>>>                implementation.
>>>                Thoughts?
>>>                On Wed, May 18, 2011 at 10:46 AM, Stephen Woodbridge
>>>        <mailto:woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>>
>>>        <mailto:woodbri at swoodbridge.com>>>> wrote:
>>>                    Hi Daniel,
>>>                    These are good points.
>>>                    I agree that turn restrictions should be thought
>>>        about but only
>>>                    implemented if there is time. I think we should take
>>> the
>>>                discussion
>>>                    of turn restriction into a separate thread. I'm
>>>        interested
>>>                in what
>>>                    you think is a limitation that can't be modeled in
>>>        Dijkstra
>>>                or A*.
>>>                    Regarding the time modeling, my point was just that we
>>>                needed more
>>>                    thought there and a richer model developed. The
>>> crontab
>>>                model is a
>>>                    good idea. I'm not opposed to modeling monthly or
>>> yearly
>>>                events, but
>>>                    they rarely exist other than holidays which I tried to
>>>                capture. I
>>>                    suppose you could model something like the Boston
>>>        Marathon
>>>                and model
>>>                    all the road closures and restrictions, but it seems
>>>        to be a
>>>                lot of
>>>                    work for a one day event, but I can see city
>>>        government's
>>>                deploying
>>>                    the resources to model something like this.
>>>                    Regarding timezones: Times need to be entered with
>>>        zones for
>>>                models
>>>                    that cross zones but all the data should be
>>>        converted to UTC
>>>                    internally so it runs in a consistent time model.
>>>        Timezones
>>>                are for
>>>                    input and output, but the solver should be ignorant
>>>        of them,
>>>                in my
>>>                    opinion.
>>>                    I have carried my GPS from the Eastern to central
>>>        time zone,
>>>                and it
>>>                    knew the local time when I powered it up. So my
>>>        guess is that it
>>>                    would auto correct when crossing the time zone.
>>>                    -Steve
>>>                    On 5/17/2011 10:42 PM, Daniel Kastl wrote:
>>>                        Hi Jay and Steve,
>>>                        This looks really nice, but let me give some
>>>        comments
>>>                regarding
>>>                        how to
>>>                        model time, because this is really tricky in my
>>>        opinion.
>>>                        Especially when
>>>                        thinking about an abstract network that isn't a
>>> road
>>>                network.
>>>                            Would it be possible to support turn
>>>        restrictions in
>>>                the static
>>>                            Dijkstra also? I'm thinking just use all the
>>>        same
>>>                structures but
>>>                            ignore the the time components to keep things
>>>                simple. So if
>>>                        the the
>>>                            turn restrictions table is present we use
>>>        it, otherwise
>>>                        assume no
>>>                            restrictions. If doing static shortest path
>>>        with turn
>>>                        restrictions
>>>                            then ignore the time components otherwise we
>>> use
>>>                them. And
>>>                        it is up
>>>                            to the user to make sure the turn
>>>        restriction table
>>>                is valid
>>>                        for the
>>>                            analysis being requested.
>>>                        Currently in pgRouting Dijkstra and A* don't
>>>        support turn
>>>                        restrictions
>>>                        modelling. What I actually like on Shooting Star
>>>        is, that it
>>>                        routes from
>>>                        edge to edge instead of node to node. So it
>>>        allows to model
>>>                        relations
>>>                        between edges rather than nodes, which I think
>>>        is more
>>>                close to how
>>>                        humans would think of this.
>>>                        Dijkstra can only visit one node one times (as
>>>        Shooting star
>>>                        only visits
>>>                        an edge once). Well, there can be turn
>>>        restriction cases
>>>                where a
>>>                        node is
>>>                        passed twice and which can't be done correctly
>>> with
>>>                Dijkstra as
>>>                        far as I
>>>                        know.
>>>                        In the beginning I wouldn't think about the turn
>>>                restrictions
>>>                        too much.
>>>                        Let's take it as an extra when we see we still
>>> have
>>>                enough time.
>>>                        Of course if you have a good idea to implement
>>>        it all at
>>>                once
>>>                        with only
>>>                        little extra work, then that's fine.
>>>                            For time definitions in your tables I think
>>>        you need
>>>                to probably
>>>                            define some common structure for handling a
>>>        time entry.
>>>                        Another problem might be time zones. Plain day
>>>        field + time
>>>                        field might
>>>                        not be able to allow driving from one time zone to
>>>                another (or just
>>>                        think about a flight network). I never went from
>>> one
>>>                timezone to
>>>                        another
>>>                        by car or train, but Steve and Anton, you might
>>>        have this
>>>                        experience.
>>>                        How does car navigation software handle this
>>>        when you
>>>                cross the
>>>                        timezone
>>>                        border? ;-)
>>>                        So taking "timestamp with timezone" for those
>>> fields
>>>                might be a good
>>>                        idea to be able to support such a functionality.
>>>                            For example time_from and time_to might need
>>>        to be
>>>                defined as a
>>>                            structure that includes day_of_week. day_of
>>> week
>>>                might take
>>>                        values like:
>>>                            -3   - holidays
>>>                            -2   - weekend days
>>>                            -1   - week days
>>>                            0    - all days
>>>                            1..7 - Sun,...,Sat
>>>                        I think the problem here is how to model
>>>        recurring time
>>>                        dependent costs,
>>>                        right?
>>>                        If you think about weekdays, then you can't for
>>>        example
>>>                model
>>>                        monthly or
>>>                        yearly events.
>>>                        I'm not really sure this is useful information
>>>        here, but
>>>                I once saw
>>>                        about how the "iCal" format models recurring
>>>        calendar
>>>                events:
>>> http://ext.ensible.com/deploy/dev/examples/calendar/recurrence-widget.html
>>>                        Maybe we can learn something from there. The
>>> example
>>>                needed to be
>>>                        extended with some duration probably. But
>>>        looking about
>>>                calendar
>>>                        formats
>>>                        might be a good idea to model holidays etc.
>>>                        Or another (stupid) example would be cron job
>>>        syntax.
>>>                Something
>>>                        I always
>>>                        need to google for as I can't remember it ;-)
>>>                        All this time dependent stuff, events and
>>>        schedules is
>>>                also an
>>>                        issue in
>>>                        Darp solver.
>>>                        And it probably is important also for the
>>>        multi-modal
>>>                routing,
>>>                        so if we
>>>                        can find some clever way how to model this and
>>>        can share
>>>                it between
>>>                        algorihtms, that would be great.
>>>                        Daniel
>>>  _______________________________________________
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> Regards,
> -Jay Mahadeokar
Regards,
-Jay Mahadeokar
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110526/66ab58dc/attachment-0001.html
More information about the pgrouting-dev mailing list
