[pgrouting-dev] Support for Time Constraints
Stephen Woodbridge woodbri at swoodbridge.com
Fri May 27 14:45:12 EDT 2011
Jay,
I have downloaded all the data for April 2011 for the California sensors
based on hourly stats from:
http://pems.dot.ca.gov/?dnode=State&content=dbx&tab=dbx_download
You have to create an account and login to get to the data.
Here is a description of the data fields:
http://pems.dot.ca.gov/Help/context.phtml?content=ctx&dnode=State&topic=dbx#text-station_hour
You can also download raw sensor data, 5 min, 1 hr, 1 day data
summaries. It's a lot of data! If someone wanted to get fancy/crazy?
they could download a years worth of data or multiple years and then try
to summarize that in hourly data by day of week, holidays, etc.
Each sensor is located by both a lat/long position and a description and
has average speed over the interval being collected, into addition to
number of lanes, and vehicle counts.
There are 9 separate coverage areas in California that the data is
grouped into.
My thought is to some day I'll do something with this data if I can get
a routable data set for California maybe able to use OSM data for this.
-Steve
On 5/27/2011 10:42 AM, Stephen Woodbridge wrote:
> Correction: TMC - Traffic Message Channel or Traffic Management Center
> On 5/27/2011 10:18 AM, Stephen Woodbridge wrote:
>> Jay,
>> Trying to narrow down some google searches this looks like it might have
>> some promising candidates:
>> http://www.google.com/#q=traffic+data+feed+data+standards+tmc+adms
>> ADMS - Archived Data Management Systems
>> TMC - Traffic control centers
>> This looks like a potential site for getting archived real-time data:
>> https://pems.eecs.berkeley.edu/?redirect=%2F%3Fdnode%3DState
>> So from a project point of view, I'm not sure it is a good idea to spend
>> much time research potential data sources and coding tools to summarize
>> the data into tables. While this is clearly interesting and might be a
>> good ideas after GSoC, I think it might be a huge time sync and it would
>> be better to just make some test networks by hand.
>> One of the problems you will run into with most if not all of these
>> sites, is mapping sensors to edges. This might not be hard if the supply
>> the lat/lon of the sensor, but in may cases I think they just supply a
>> textual description of the sense and you have to map that to a edge.
>> -Steve
>> On 5/26/2011 11:31 PM, Jay Mahadeokar wrote:
>>> Hi,
>>> We had discussed some possible ways of getting the test time-dependent
>>> data, but reached no particular solution.
>>> I found this link: http://bhelp.traffic.com/
>>> It a Navteq service and provides live traffic information. You need to
>>> login, and then you can browse live traffic.
>>> You can select each road and get following info:
>>> - Jam factor
>>> - Drive time now
>>> - delay
>>> - speed limit
>>> - average speed
>>> I guess, this is exactly what we need. Even if we can record the
>>> drive-time now, for each road at intervals of 1 hour each for a
>>> particular city, we will have significant time dependent data.
>>> I browsed the website but did not find any link where this data is made
>>> available. Is there any way to record this data? Any starting points?
>>> On Thu, Apr 7, 2011 at 10:05 PM, Jay Mahadeokar
>>> <jai.mahadeokar at gmail.com <mailto:jai.mahadeokar at gmail.com>> wrote:
>>> Hello all,
>>> Just an update - as Daniel suggested I posted a query about
>>> time-Dependent data in OSM routing list. It seems they dont have
>>> such data, but people have posted some things that might be useful
>>> for us in future. Here is link to the discussion -
>>> http://lists.openstreetmap.org/pipermail/routing/2011-April/001127.html
>>> You may want to have a look there.
>>> Sorry for the delayed replies, presently, I am a bit occupied by
>>> college submissions. I will go through the links and the ideas
>>> proposed here by Daniel and Steve soon. As already said I guess we
>>> need to put a lot of thought in designing the data model, that would
>>> be easy for users to use, robust and flexible for different
>>> applications, and at the same time efficient in terms of query and
>>> processing time. I will try and come up with thoughts on that soon.
>>> Regarding Navteq data, the website says that only one data-set will
>>> be allowed to download. So, I was wondering which data should be
>>> preferred. Also, there are various data-formats that Navteq provides
>>> data in. Steve, have you downloaded any data which specifically has
>>> time-dependent edge weights?
>>> Though we will not want the module to follow Navteq standards, any
>>> time-dependent data would be very helpful for me, since I also want
>>> to try out some heuristics on that as part of my thesis. The work
>>> done by R. Geisberger, P. Sanders and others is experimented on the
>>> Germany data provided by PTV AG
>>> http://www.ptvag.com/company/contact/. I have requested them data
>>> for research purposes. Have you worked with their data by any chance?
>>> Regards,
>>> On Tue, Apr 5, 2011 at 8:05 PM, Stephen Woodbridge
>>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>>> On 4/5/2011 1:37 AM, Daniel Kastl wrote:
>>> Hi Jay,
>>> As Steve said, Navteq sample data is one possibility ... and
>>> it's better
>>> than nothing ;-)
>>> Well, I think we should avoid to support a single data
>>> provider, because
>>> who tells that the format they defined several years ago is
>>> the most
>>> suitable one. It might work perfectly for Navteq and road
>>> networks in
>>> countries they are operating, but this doesn't say there
>>> won't be a more
>>> clever way to store such an information.
>>> I think it will be always necessary to transform data into a
>>> format
>>> pgRouting algorithms can handle. So it's OK in my opinion to
>>> define some
>>> convenient format if there isn't an existing standard
>>> already (which
>>> doesn't exist afaik).
>>> But Navteq is good data for testing, I agree. For the
>>> beginning I think
>>> it might be even too complex model, as Steve mentioned there
>>> are even
>>> time dependent turn restrictions.
>>> I think that the value in looking at Navteq is not to use it
>>> all, but that it is a concrete data model that expresses all the
>>> various routing characteristics that you might run into in other
>>> data sets. Navteq has been the basis for almost all routing
>>> solution during the past 10-15 years. There are now others like
>>> TeleAtlas, and even OSM. So look it over and use as much or as
>>> little as you need to get started. Designing a data model is
>>> very complex and you can not do it in the abstract - you need to
>>> know what you are modeling.
>>> As far as defining an data model that is easy for users to work
>>> with, keep the tables simple to understand and load with data.
>>> It is better to have 5 simple to work with tables than 1-2
>>> complex ones. If you need to transform the data inside then have
>>> a preparation function that reads the user tables and applies
>>> them to the graph. So examples of user tables might be:
>>> o bus, train, ferry, airline schedules
>>> o live traffic data table
>>> o historical speed estimates by day/time (as Daniel mentions below)
>>> o transfer rules - required pre-deparature arrival time when
>>> transferring to a different transportation mode and
>>> post-scheduled arrival wait time when transferring from a mode.
>>> EG, must arrive at airport 2 hr before flight departure and
>>> allow 45 mins after arrival to collect baggage or longer on
>>> international flights. (this might not apply to your specific
>>> problem)
>>> A good place to discuss such a question might be also the
>>> "OSM routing"
>>> mailing list. In the worst case nobody will answer. But
>>> maybe you will
>>> start a long discussion as there are several people very
>>> interested in
>>> routing related topics. OSM data would be nice, if we could
>>> make use of
>>> it, but I fear that not many mappers really think about
>>> time-dependent attributes. Probably in Germany you can find
>>> such a data.
>>> Yes, working with OSM is another good possibility.
>>> I thought a bit about some possible cases for time dependent
>>> road networks:
>>> * In Japan a big issue for navigation software are so
>>> called "School
>>> Zones", which are areas around schools obviously,
>>> which are closed
>>> for motorized traffic at certain times in the morning.
>>> * In Europe I know about pedestrian areas for example,
>>> which can be
>>> used for delivery of goods after regular business
>>> hours. Or heavy
>>> trucks are not allowed to access roads during certain
>>> times.
>>> * Some highways/roads in Germany have a speed limit
>>> during night time
>>> * Ferry services might only operate during day time (so
>>> if you
>>> missed the last ferry, you might have to take a longer
>>> way)
>>> * In Japan they have so called VICS data
>>> (http://www.mlit.go.jp/road/ITS/conf/2006/ts20.pdf)
>>> collected from
>>> road sensors, which can tell the typical speed on
>>> roads during
>>> certain hours.
>>> ... and so on ...
>>> One last thought on loading data. I work a lot with Navteq and
>>> LOTS of other data sets. The one common theme that I come back
>>> to is that I create data loaders for the various data sets I
>>> work with so I can load the data into the database and I always
>>> end up transforming the data into a simpler model that is easy
>>> to work with and then used by whatever application I am working
>>> on. Sometimes I transform the data in the loader and sometimes I
>>> just load it raw and transform it in the database and then drop
>>> the raw data tables.
>>> Hope this helps,
>>> -Steve
>>> I think what pgRouting is currently missing are some sort of
>>> "unit
>>> tests" on some test network. This can be a regular grid with
>>> costs
>>> assigned, that model a certain routing case. It would be really
>>> convenient to have something like this.
>>> Daniel
>>> 2011/4/5 Jay Mahadeokar <jai.mahadeokar at gmail.com
>>> <mailto:jai.mahadeokar at gmail.com>>>
>>> Hi,
>>> Since we will be working on time-dependent shortest path
>>> problem, I
>>> was wondering if time-dependent geographic data is
>>> freely available
>>> for research purposes. [1] states that we witness an
>>> increasing
>>> number of navigation service providers (such as Navteq and
>>> TeleAtlas) have started releasing their time-dependent
>>> travel-time
>>> datasets for road networks at high-resolution temporal
>>> granularity
>>> as fine as one sample for every five minutes.
>>> I guess that data is not freely available. Anyways, if
>>> you know such
>>> data-source can you please direct me? Besides this
>>> project, I am
>>> also working on some new heuristics for time-dependent
>>> shortest path
>>> as part of my thesis and the data would be really
>>> helpful for my work.
>>> Thanks.
>>> [1] http://portal.acm.org/citation.cfm?id=1869865
>>> On Thu, Mar 31, 2011 at 7:49 PM, Stephen Woodbridge
>>> <mailto:woodbri at swoodbridge.com>>> wrote:
>>> On 3/30/2011 9:45 PM, Daniel Kastl wrote:
>>> float cost := getEdgeCost(time,
>>> vehicle_type,
>>> node_from,
>>> node_to);
>>> or something like that. Where time
>>> could be NULL
>>> for some
>>> default
>>> behavior, or a value that would be
>>> used to
>>> figure out the cost.
>>> vehicle_type might be helpful if
>>> there are
>>> multiple costs to
>>> traverse a link based on say, car,
>>> carpool, bus,
>>> truck, walking,
>>> taxi, etc. This could also be used
>>> to implement
>>> the rules
>>> for bus
>>> and train lines.
>>> I think one of the difficulties with routing
>>> topic is that
>>> everyone
>>> (also myself) immediately think about routing in
>>> terms of
>>> vehicle types.
>>> It's the easiest example to explain pgRouting,
>>> but I think
>>> one premise
>>> of pgRouting is that it should work for any kind
>>> of network.
>>> Let's say
>>> your network would be the human nervous system.
>>> What is a
>>> vehicle there?
>>> Well, probably changing "vehicle_type" to
>>> "speed" would make
>>> sense, right?
>>> Sorry for using vehicle as the selector maybe
>>> "service_type"
>>> would be better, but the point is not the name,
>>> "speed" is
>>> equally misleading, the point is to be able to be
>>> able to pass a
>>> selector to the under lying function so that based
>>> on the
>>> selector we can compute an appropriate cost.
>>> For my vehicle routing example, I chose: car,
>>> carpool, bus,
>>> truck, walking, taxi, etc. because these might have
>>> different
>>> rules associated to them. The selector values would be
>>> appropriate to the model that you were working with.
>>> car vs carpool vs bus - many cities have HOV lanes
>>> that bus and
>>> carpool can use but not single occupancy cars. We
>>> might want to
>>> allocate a higher speed to those lanes vs the normal
>>> lanes
>>> during rush hours. Emergency vehicles many be
>>> allowed to make
>>> u-turns on highways that other vehicles can not
>>> make. Trucks
>>> might be banned from some streets so need to be costed
>>> appropriately, etc.
>>> If we had a live traffic feed information linked to
>>> segment ids
>>> in another table, The cost function could be
>>> implemented to
>>> check that table and if a record exists then use that
>>> information or return the standard information. By
>>> keeping this
>>> data in a separate table that is presumably much
>>> smaller and
>>> dynamic than the street records it would make it
>>> much easier and
>>> more cost effective to make dynmaic changes to that
>>> table and to
>>> hide (abstract away complexity) by using a cost function
>>> supplied to the underlying code.
>>> -Steve
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
