[pgrouting-dev] Where is the twoq repository in git?
Jinfu Leng
logicnut at gmail.com
Sun Jul 1 01:29:56 PDT 2012
Hey Steve,
I just checked my folder for the boost library (/usr/include/boost), and it
included all the missing files in the error message showed in your mail. So
the compile problem should be solved once you update the boost library.
Also I will try to clear my code.
Jinfu
On Sat, Jun 30, 2012 at 3:49 AM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> Daniel, Jinfu,
> Thanks. I'm not sure if this is supposed to compile yet but here is what I
> got. This might be because I have an old version of boost v1.34.1 installed.
> -Steve
> woodbri at mappy:~/work/**pgrouting-git/gsoc-twoq$ git clone git://
> github.com/pgRouting/**pgrouting.git<http://github.com/pgRouting/pgrouting.git>
> Initialized empty Git repository in /u/work/pgrouting-git/gsoc-**
> twoq/pgrouting/.git/
> remote: Counting objects: 2014, done.
> remote: Compressing objects: 100% (776/776), done.
> remote: Total 2014 (delta 1251), reused 1956 (delta 1201)
> Receiving objects: 100% (2014/2014), 702.75 KiB, done.
> Resolving deltas: 100% (1251/1251), done.
> woodbri at mappy:~/work/**pgrouting-git/gsoc-twoq$ cd pgrouting/
> woodbri at mappy:~/work/**pgrouting-git/gsoc-twoq/**pgrouting$ git checkout
> origin/gsoc-two_q
> Note: moving to "origin/gsoc-two_q" which isn't a local branch
> If you want to create a new branch from this checkout, you may do so
> (now or later) by using -b with the checkout command again. Example:
> git checkout -b <new_branch_name>
> HEAD is now at 769c967... optimized the logic of the mild_two_q algorithm
> woodbri at mappy:~/work/**pgrouting-git/gsoc-twoq/**pgrouting$ cmake .
> -- The C compiler identification is GNU
> -- The CXX compiler identification is GNU
> -- Check for working C compiler: /usr/bin/gcc
> -- Check for working C compiler: /usr/bin/gcc -- works
> -- Detecting C compiler ABI info
> -- Detecting C compiler ABI info - done
> -- Check for working CXX compiler: /usr/bin/c++
> -- Check for working CXX compiler: /usr/bin/c++ -- works
> -- Detecting CXX compiler ABI info
> -- Detecting CXX compiler ABI info - done
> -- POSTGRESQL_EXECUTABLE is POSTGRESQL_EXECUTABLE-NOTFOUND
> -- Found PostgreSQL: /usr/include/postgresql/8.3/**server,
> /usr/lib/libpq.so
> -- Boost version: 1.34.1
> -- Found the following Boost libraries:
> Boost headers were found here: /usr/include
> Output directory for libraries is set to /usr/lib/postgresql/8.4/lib
> -- Found PGROUTING_CORE core: /home/woodbri/work/pgrouting-**
> git/gsoc-twoq/pgrouting/core/**src
> Installation directory for libraries is set to /usr/lib/postgresql/8.4/lib
> and for SQL files is set to /usr/share/pgrouting
> -- Configuring done
> -- Generating done
> -- Build files have been written to: /home/woodbri/work/pgrouting-**
> woodbri at mappy:~/work/**pgrouting-git/gsoc-twoq/**pgrouting$ make
> Scanning dependencies of target routing
> [ 12%] Building C object core/src/CMakeFiles/routing.**dir/dijkstra.o
> [ 25%] Building C object core/src/CMakeFiles/routing.**dir/astar.o
> [ 37%] Building C object core/src/CMakeFiles/routing.**dir/shooting_star.o
> [ 50%] Building C object core/src/CMakeFiles/routing.**dir/mild_two_q.o
> [ 62%] Building CXX object core/src/CMakeFiles/routing.**
> dir/boost_wrapper.o
> In file included from /usr/include/c++/4.3/ext/hash_**set:64,
> from /usr/include/boost/graph/**adjacency_list.hpp:22,
> from /home/woodbri/work/pgrouting-**
> git/gsoc-twoq/pgrouting/core/**src/boost_wrapper.cpp:25:
> /usr/include/c++/4.3/backward/**backward_warning.h:33:2: warning:
> #warning This file includes at least one deprecated or antiquated header
> which may be removed without further notice at a future date. Please use a
> non-deprecated interface with equivalent functionality instead. For a
> listing of replacement headers and interfaces, consult the file
> backward_warning.h. To disable this warning use -Wno-deprecated.
> [ 75%] Building CXX object core/src/CMakeFiles/routing.**
> dir/astar_boost_wrapper.o
> git/gsoc-twoq/pgrouting/core/**src/astar_boost_wrapper.cpp:**25:
> [ 87%] Building CXX object core/src/CMakeFiles/routing.**
> dir/shooting_star_boost_**wrapper.o
> git/gsoc-twoq/pgrouting/core/**src/shooting_star_boost_**wrapper.cpp:25:
> [100%] Building CXX object core/src/CMakeFiles/routing.**
> dir/mild_two_q_boost_wrapper.o
> git/gsoc-twoq/pgrouting/core/**src/mild_two_q_boost_wrapper.**cpp:25:
> In file included from /home/woodbri/work/pgrouting-**
> git/gsoc-twoq/pgrouting/core/**src/mild_two_q_boost_wrapper.**cpp:28:
> /home/woodbri/work/pgrouting-**git/gsoc-twoq/pgrouting/core/**
> src/mild_two_q_shortest_paths.**hpp:26:39: error:
> boost/graph/overloading.hpp: No such file or directory
> src/mild_two_q_shortest_paths.**hpp:28:45: error:
> boost/graph/detail/d_ary_heap.**hpp: No such file or directory
> src/mild_two_q_shortest_paths.**hpp:33:36: error:
> boost/concept/assert.hpp: No such file or directory
> src/mild_two_q_shortest_paths.**hpp: In member function âvoid
> boost::Mild_two_q_**VisitorConcept<Visitor, Graph>::constraints()â:
> src/mild_two_q_shortest_paths.**hpp:75: error: expected
> primary-expression before â)â token
> src/mild_two_q_shortest_paths.**hpp:75: error: there are no arguments to
> âBOOST_CONCEPT_ASSERTâ that depend on a template parameter, so a
> declaration of âBOOST_CONCEPT_ASSERTâ must be available
> src/mild_two_q_shortest_paths.**hpp:75: error: (if you use
> â-fpermissiveâ, G++ will accept your code, but allowing the use of an
> undeclared name is deprecated)
> src/mild_two_q_shortest_paths.**hpp: In function âvoid
> boost::mild_two_q_shortest_**paths_no_init(const Graph&, typename
> boost::graph_traits<G>::**vertex_descriptor, typename
> boost::graph_traits<G>::**vertex_descriptor, PredecessorMap, DistanceMap,
> WeightMap, IndexMap, Compare, Combine, DistZero, Mild_two_q_Visitor,
> ColorMap)â:
> src/mild_two_q_shortest_paths.**hpp:306: error: expected
> src/mild_two_q_shortest_paths.**hpp:306: error: there are no arguments to
> src/mild_two_q_shortest_paths.**hpp:311: error: expected
> src/mild_two_q_shortest_paths.**hpp:311: error: there are no arguments to
> boost::mild_two_q_shortest_**paths(const VertexListGraph&, typename
> WeightMap, IndexMap, Compare, Combine, DistInf, DistZero,
> Mild_two_q_Visitor)â:
> src/mild_two_q_shortest_paths.**hpp:427: error: there are no arguments to
> âno_named_parametersâ that depend on a template parameter, so a declaration
> of âno_named_parametersâ must be available
> /usr/include/boost/property_**map.hpp: At global scope:
> /usr/include/boost/property_**map.hpp: In instantiation of
> âboost::property_traits<boost:**:bgl_named_params<double*,
> boost::vertex_distance_t, boost::bgl_named_params<boost:**
> :bundle_property_map<boost::**adjacency_list<boost::listS, boost::vecS,
> boost::directedS, boost::no_property, Vertex, boost::no_property,
> boost::listS>, boost::detail::edge_desc_impl<**boost::directed_tag, long
> unsigned int>, Vertex, double>, boost::edge_weight_t,
> boost::bgl_named_params<long unsigned int*, boost::vertex_predecessor_t,
> boost::no_property> > > >â:
> src/mild_two_q_shortest_paths.**hpp:395: instantiated from âvoid
> Mild_two_q_Visitor, ColorMap) [with VertexListGraph =
> boost::adjacency_list<boost::**listS, boost::vecS, boost::directedS,
> boost::no_property, Vertex, boost::no_property, boost::listS>,
> Mild_two_q_Visitor = boost::mild_two_q_visitor<**boost::null_visitor>,
> PredecessorMap = long unsigned int*, DistanceMap = double*, WeightMap =
> boost::bundle_property_map<**boost::adjacency_list<boost::**listS,
> boost::vecS, boost::directedS, boost::no_property, Vertex,
> boost::no_property, boost::listS>, boost::detail::edge_desc_impl<**boost::directed_tag,
> long unsigned int>, Vertex, double>, IndexMap =
> boost::vec_adj_list_vertex_id_**map<boost::no_property, long unsigned
> int>, Compare = std::less<double>, Combine = boost::closed_plus<double>,
> DistInf = double, DistZero = double, ColorMap = boost::bgl_named_params<**double*,
> boost::no_property> > >]â
> src/mild_two_q_shortest_paths.**hpp:451: instantiated from âvoid
> boost::detail::mild_two_q_**dispatch2(const VertexListGraph&, typename
> boost::graph_traits<G>::**vertex_descriptor, DistanceMap, WeightMap,
> IndexMap, const Params&) [with VertexListGraph =
> boost::no_property, Vertex, boost::no_property, boost::listS>, DistanceMap
> = double*, WeightMap = boost::bundle_property_map<**
> boost::detail::edge_desc_impl<**boost::directed_tag, long unsigned int>,
> Vertex, double>, IndexMap = boost::vec_adj_list_vertex_id_**map<boost::no_property,
> long unsigned int>, Params = boost::bgl_named_params<**double*,
> src/mild_two_q_shortest_paths.**hpp:484: instantiated from âvoid
> boost::detail::mild_two_q_**dispatch1(const VertexListGraph&, typename
> src/mild_two_q_shortest_paths.**hpp:503: instantiated from âvoid
> boost::graph_traits<G>::**vertex_descriptor, const
> boost::bgl_named_params<P, T, R>&) [with VertexListGraph =
> boost_mild_two_q(edge_t*, unsigned int, int, int, bool, bool,
> path_element_t**, int*, char**)::graph_t, Param = double*, Tag =
> boost::vertex_distance_t, Rest = boost::bgl_named_params<boost:**
> boost::no_property> >]â
> src/mild_two_q_boost_wrapper.**cpp:123: instantiated from here
> /usr/include/boost/property_**map.hpp:25: error: no type named âkey_typeâ
> in âstruct boost::bgl_named_params<**double*, boost::vertex_distance_t,
> boost::bgl_named_params<boost:**:bundle_property_map<boost::**adjacency_list<boost::listS,
> long unsigned int>, Vertex, double>, boost::edge_weight_t,
> boost::no_property> > >â
> /usr/include/boost/property_**map.hpp:27: error: no type named
> âreferenceâ in âstruct boost::bgl_named_params<**double*,
> /usr/include/boost/property_**map.hpp:28: error: no type named âcategoryâ
> boost::no_property> > >]â:
> src/mild_two_q_shortest_paths.**hpp:402: error: no matching function for
> call to âput(boost::bgl_named_params<**double*, boost::vertex_distance_t,
> boost::no_property> > >&, const long unsigned int&,
> boost::default_color_type)â
> ColorMap) [with Graph = boost::adjacency_list<boost::**listS,
> boost::no_property, boost::listS>, Mild_two_q_Visitor =
> boost::mild_two_q_visitor<**boost::null_visitor>, PredecessorMap = long
> src/mild_two_q_shortest_paths.**hpp:406: instantiated from âvoid
> src/mild_two_q_shortest_paths.**hpp:306: error: âBOOST_CONCEPT_ASSERTâ
> was not declared in this scope
> src/mild_two_q_shortest_paths.**hpp:324: error: no matching function for
> boost::no_property> > >&, long unsigned int&, boost::default_color_type)â
> src/mild_two_q_shortest_paths.**hpp:327: error: no matching function for
> call to âget(boost::bgl_named_params<**double*, boost::vertex_distance_t,
> boost::no_property> > >&, long unsigned int&)â
> src/mild_two_q_shortest_paths.**hpp:329: error: no matching function for
> boost::no_property> > >&, Vertex&, boost::default_color_type)â
> src/mild_two_q_shortest_paths.**hpp:338: error: no matching function for
> boost::no_property> > >&, Vertex&)â
> src/mild_two_q_shortest_paths.**hpp:339: error: no match for âoperator==â
> in âc_v == boost::color_traits<**ColorValue>::white [with ColorValue =
> double*]()â
> src/mild_two_q_shortest_paths.**hpp:342: error: no matching function for
> src/mild_two_q_shortest_paths.**hpp:344: error: no match for âoperator==â
> in âc_v == boost::color_traits<**ColorValue>::black [with ColorValue =
> double*]()â
> src/mild_two_q_shortest_paths.**hpp:347: error: no matching function for
> make[2]: *** [core/src/CMakeFiles/routing.**dir/mild_two_q_boost_wrapper.*
> *o] Error 1
> make[1]: *** [core/src/CMakeFiles/routing.**dir/all] Error 2
> make: *** [all] Error 2
> On 6/29/2012 1:58 PM, Daniel Kastl wrote:
>> Hi Steve,
>> It's a branch in the pgRouting repository:
>> https://github.com/pgRouting/**pgrouting/tree/gsoc-two_q<https://github.com/pgRouting/pgrouting/tree/gsoc-two_q>
>> Btw., the Github network graph is interesting, because you can see some
>> activities of other users:
>> https://github.com/pgRouting/**pgrouting/network<https://github.com/pgRouting/pgrouting/network>
>> Didn't look at it for a while.
>> Daniel
>> On Fri, Jun 29, 2012 at 7:42 PM, Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>>>
>> wrote:
>> Hi Jinfu,
>> Have you created a git repository for your twoq code?
>> Where is it? git://github.com/... <http://github.com/...>..
>> I looked through your weekly reports, and emails to the list but did
>> not notice it anywhere. I probably just missed it.
>> I would probably be a good idea to post this link on your respective
>> project pages.
>> Thanks,
>> -Steve
>> ______________________________ _________________
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
>> http://lists.osgeo.org/ mailman/listinfo/pgrouting-dev
>> <http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl@**georepublic.de<daniel.kastl at georepublic.de>
>> Web: http://georepublic.de <http://georepublic.de/>
>> ______________________________**_________________
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120701/b46bc5cf/attachment-0001.html>
More information about the pgrouting-dev
