[pgrouting-dev] Develop the automatic testing tool
Jinfu Leng
logicnut at gmail.com
Sun Jul 1 01:43:44 PDT 2012
Hey Steve,
Thanks for your comprehensive review of the methods. It is very useful.
Since I really care about the core performance of each algorithm, I would
do this "you could add timing collection in your C/C++ code ".
Thanks,
Jinfu
On Sat, Jun 30, 2012 at 11:27 AM, Stephen Woodbridge <
woodbri at swoodbridge.com> wrote:
> On 6/29/2012 10:38 PM, Jinfu Leng wrote:
>> Hey all,
>> I almost finished my code for the new algorithm. Next I want to test the
>> performance (regarding computing time) of these algorithms. I am
>> planning to randomly generate some source-target pairs, and use them for
>> testing. But I do not know where to start.
>> My questions are:
>> How to execute the query from the code? (I always test the algorithms
>> from pgadmin)
>> How to save the results? (I want to save the total distance at least,
>> and then I can use these results to make sure all the algorithms are
>> right)
>> How to measure the computing time of each algorithm?
> There are a lot of ways to build automated tests. I will outline some of
> them below. One big thing to watch out for is to be aware of WHAT you are
> measuring.
> 1. you can use linux command line in a script like:
> time psql -U user -h localhost databse -f input.sql
> in the input.sql you can start off with '\timing on' to get it to echo
> query times for each command. There are other command line options read
> 'man psql' for details that might be useful.
> Be aware that you are measuring psql startup time, database connect time,
> and the query time of the commands, the transfer of the results and
> printing the results. If the query time is small relative to all the other
> stuff. this might be problematic.
> 2. you can use a perl script with DBI and Time::HighRes modules to measure
> the time a query takes to run. If you are knowledgeable in perl this also
> makes it easy to read data and query input from files and log the results
> to a file.
> 3. If you like plpgsql or SQL, you could create a table in your database
> with the data, queries, and tests that you want to run. maybe with a
> structure like:
> create table testdata (
> testid integer not null primary key,
> query text,
> expected_results text,
> And a table for results:
> create table testresults {
> testid integer,
> run_date time stamp with timezone,
> duration integer,
> pass integer,
> comments text
> Then you could write a stored procedure(s) like:
> select * from runtests();
> select * from runtests(testid);
> this would read the test(s) from testdata
> run each test requested
> store the results in testresults
> and return the results one for each test run.
> You can do timing via SQL and plpgsql using timestamps and extracting
> microseconds from the interval between the start and end timestamps that
> can bracket a query.
> 4. you could add timing collection in your C/C++ code and return it via
> the NOTICE facility, like what we do for debugging.
> And I'm sure there are other ways to do this.
> -Steve
> ______________________________**_________________
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120701/4c213aae/attachment.html>
More information about the pgrouting-dev
