[pgrouting-dev] BDSP Crashes
Stephen Woodbridge woodbri at swoodbridge.com
Sun Jul 1 21:25:07 PDT 2012
Argh! sorry my bad. Try:
http://imaptools.com:8080/dl/test.tgz
-Steve
On 7/1/2012 11:45 PM, Razequl Islam wrote:
> Hi Steve,
> I am trying to download the csv but ending up with 404 Not Found error.
> Please confirm the URL works. I am also getting the same problem with
> http://imaptools.com/dl/test.tgz
> -Razequl
> On Sun, Jul 1, 2012 at 7:37 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     Razqequl,
>     I have not looked into the reason, but my intuition it that it may
>     be because this graph has about 50K edges so it will be larger than
>     most anything that you generated by hand, and the edge and node
>     numbers are very large because this is an extract from a 10s of
>     million of edges graph. There were no error message other than the
>     generic postgresql message the the server crashed. You will probably
>     fine you have a segv in your test program.
>     I can download a zipped copy of the csv file. The first row is the
>     column names.
>     http://imaptools.com/dl/bdsp- big-bug.zip
>     <http://imaptools.com/dl/bdsp-big-bug.zip>
>     -Steve
>     On 7/1/2012 5:18 AM, Razequl Islam wrote:
>         Hi Steve,
>         Bad news :(
>         As I mentioned, I already have a test application to read from text
>         file, it will be very helpful if you send me a csv file
>         containing the
>         graph. Also please let me know if there is any error message. I am
>         looking into my code for a possible reason.
>         -Razequl
>         On Sun, Jul 1, 2012 at 3:19 AM, Stephen Woodbridge
>         <mailto:woodbri at swoodbridge. com
>         <mailto:woodbri at swoodbridge.com>>> wrote:
>              Hi Razequl,
>              I tried a larger test and it crashed the server.
>              You can test it like this:
>              # fetch a test file from my server
>              wget http://imaptools.com/dl/test. tgz
>              <http://imaptools.com/dl/test. tgz
>         <http://imaptools.com/dl/test.tgz>>
>              # extract the tarfile into directory test
>              tar xzf test.tgz
>              # load the file into your test database into table "st"
>              shp2pgsql -s 4326 -c -D -I -N skip test/bdsp-bug.shp st |
>         psql -U
>              user -h localhost mydatabase
>              # get into psql or pgadmin and run the following
>              psql -U user -h localhost mydatabase
>              SELECT * FROM st, (
>                             SELECT gid,the_geom
>                               FROM bidir_dijkstra_shortest_path(
>                                 'SELECT link_id  as id,
>                                          source::integer,
>                                          target::integer,
>                                          cost_time::double precision as
>         cost ,
>                                          rcost_time as reverse_cost
>                                    FROM st a',
>                                 1187405,
>                                 1187508,
>                                 true,
>                                 true
>                        ), st where edge_id = link_id
>                   ) as rt
>                   WHERE st.gid=rt.gid;
>              This crashes my server!
>              If you want to write a testmain.cpp, I can provide the
>         graph data in
>              a csv file that you could read in and pass to your code
>         instead of
>              the query to get the data from table st.
>              -Steve
>              ______________________________ _________________
>              pgrouting-dev mailing list
>         pgrouting-dev at lists.osgeo.org
>         <mailto:pgrouting-dev at lists.osgeo.org>
>         <mailto:pgrouting-dev at lists. osgeo.org
>         <mailto:pgrouting-dev at lists.osgeo.org>>
>         http://lists.osgeo.org/ mailman/listinfo/pgrouting-dev
>              <http://lists.osgeo.org/ mailman/listinfo/pgrouting-dev
>         <http://lists.osgeo.org/mailman/listinfo/pgrouting-dev> >
>         pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
More information about the pgrouting-dev mailing list
