[pgrouting-dev] BDSP Crashes
Razequl Islam ziboncsedu at gmail.com
Mon Jul 2 05:51:49 PDT 2012
Hi Steve,
I downloaded the csv file and used my test application. But it ran fine and
produced the following output:
1187405 | 25345111 | 11.338544
1187406 | 25345248 | 16.928516
1187508 | -1  | 0.000000
I ran some other queries on the graph but could not crash the program. So I
suspect the problem may lie in the wrapper classes. I will create a table
and run the query.
-Razequl
On Mon, Jul 2, 2012 at 10:25 AM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> Argh! sorry my bad. Try:
> http://imaptools.com:8080/dl/**test.tgz<http://imaptools.com:8080/dl/test.tgz>
> -Steve
> On 7/1/2012 11:45 PM, Razequl Islam wrote:
>> Hi Steve,
>> I am trying to download the csv but ending up with 404 Not Found error.
>> Please confirm the URL works. I am also getting the same problem with
>> http://imaptools.com/dl/test.**tgz <http://imaptools.com/dl/test.tgz>
>> -Razequl
>> On Sun, Jul 1, 2012 at 7:37 PM, Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>>>
>> wrote:
>>     Razqequl,
>>     I have not looked into the reason, but my intuition it that it may
>>     be because this graph has about 50K edges so it will be larger than
>>     most anything that you generated by hand, and the edge and node
>>     numbers are very large because this is an extract from a 10s of
>>     million of edges graph. There were no error message other than the
>>     generic postgresql message the the server crashed. You will probably
>>     fine you have a segv in your test program.
>>     I can download a zipped copy of the csv file. The first row is the
>>     column names.
>>     http://imaptools.com/dl/bdsp- big-bug.zip
>>     <http://imaptools.com/dl/bdsp-**big-bug.zip<http://imaptools.com/dl/bdsp-big-bug.zip>
>>     -Steve
>>     On 7/1/2012 5:18 AM, Razequl Islam wrote:
>>         Hi Steve,
>>         Bad news :(
>>         As I mentioned, I already have a test application to read from
>> text
>>         file, it will be very helpful if you send me a csv file
>>         containing the
>>         graph. Also please let me know if there is any error message. I am
>>         looking into my code for a possible reason.
>>         -Razequl
>>         On Sun, Jul 1, 2012 at 3:19 AM, Stephen Woodbridge
>>         <mailto:woodbri at swoodbridge. com
>>         <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>
>> wrote:
>>              Hi Razequl,
>>              I tried a larger test and it crashed the server.
>>              You can test it like this:
>>              # fetch a test file from my server
>>              wget http://imaptools.com/dl/test. tgz
>>              <http://imaptools.com/dl/test. tgz
>>         <http://imaptools.com/dl/test.**tgz<http://imaptools.com/dl/test.tgz>
>>              # extract the tarfile into directory test
>>              tar xzf test.tgz
>>              # load the file into your test database into table "st"
>>              shp2pgsql -s 4326 -c -D -I -N skip test/bdsp-bug.shp st |
>>         psql -U
>>              user -h localhost mydatabase
>>              # get into psql or pgadmin and run the following
>>              psql -U user -h localhost mydatabase
>>              SELECT * FROM st, (
>>                             SELECT gid,the_geom
>>                               FROM bidir_dijkstra_shortest_path(
>>                                 'SELECT link_id  as id,
>>                                          source::integer,
>>                                          target::integer,
>>                                          cost_time::double precision as
>>         cost ,
>>                                          rcost_time as reverse_cost
>>                                    FROM st a',
>>                                 1187405,
>>                                 1187508,
>>                                 true,
>>                                 true
>>                        ), st where edge_id = link_id
>>                   ) as rt
>>                   WHERE st.gid=rt.gid;
>>              This crashes my server!
>>              If you want to write a testmain.cpp, I can provide the
>>         graph data in
>>              a csv file that you could read in and pass to your code
>>         instead of
>>              the query to get the data from table st.
>>              -Steve
>>              ______________________________ _________________
>>              pgrouting-dev mailing list
>>         pgrouting-dev at lists.osgeo.org
>>         <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
>>         <mailto:pgrouting-dev at lists. osgeo.org
>>         http://lists.osgeo.org/ mailman/listinfo/pgrouting-dev
>>              <http://lists.osgeo.org/ mailman/listinfo/pgrouting-dev
>>         <http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>>         pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**
>> osgeo.org <pgrouting-dev at lists.osgeo.org>>
>>     pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
>> ______________________________**_________________
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120702/09f6ef1d/attachment-0001.html>
More information about the pgrouting-dev mailing list
