[pgrouting-dev] redundant core sql functions
Daniel Kastl daniel at georepublic.de
Mon Jul 2 01:09:04 PDT 2012
On Mon, Jul 2, 2012 at 9:41 AM, "Christophe Damour (SIGéal)" <
sigeal at sigeal.com> wrote:
> Hi,
> I totally agree with both of you, Daniel and Mario.
> I too was a bit confused by existing wrappers when I began to use
> pgrouting.
> Wrappers should add extra functionalities.
> A function that accept source and target x/y would indeed be usefull,
> especially if it can return the first and last edge cut at the actual
> projection of source and target x/y. I will need such a function soon, so I
> will have to work on it...
This is indeed an often requested "feature". But it can be more tricky than
it initially looks like.
There is some example you can start with:
https://github.com/pgRouting/pgrouting-contrib/tree/master/wrapper
For wrappers "shipped" we should define some criteria. As more we have as
more needs to be documented and maintained. Instead a tutorial or a
few recipes to help users to write and modify their own custom wrappers
might make more sense.
Daniel
> Any hints appreciated.
> Christophe
> Le 02/07/2012 09:28, Mario Basa a écrit :
>  Daniel,
>> I agree. Right now it really is quite confusing which function to use,
>> and the description of each function is not also very helpful.
>> I am curious though why is it that there is no sp function that
>> accepts source_x,source_y and target_x,target_y parameters similar to
>> that of driving_distance. This I think, will be very useful.
>> Mario.
>> On Mon, Jul 2, 2012 at 4:11 PM, Daniel Kastl <daniel at georepublic.de>
>> wrote:
>>> Hi Mario,
>>> In my opinion I would drop functions like the one you mentioned and
>>> reduce
>>> the number of wrappers as much as possible.
>>> I think a good and useful wrapper function is one, that selects a BBOX
>>> containing start and end point and returns records with geometries.
>>> Then everyone can modify it as needed. I don't think we should simplify
>>> those basic wrappers and make assumptions like naming the cost column
>>> "length" or so.
>>> What do you think?
>>> Daniel
>>> On Mon, Jul 2, 2012 at 9:02 AM, Mario Basa <mario.basa at gmail.com> wrote:
>>>> Hello,
>>>> The core wrapper functions have
>>>> dijkstra_sp_delta_directed
>>>> astar_sp_delta_directed
>>>> with "length" hard coded as cost for some reason.
>>>> While astar_sp_delta_cc has a cost column parameter, but all it does
>>>> is call astar_sp_delta_cc_directed  with
>>>> reverse_cost=false,directed=**false.
>>>> There is also no dijkstra_sp_delta_cc with a cost column parameter, so
>>>> a user has to rename the column containing the cost value to "length"
>>>> to use this clipping function. Etc....
>>>> Personally I am getting confused with all these functions and would
>>>> like to just trim it down to dijkstra_sp_delta and astar_sp_delta with
>>>> a cost column parameter along with reverse_cost and directed
>>>> parameters.
>>>> Opinions?
>>>> Mario.
>>>> ______________________________**_________________
>>>> pgrouting-dev mailing list
>>>> pgrouting-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>>> Georepublic UG & Georepublic Japan
>>> eMail: daniel.kastl at georepublic.de
>>> Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120702/39dc1731/attachment-0001.html>
More information about the pgrouting-dev mailing list
