[pgrouting-dev] redundant core sql functions
"Christophe Damour (SIGéal)"
sigeal at sigeal.com
Mon Jul 2 02:19:14 PDT 2012
Thanks for the hints Mario and Daniel,
I'll have look and let you know as soon as I can put my hands on it.
Christophe
Le 02/07/2012 10:09, Daniel Kastl a écrit :
> On Mon, Jul 2, 2012 at 9:41 AM, "Christophe Damour (SIGéal)"
> <sigeal at sigeal.com <mailto:sigeal at sigeal.com>> wrote:
> Hi,
> I totally agree with both of you, Daniel and Mario.
> I too was a bit confused by existing wrappers when I began to use
> pgrouting.
> Wrappers should add extra functionalities.
> A function that accept source and target x/y would indeed be
> usefull, especially if it can return the first and last edge cut
> at the actual projection of source and target x/y. I will need
> such a function soon, so I will have to work on it...
> This is indeed an often requested "feature". But it can be more tricky
> than it initially looks like.
> There is some example you can start with:
> https://github.com/pgRouting/pgrouting-contrib/tree/master/wrapper
> For wrappers "shipped" we should define some criteria. As more we have
> as more needs to be documented and maintained. Instead a tutorial or a
> few recipes to help users to write and modify their own custom
> wrappers might make more sense.
> Daniel
> Any hints appreciated.
> Christophe
> Le 02/07/2012 09:28, Mario Basa a écrit :
> Daniel,
> I agree. Right now it really is quite confusing which function
> to use,
> and the description of each function is not also very helpful.
> I am curious though why is it that there is no sp function that
> accepts source_x,source_y and target_x,target_y parameters
> similar to
> that of driving_distance. This I think, will be very useful.
> Mario.
> On Mon, Jul 2, 2012 at 4:11 PM, Daniel Kastl
> <daniel at georepublic.de <mailto:daniel at georepublic.de>> wrote:
> Hi Mario,
> In my opinion I would drop functions like the one you
> mentioned and reduce
> the number of wrappers as much as possible.
> I think a good and useful wrapper function is one, that
> selects a BBOX
> containing start and end point and returns records with
> geometries.
> Then everyone can modify it as needed. I don't think we
> should simplify
> those basic wrappers and make assumptions like naming the
> cost column
> "length" or so.
> What do you think?
> Daniel
> On Mon, Jul 2, 2012 at 9:02 AM, Mario Basa
> <mario.basa at gmail.com <mailto:mario.basa at gmail.com>> wrote:
> Hello,
> The core wrapper functions have
> dijkstra_sp_delta_directed
> astar_sp_delta_directed
> with "length" hard coded as cost for some reason.
> While astar_sp_delta_cc has a cost column parameter,
> but all it does
> is call astar_sp_delta_cc_directed with
> reverse_cost=false,directed=false.
> There is also no dijkstra_sp_delta_cc with a cost
> column parameter, so
> a user has to rename the column containing the cost
> value to "length"
> to use this clipping function. Etc....
> Personally I am getting confused with all these
> functions and would
> like to just trim it down to dijkstra_sp_delta and
> astar_sp_delta with
> a cost column parameter along with reverse_cost and
> directed
> parameters.
> Opinions?
> Mario.
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> <mailto:pgrouting-dev at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.de
> pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.de <http://georepublic.de/>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120702/907c0a8b/attachment.html>
More information about the pgrouting-dev
