[pgrouting-dev] duplicate function names in core
Stephen Woodbridge woodbri at swoodbridge.com
Tue Jul 10 17:38:38 PDT 2012
On 7/10/2012 5:23 AM, Mario Basa wrote:
> Hello,
> I am encountering problems placing the drivedist.c and
> boost_drivedist.cpp into core (everything compiles, drivedist works
> but astar searches dumps core. If I take out drivedist, astar works
> like normal.), so I decided to poke around the source. I just found
> out that there are so many duplicate functions (i.e.
> finish(),text2char(),etc.) and struct names (edge_column,etc.) in each
> of the C files.
> Since C does not have any namespace functionality nor function
> overloading, I don't have any idea which one will be called whenever
> there is a library call. Scary since this will be difficult to debug.
> Now that pgRouting is getting source contributions, I think this will
> be a good time that we start discussing function naming conventions to
> avoid duplicates as well as directory (core and extensions)
> structures.
Mario,
UGH! Ideally one of two things should happen:
1. common functions with compatible signatures should be extracted into
a common.c common.h or utils.c utils.h and get shared by all algorithms
that need them.
2. local functions should all be declares "static" which means they are
not visible or callable from references outside the file they are
declared in.
So, if you have a C wrapper and it needs functions and no other files
need to use these functions then they should be declared as static and
placed in the C wrapper file.
If you have some function that multiple C files need to call or you C++
also needs to call, then it needs to go into a file like
<namespace>_utils.c and all the functions in this file need to have a
unique <namespace>_functionname() like signature.
I think this will minimize the changes we need to make to the existing
code using "static" declarations for most things, and then moving the
others into some namespace'd set of files.
How does this sound?
I like the idea of having multiple library .so files rather than one
huge file because it keeps things separated but more so because it makes
it easy to rebuild one library without effecting any of the others. I
would like to know that if I change TRSP that there is little to zero
change that I can impact the other algorithms.
Thank about a production environment where you have pgrouting running on
lots of databases and in one database you want to add TRSP. By making it
one big library you force a change on all the databases that did not
need that change, but if TRSP is in a separate library then all the
database that are not using it can be assured to be stable because they
did not change. The worsted cases is that the new database with TRSP
added to it might be unstable and if there is a collision of files like
you describe the cases crashes, it only happens in the new database.
Hmmm, maybe it doesn't work this way once the postgresql loads the
library. But I don't remember having problems loading multiple libraries.
Thoughts?
-Steve
More information about the pgrouting-dev mailing list
