[pgrouting-dev] duplicate function names in core
Sanak geosanak at gmail.com
Wed Jul 11 00:50:50 PDT 2012
Hi Mario,
I am not familiar with c/c++ specification,
but I had encountered the same problem before.
See my experimental "msvc" branch commit diff.
https://github.com/sanak/pgrouting/commit/9ef417078eadad8554e1d7cd3ccd7592266b2912
(NOTICE: Don't mind my temporary fix(symbol naming, .etc),
               because my "msvc" branch is "only" experimental.)
And I agree that different symbol name using.
Regards,
2012/7/11 Mario Basa <mario.basa at gmail.com>
> Hello Steve,
> With the problem I am encountering when I brought the driving_distance
> into core, both boost_drivedist.cpp and astar_boost_wrapper.cpp have
> graph_add_edge() function and Edge and Vertex structs.
> The offending components here are the structs I think since they have
> different values even if they have the same name in the c++ files. So,
> whichever you compile first (astar or drivedist) in the CMAKE file
> will work while the other will core dump. For fun, I made a different
> library in the CMAKE for drivedist, and it still dumped core.
> It was only after I renamed everything (Edge_dd,Vertex_dd, etc.) did
> it work. Again, this is so difficult to debug, well time consuming
> anyway. I am not so familiar with the recent gcc compiler, but I'll
> try look if there is a compile time option to give out warnings for
> similar function names.
> I'll move the common functions into a pgr_utils.h file to take out
> redundancy in core.
> Mario.
> On Wed, Jul 11, 2012 at 8:38 AM, Stephen Woodbridge
> <woodbri at swoodbridge.com> wrote:
> > On 7/10/2012 5:23 AM, Mario Basa wrote:
> >> Hello,
> >> I am encountering problems placing the drivedist.c and
> >> boost_drivedist.cpp into core (everything compiles, drivedist works
> >> but astar searches dumps core. If I take out drivedist, astar works
> >> like normal.), so I decided to poke around the source. I just found
> >> out that there are so many duplicate functions (i.e.
> >> finish(),text2char(),etc.) and struct names (edge_column,etc.) in each
> >> of the C files.
> >> Since C does not have any namespace functionality nor function
> >> overloading, I don't have any idea which one will be called whenever
> >> there is a library call. Scary since this will be difficult to debug.
> >> Now that pgRouting is getting source contributions, I think this will
> >> be a good time that we start discussing function naming conventions to
> >> avoid duplicates as well as directory (core and extensions)
> >> structures.
> > Mario,
> > UGH! Ideally one of two things should happen:
> > 1. common functions with compatible signatures should be extracted into a
> > common.c common.h or utils.c utils.h and get shared by all algorithms
> that
> > need them.
> > 2. local functions should all be declares "static" which means they are
> not
> > visible or callable from references outside the file they are declared
> in.
> > So, if you have a C wrapper and it needs functions and no other files
> need
> > to use these functions then they should be declared as static and placed
> in
> > the C wrapper file.
> > If you have some function that multiple C files need to call or you C++
> also
> > needs to call, then it needs to go into a file like <namespace>_utils.c
> and
> > all the functions in this file need to have a unique
> > <namespace>_functionname() like signature.
> > I think this will minimize the changes we need to make to the existing
> code
> > using "static" declarations for most things, and then moving the others
> into
> > some namespace'd set of files.
> > How does this sound?
> > I like the idea of having multiple library .so files rather than one huge
> > file because it keeps things separated but more so because it makes it
> easy
> > to rebuild one library without effecting any of the others. I would like
> to
> > know that if I change TRSP that there is little to zero change that I can
> > impact the other algorithms.
> > Thank about a production environment where you have pgrouting running on
> > lots of databases and in one database you want to add TRSP. By making it
> one
> > big library you force a change on all the databases that did not need
> that
> > change, but if TRSP is in a separate library then all the database that
> are
> > not using it can be assured to be stable because they did not change. The
> > worsted cases is that the new database with TRSP added to it might be
> > unstable and if there is a collision of files like you describe the cases
> > crashes, it only happens in the new database. Hmmm, maybe it doesn't work
> > this way once the postgresql loads the library. But I don't remember
> having
> > problems loading multiple libraries.
> > Thoughts?
> > -Steve
> > pgrouting-dev mailing list
> > pgrouting-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120711/d54123f2/attachment-0001.html>
More information about the pgrouting-dev mailing list
