[pgrouting-dev] First version of bi-directional dijkstra
Razequl Islam ziboncsedu at gmail.com
Sat Jun 9 00:46:37 PDT 2012
Hi Steve,
1.I implemented the first version bi directional shortest path using
dijkstra and attached the source code in this mail. Please have a look and
let me know your feedback.
2. i tried to merge my source code to https://github.com/zibon/pgrouting.
but failed.
I have checked out the fork the local folder and created my source
directory bdsp under the extra folder. Then
i tried the following command:
git push origin master
After a few time it said that 'Everything up-to-date', but found no bdsp
folder in https://github.com/zibon/pgrouting/tree/master/extra.
3.I just copied my source code folder to my local repo directory. Is it
necessary to commit every single file of my folder. If so then what is the
procedure?
regards
razequl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120609/bcfd0bcf/attachment.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120609/bcfd0bcf/attachment.bin>
More information about the pgrouting-dev mailing list
