[pgrouting-dev] First version of bi-directional dijkstra
Jay Mahadeokar jai.mahadeokar at gmail.com
Sat Jun 9 01:05:03 PDT 2012
Hi Razequl,
You need to first add all files (git add filename)and then commit to the
local git repository and then push it to the remote repo.
I guess a quick look at any git tutorial should give you the exact
commands.
On 9 Jun 2012 13:16, "Razequl Islam" <ziboncsedu at gmail.com> wrote:
> Hi Steve,
> 1.I implemented the first version bi directional shortest path using
> dijkstra and attached the source code in this mail. Please have a look and
> let me know your feedback.
> 2. i tried to merge my source code to https://github.com/zibon/pgrouting.
> but failed.
> I have checked out the fork the local folder and created my source
> directory bdsp under the extra folder. Then
> i tried the following command:
> git push origin master
> After a few time it said that 'Everything up-to-date', but found no bdsp
> folder in https://github.com/zibon/pgrouting/tree/master/extra.
> 3.I just copied my source code folder to my local repo directory. Is it
> necessary to commit every single file of my folder. If so then what is the
> procedure?
> regards
> razequl
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120609/c9a4c2c5/attachment-0001.html>
More information about the pgrouting-dev mailing list
