[pgrouting-dev] Building TRSP branch
Steve Horn steve at stevehorn.cc
Tue Jun 12 06:17:33 PDT 2012
Was not able to find these libraries via package manager, but I did get
pgRouting and dependencies installed manually.
The "cannot find -lgmp" referred to a dependency of CGAL that needed to be
installed ( http://gmplib.org/manual/Installing-GMP.html#Installing-GMP )
Also of note is that CGAL needs a specific version of the Boost libraries
to work (1.41).
After successful pgRouting make/make install then I ran the
driving_distance function to test and got this:
“Error while loading shared libraries: libboost_thread.so.1.41.0: cannot
open shared object file: No such file or directory"
Used the information in this blog to correct that error:
http://somethingididnotknow.wordpress.com/2012/02/17/fix-the-error-while-loading-shared-libraries-libboost_thread-so-1-48-0-cannot-open-shared-object-file-no-such-file-or-directory-error/
Hope this helps someone in the future.
Steve: Haven't done a deep dive into the TRSP functionality -but I am
impressed at the surface. Does it use an A Star algorithm at the core?
Thanks for your efforts on this!
On Mon, Jun 11, 2012 at 8:26 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> On 6/11/2012 7:58 PM, Steve Horn wrote:
>> Trying to manually build and install the gmp dependency for cgal..but
>> I'm curious how you can install it through yum. The searches you
>> provided do not turn up anything.
> You probably need to google "centos cgal" and then add an appropriate
> repository to yum. I forget the exact way to do that.
>  I'm more familiar with apt get and adding repositories. Does yum work
>> similarly? Just curious and trying to learn. Thanks!
> Yes, yum is the CentOS equivalent to apt-get. They both work in similar
> ways. There were some good yum howto or tutorials that I learned from when
> I needed to use it that I found via google.
> -Steve
>  On Monday, June 11, 2012, Stephen Woodbridge wrote:
>>    On 6/11/2012 3:41 PM, Steve Horn wrote:
>>        Hello again :)
>>        Trying to build and install the trsp branch on my CentOS linux box.
>>        (Using
>>        https://github.com/pgRouting/ pgrouting/wiki/Developer---
>>        Getting-Started
>>        <https://github.com/pgRouting/**pgrouting/wiki/Developer---**
>> Getting-Started<https://github.com/pgRouting/pgrouting/wiki/Developer---Getting-Started>
>>        as
>>        a baseline)
>>        Here is where I'm at:
>>        # git clone https://github.com/pgRouting/ pgrouting.git
>>        <https://github.com/pgRouting/**pgrouting.git<https://github.com/pgRouting/pgrouting.git>
>>        # cd pgrouting
>>        //Hack around installing GAUL
>>        # cmake -DWITH_TSP=ON -DWITH_DD=ON .
>>        -- POSTGRESQL_EXECUTABLE is POSTGRESQL_EXECUTABLE-NOTFOUND
>>        -- Found PostgreSQL: /usr/include/postgresql/ include/server,
>>        /usr/pgsql-9.1/lib/libpq.so
>>        Boost headers were found here: /usr/include
>>        Output directory for libraries is set to /usr/pgsql-9.1/lib
>>        Installation directory for libraries is set to
>>        /usr/pgsql-9.1/lib and
>>        for SQL files is set to /usr/share/pgrouting
>>        Installation directory for libraries is set to /usr/pgsql-9.1/lib
>>        -- Configuring done
>>        -- Generating done
>>        -- Build files have been written to: /home/shorn/pgrouting
>>        # make
>>        Linking CXX shared library ../../../lib/librouting_tsp.so
>>        */usr/bin/ld: cannot find -lgmp  //THIS APPEARS TO BE THE PROBLEM?*
>>        collect2: ld returned 1 exit status
>>        make[2]: *** [lib/librouting_tsp.so] Error 1
>>        make[1]: *** [extra/tsp/src/CMakeFiles/ routing_tsp.dir/all] Error
>> 2
>>        make: *** [all] Error 2
>>        Can anyone help me understand the error "Cannot find -lgmp"?
>>    For TSP you need to instal GUAL and for DD you need the CGAL libraries.
>>    Try:
>>    yum search libcgal
>>    yum search cgal
>>    You probably need the dev package also.
>>    After you:
>>    cd pgrouting
>>    git checkout trsp   ## switch to trsp branch
>>    git pull
>>    cmake -DWITH_TRSP=ON -DWITH_TSP=ON -DWITH_DD=ON .
>>    -Steve
>>    ______________________________ _________________
>>    pgrouting-dev mailing list
>>    pgrouting-dev at lists.osgeo.org
>>    http://lists.osgeo.org/ mailman/listinfo/pgrouting-dev
>>    <http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>> Steve Horn
>> ______________________________**_________________
Steve Horn
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120612/9c2739d1/attachment.html>
More information about the pgrouting-dev mailing list
